pure dmx60
  • azza1234
    • Nov 2013
    • 124
    • united kingdom
    pure dmx60
    Hi I just got given a pure dmx60 with no power and was wondering if anyone else has had problems with this make of stereo ive checked the main fuse and the fuse near the transformer and there ok but its not getting any voltage to the glass fuse near the transformer any one got any ideas where to start?
    • 31113
    Re: pure dmx60
    post a foto of the other side of the board so i can see the tracks.
    • azza1234
      • Nov 2013
      • 124
      • united kingdom
      Re: pure dmx60
      Is this ok?
        • 31113
        Re: pure dmx60
        no, it's really bad.
        but it looks like the top of the relay is cracked.
        and you should make sure you dont mix up the connectors.
        it looks like the one near the fuse is the input,
        and the one to the left of it is the output that is switched with the relay.
        get them the wrong way around and it wont run.
        • azza1234
          • Nov 2013
          • 124
          • united kingdom
          Re: pure dmx60
          I replaced the original capacitor (2200uf 25v) with a 2200uf 40v and now when plugged in you can hear the stereo trying to start (like a click noise) but nothing else happens could it be a different problem for example with the toroidal transformer?
          • R_J
            • 9569
            Re: pure dmx60
            That looks like the standby voltage board only. I suspect problems elseware, main power supply or output section.
            • corrize
              A funny fuse story – Lumix LX100 II
              by corrize
              Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
              I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
              The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
              There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
              And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
              10-19-2023, 09:58 AM
            • ohren
              Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
              by ohren
              Hello!
              I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
              Measured voltages with no load:
              After rectifier diodes
              12V: 6.17 V
              5V: 5.67 V
              Secondary transformer pins AC measurement (really don't know if this says anything)
              12V: 2-2.5 V
              5V: 1.04 V
              I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
              03-18-2023, 10:33 AM
            • jesterace
              Samsung UE46ES8000 Blown fuse but no other signs of short
              by jesterace
              Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
              09-11-2024, 03:14 PM
            • jshhh
              Help replacing fuse on my Mimaki CJV300-160 vinyl printer
              by jshhh
              Hi guys,
              I'm inexperienced with electronics repairs, I've done a little bit of soldering caps and whatnot, but i have a blown fuse on this mimaki printer I got which I have bought a replacement for.
              How do I remove this type of fuse (see picture)...it kinda looks like it would pull out of that bracket but it didn't come at first pull and I didn't want to brute force it incase it's soldered on there like most of the rest of the components.
              Anybody know how to remove this type of fuse?
              (The fuse is toward the bottom of the image labeled F2)...
              06-17-2025, 01:35 AM
            • mikey5791
              Is it possible for transformer substitution?
              by mikey5791
              Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
              Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
              My questions are
              1. How do i test to see if the transformer is in good working condition?
              2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
              Hope you guys understand what i was asking. My intention is...
              11-03-2022, 02:11 AM
