Marian Trace Alpha sound card repair help
  • Christos Tsiligiannis
    • Nov 2024
    • 9
    • Greece
    Hello to the forum.
    My name is Christos, I am new to the forum here and i am posting from Greece.
    So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
    To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
    So i tried asking for a schematic from the company and they would not give me one. Instead they went ahead and asked for money to repair. Problem is that repair costs plus shipping makes any sense for this old card, but i would like to get it repair and probably keep it as a spare if one of my other breaks (i also have some other from many brands).
    Anyway, so this card gets recognized by windows as a sound playback device without drivers installed, but when installing drivers i get error 10 from windows. Is says, sound card cannot open. Drivers from the manufacturer say DMA engine not ready.
    It is not a driver's fault as the other card with the same drivers work fine. I have also tried even older (even the first) versions and nothing..
    So at first i was thinking there must be something wrong near the PCI connector like a capacitor or something as it seems the sound card does not get any voltage. so i am kinda speculating these old electrolytic aluminum capacitors shown in the photo. I have also read online that the crystal oscillator can break on some sound cards but i haven't found anything about my exact card. i have ordered 10 of these 47 16s capacitors as well as one 40mhz oscillator from alliexpress to try and replace and see if these might be broken. One guy told me to reflow them a bit and add some solder to all the pins i see as loose connections is a common thing for sound cards.
    any thoughts for troubleshooting?Click image for larger version
    • 31269
    get a datasheet for the spartan fpga,
    then check the voltages and any clocks on it.
    if those are good it may have lost it's configuration eeprom data
      • Nov 2024
      • 9
      • Greece
      thanks for the reply.
      unfortunately I only have a multimeter so I can only test voltages not clocks.
      so I let’s pray it’s a bad cap or something
        • 31269
        you can also check any voltage regulators on the board.
          • Nov 2024
          • 9
          • Greece
          Can you help me on how to check those?
            • 31269
            what are the part numbers on ic's 10,18 and 20?
            they are the packages with 3 pins on one edge and a tab on the oposite edge.
              • Nov 2024
              • 9
              • Greece
              Ic10: 24AD N00A
              ic18: 2CRN N13A
              ic20: 23AE N05A
                • Nov 2024
                • 9
                • Greece
                not a clue?
                • gerry.b
                  • Feb 2025
                  • Deutschland
                  in eBay i found a brand new Marian Trace Alpha sound card in germany for 50€: auction number 176858394388
                    • Nov 2024
                    • 9
                    • Greece
                    thanks for the reply!
                    I have sent my old broken card in Marian for fixing. I am still waiting (2-3 months now). I told them to not rush as I have it as a backup. So I am thankful for the eBay listing, but I will leave it for anyone else that might need it more.
                    • FZG
                      EVGA Nu Audio Sound Card - Not Working
                      by FZG
                      I have an EVGA Nu Audio sound card that is not working properly and I need some help diagnosing the fault (preferably by someone who owns this card and is willing to take some measurements).
                      The card sort of powers up (LED lights are coming on and the relais is clicking, some voltages are present) but it is not detected in Windows. I tried installing in two different PCs and tried several driver versions but the card was never detected anyway. So I thought this is probably not a driver / software-issue and then disassembled the card to take some measurements.
                      I found...
                      03-07-2025, 11:44 AM
                    • paparazzo79
                      sound card dead after graphics card installation
                      by paparazzo79
                      Hi guys.I own Z690 F Strix board in one of my PCs....everything was working fine with integrated graphics card.I turned off power from it, installed graphics card from another PC, connected all the peripheral cables, optical sound cable of course when everything was switched off.Then I powered on the machine and integrated soundcard is dead.How did this manage to happen and if there is a way to diagnose and replace damaged component?
                      The new pci-e soundcard costs here 80 euros which is half of money I spent on motherboard.
                      I still can not believe that I am such a looser and don't know...
                      07-23-2024, 12:22 PM
                    • alpersen
                      Modding, adding usb/c audio pcb to laptop with faulty sound card/chip, Lenovo L340
                      by alpersen
                      Hello
                      After months of trying I gave up my laptops sound card. I plan to solder a sound card on pcb inside my laptops case, probably connecting to usb ports inside. Do anyone has an experience to recommend pcb type audio/sound card suitable installing inside a laptop? Probably should have some type of amplifier for connecting to internal speakers ( speakers ).
                      Thank you
                      11-19-2023, 09:34 AM
                    • LEECH666
                      Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                      by LEECH666
                      Good day ladies and gentleman!
                      I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                      This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                      I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                      01-19-2024, 05:46 PM
                    • ChaosLegionnaire
                      by ChaosLegionnaire
                      09-13-2022, 09:02 AM
