Crate guitar amp with extremely loud static on power on (no input)
  • mon2
    • Dec 2019
    • 14544
    Hi. Not our mainstream line of work - we work with digital mostly. Will study the schematic found on the internet. The output darlington transistors appear to be ok. Even with no input, the output is extremely loud with static / crackle / pop. Any ideas? Will post more details and fix as we continue the review. Have not checked the main power supply rails yet (+-40V and +-16V).
  • CapLeaker
    Leaking Member
    • 8290
    What model number? Got a schematic to boot with it?
    • mon2
      • Dec 2019
      • 14544
      Thanks so much for replying. No, could not find one..yet. Will share the full details on Monday (or sooner if we run back to the office). Still fixing a Fender 212R which is slightly different in the schematic than the public ones on the internet. Has noise even on clean input. Static / distortion with a mind of its own. The power rails are stable. Amp appears to be ok and loud. Replaced most of the pots and did replace each connector with little improvement. Working with a 1 khz tone from our scope as input and tracing as we go.
      • mon2
        • Dec 2019
        • 14544
        Attached.
        • mon2
          • Dec 2019
          • 14544
          Found the following on internet which may be the scematic - will confirm it on Monday.
          Symptoms are:
          with or without input, blasting loud random static / snap / crackle pop. Volume control has no impact on the output noise. Cut the darlington output transistors to measure in diode mode and they appear to test out fine and without a short. Have not yet injected a 1khz tone into the input to monitor with a scope.
          • CapLeaker
            Leaking Member
            • 8290
            Check with the oscilloscope what goes into the PA. Would be my first step.
              • 31157
              can you split the power amp from the pre-amp to seeif it still generates noise?
              btw, the 16v regulation circuit is taking the piss - i hope these arent marketed as "high end"
              • mon2
                • Dec 2019
                • 14544
                Power supply rails appear to be stable. +-40 is ~38v. +-16v is ~16v. After assorted permutations to open this beast, our 1khz injected tone appears to be clean at the output. Soldered back the darlington output transistors and mated the speakers - still clean. When brought in, the noise was unbearable out of the speakers. Loose connections? Will keep testing.
                  • 31157
                  maybe cracked solder joints.
                  • mon2
                    • Dec 2019
                    • 14544
                    Indeed on the DSP board. See attached. Soldered them back but still no activity on the LEDs.
                    • mon2
                      • Dec 2019
                      • 14544
                      Plugged in a guitar which works fine with our attempt to play music but there is a background high pitch tone (much like the 1khz we were injecting from our scope). This is when the guitar is plugged in and sitting idle. If the 1/4" plug is disconnected, then there is still this tone (corrected update).
                      Will post a new audio of the tone.
                      Is this normal to have this background (annoying) tone? Still trying to validate if the DSP is working or not - all of the LEDs on this DSP board are dark.
                      • mon2
                        • Dec 2019
                        • 14544
                        A fresh recording of this tone - no inputs are mated with this amp.
                        The probe is going to our portable speaker with a 0.1uf cap in series - the amp speakers are disconnected while we experiment to avoid risk of damage to the true speakers.
                          • 31157
                          focus on the dsp board i think
                          • mon2
                            • Dec 2019
                            • 14544
                            Yeah - the DSP board appears to be dead and was purchased this way. Will search for the DSP component but not sure if there is firmware involved or not. A royal pain to probe at the awkward angles for this vertical mounted PCB that is like an oreo sandwich inside of the cut slot. No connectors - just raw PCB pads being soldered to mate with the 90 degree main board.
                            • CapLeaker
                              Leaking Member
                              • 8290
                              I guess they use the DSP board for the delay, reverb etc. If the reverb isn’t working the DSP is dead. Verify if it is getting any power.
                              These kind of speakers have a hard life. Being tossed and kicked around, stored in a wet basement, spillage, etc… perfect recipe for cracked solders and other damages.
                              • mon2
                                • Dec 2019
                                • 14544
                                Have verified that the DSP is indeed receiving 3v3 via the +10v rail then a local LDO. However, no led is being driven. Will investigate the 2N2907 that is onboard the add-on board with the bank of leds.
                                Yes, found about 4 screws that are rusted but otherwise, very clean solder joints under the PCBA. The unit is working much better than when it was brought in but a bit baffled as to how it 'cured itself'. Perhaps the handling of the assorted cabling / pcbs. So far, unable to see any bad solder joints other than on the DSP board (which is still not working).
                                • mon2
                                  • Dec 2019
                                  • 14544
                                  The DSP remains dark but believe it may need a foot pedal to trigger. The client will bring in those pieces next week. The unit is 99.9% better than how it was brought in. Still have that high tone I can still hear but may not matter when the volume is cranked a bit which drowns out this tone. Puzzled on the source of this tone - disconnected by surrounding UPS and test equipment used to isolate myself from the mains but the tone still remains. The DSP schematics are not public from what I could find on the internet.
                                  • CapLeaker
                                    Leaking Member
                                    • 8290
                                    Well…you suppose I got a Fender Aoucustisomething 100 in. It has also a DSP, no schematics to be found for it. My DSP works, I got some problem with one channel no audio, than popping in the speaker and the it works like nobodies business…
                                    I am sure the DSP is running something… upgradable firmware or not.
                                      • 31157
                                      lets see pictures of the dsp board.
                                      maybe (probably) it has a crystal and stuff to check.
                                      • aidanmo
                                        Philips 43PUS7506/12 - Loud blown out sound
                                        by aidanmo
                                        I've got a really strange issue with the speakers on my Philips 43PUS7506/12. It makes this awful loud buzzing now. It happened after it was attempted to be wall mounted - I think the back got squeezed and something broke.
                                        I thought maybe the speakers got damaged, so I replaced them - no dice.
                                        • Using the internal speakers, it always happens.
                                        • Using the headphone jack, it never happens.
                                        • Using the digital/optical out with a soundbar - it happens after about 2h/movie runtime - it's never as drastic, it just pops in and out, but I didn't want it to damage the sound bar
                                        02-28-2025, 03:13 PM
                                      • DaLZy
                                        Extremely Strange Issues with charging and battery on Zephyrus G14(GA401)
                                        by DaLZy
                                        I have recently come into possession of a G14 that cannot detect or charge it's battery. Initially both windows and the bios agreed that the battery was on "0%" but the laptop was able to run without AC power. I was able to get the laptop to detect the true charge of the battery(26%) in windows for a moment but it wouldn't charge or update the percentage when the battery drained. I attempted a few more EC resets and battery reconnections and now the battery shows at 0% in bios and 100% in windows. Additionally the machine is extremely laggy when plugged into AC. When on ac power in the...
                                        01-27-2025, 12:38 AM
                                      • spice_disc
                                        Vizio TV M50-C1 reboot cycle and static on screen
                                        by spice_disc
                                        I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
                                        The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
                                        09-08-2024, 02:37 PM
                                      • Leebo249
                                        SA-HD52 1 Default Crosstalk/static after replacing selector switch IC?
                                        by Leebo249
                                        Hey,
                                        A month back I replaced the selector switch IC on my Panasonic SA-HD52 as the radio was still playing when I selected the CD, it did this with the tape and record too.
                                        Now when I replaced the IC it worked perfectly, no cross talking and I left it at that for a month and have come to it today to play a CD (you can hear it spinning) and the issue has come back although with another issue.
                                        Both issues are random, the original problem where the radio will play over other playbacks has come back and another time you turn it on it will refuse to play anything,...
                                        09-07-2025, 07:23 AM
                                      • Darren Hibbert
                                        A2179 fast fan and extremely laggy touchpad :'(
                                        by Darren Hibbert
                                        I just changed the screen on a Macbook A2179.
                                        On restart, it boots up to the password screen but any movement on the touchpad is extremely laggy and the fan spins up to full speed.
                                        I tried checking all the connectors which are all in place.
                                        New thermal paste on CPU.
                                        Also noticed the battery is not charging either and shows a battery sign in the top right hand corner with an exclamation mark in it.
                                        I have schematic and boardview if anyone can help me with this?
                                        Many thanks.
                                        08-21-2025, 05:43 PM
