Anyone know how to get this sucker open? I've got all visible screws (including under rubber foot) and the level control pot nut removed. Apparently I need to remove the front grill but it won't budge. Do I just have to get brutal with it? I'm not having luck Googling for it.
Zylux (Dell) A425 subwoofer disassembly
Tags: None
Re: Zylux (Dell) A425 subwoofer disassembly
Can you remove the back panel and see inside ? I'm wondering if there are clips that need to be released to remove the front ?
Just found this video. The sub looks the same. It doesn't show the front being removed just the securing points after the front has come off.
Mute the sound if you are offended by swearing lol
http://www.youtube.com/watch?v=i33TRCvuhGY -
Mystery solved. Thanks for the vid but it didn't help.
I had to get medieval on its buttocks with a flat-head and a rubber mallet but I got it off. Plastic posts into particle-board baffle with silicone glue on the ends of a couple of them. The control pot wiring is also silicone glued thru a hole in the baffle. Gotta clear that and disconnect the speaker, which are what's keeping the rest of the guts from exiting thru the back panel. They used spade connectors on the speaker but soldered the negative spade on. Why use the spades if you're gonna solder the thing on anyway? Some people's children...
It was made in a capitalist version of a prison-like workplace in a communist country.
I was wrong about the glue though, it's hot glue, not silicone.Last edited by SteveNielsen; 08-06-2014, 04:22 PM.Comment
by BowlineMy question pertains to understanding the control circuity inside a Dell PT434 type battery used in Dell E6400, E6410 and other Dell notebooks?
I have tried multiple different Dell power adapters. My Dell... -
by Akhlz001Hi,
Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...-
Channel: BIOS Requests ONLY!
by master3112I would like to share my experience about charging issues with Dell power supplies with the tech community. I am working on a Dell Inspiron 5590, Mainboard 18778-1 with charging problems. The device can be switched on and works so far, only the message appears at startup:
The power supply unit is not recognized in the Bios and the charging process is set to "idle". I use original Dell battery, type...-
by SMDFleaDell thunderbolt firmware, extracted from dell firmware update exe. Padded to 1MB.
Some models have a choice of 2 different firmwares, it depends on the dell SKU.
The SKU is in brackets (****)
EDIT: NVM65...-
by dell_sadnessBIOS password locked Dell Latitude 3440 (Service tag B4HNJX3)
Have extracted the BIN and want to know how to rebuild a clean BIOS
I have come across the 8F8C patcher but not sure if that would work in my case as the service tag ends in 0001.
I tried it and although the log states it patched several mentions of 8F8C in the BIN, I haven't flashed it yet in case such a patch wouldn't work.
Have also tried to extract a clean BIN file from Dell's .exe BIOS updates using 'Dell PFS Extractor', but not confidently; Ended up with a 25MB file instead of the same 32MB...-
- Loading...
