Need help adding input jack to 80's car radio
  • Mark M
    • May 2014
    • 4
    New guy here. I have a mid-80s Delco AM FM Cassette radio that I am installing in a 1964 Chevrolet Corvair and I would like to add an input jack so I can connect to my iPhone. I have a cassette adaptor that works, but would prefer to have the jack so I can eliminate the wire hanging out of the cassette opening. I am willing to sacrifice the operation of the cassette if necessary in order to wire in a jack. After a search I found a similar thread, but the wiring of the radio was different than mine.
    There are two connectors coming from the cassette. I believe the one I need to connect to is in photo below. There are 6 wires: Red, Wh w/red, Green, Black, Orange and Yellow. Green and Black go to the "Tape" light on front of the unit. How do I splice into the other wires to add a jack to the circuit?
    Can I add a DPDT switch to select from radio, cassette and input? Or, do I need to sacrifice use of the cassette. If so, will I need to put a cassette in the unit to signal it to switch to aux input? Diagrams will help - I am not good at electrical.
    Thanks,
    Mark
  • SuperDuty
    • Mar 2011
    • 299
    • France
    Re: Need help adding input jack to 80's car radio
    Here's my simple diagram :
    I used it on mu UU6 radio from 1984.
    The switch is precisely used to feign the presence of a cassette so I don't have to put an empty one in. When the wires 3 and 4 are shorted together, the unit will think there is a cassette, when the 5 and 4 are shorted, it will believe it's supposed to play the radio and won't use the audio signal from the cassette player.
    You will have to find which wire does what on your unit, even though some colors are the same, I can't tell your they serve the same purpose. I did not have to search on my unit as I had found a tutorial on TurboBuick.com where someone was doing the same thing on a similar double DIN unit (those Delco units with three mechanical buttons under the cassette deck).
    • Mark M
      • May 2014
      • 4
      Thanks for the help. So when the switch is in the leftmost position you have cassette. In rightmost, radio. What do you get when the switch is in the center? Or perhaps there is no center?
      Not sure I can figure out how to wire the switch in, but I think I can find left and right channels.
      If anyone else has input on how to wire the switch I would appreciate it.
      • SteveNielsen
        Retired Tech
        • 2327
        You could also try tapping into the high sides of the volume pot through a couple of caps (I'd try something between .05uF and .1uF) to block any DC that may be present. Like a signal injector.
        • SuperDuty
          • Mar 2011
          • 299
          • France
          There's no middle position, there's one common wire used in the system and that's the +12V. The switch just goes from +12V/radio to +12V/cassette.
          I'm sure this design could be much improved, I'm by no means an expert but I just have a rough idea on how it works. If anybody knows a bit about these units and thinks of a better way to add an AUX input, I'd be very interested.
          My unit was the high end stuff in 1984 and cost an arm (it was a $510 option in 1984), it sounds really good but I need better speakers. All I have is the stock 4x6 front speakers and some aftermarket stuff I found on parts cars. Not great.
          • R_J
            • 9535
            Why not use a wireless fm transmiter, like an iTrip
            • audiofreak19
              • Apr 2013
              • 556
              • usa
              Why not use a hardwired transmitter. It ties in through the antenna plug on the back of the radio. They have a kit they sell made by I simple the model number is IS77. Bestbuy sells it and I believe it included installation and it has a direct plug for the iphone and will charge it as well. It's a good deal I used to install them.
              • mikey5791
                Sony CFS-5000S radio cassette player no FM reception
                by mikey5791
                Hi forum members,
                In the past i have had many helpful hints from generous forum members in diagnosing and solving issue related to most of my electrical things.
                Fyi, i have been keeping this unit of Sony radio cassette player as the cassette belting has worn off but the radio has been working fine before. Recently, out of a sudden i found out i can't get any radio reception at all (no signal from FM,MW or SW band) except some buzzing warp noise from the speakers.
                I opened the casing inside and checked for any dry solder, burned component or loose wires...
                02-24-2023, 03:48 AM
              • shelby5041
                clock radio / radio lifespan?
                by shelby5041
                hi
                ive got a modern digital clock radio approx 15yrs old
                my question is how long can a clock radio or a simple radio last ss farcas operating hours?
                since elec components have limited hour lifecspan i would imagine the radio or clock radio would eventually fail.
                the reason i ask is because i have my clock radio on radio function 24/7 for the past 7 years and its still working fine....i leave the radio on ..never turn off past 7years...thats approx 60000 hours
                it uses very little power just a few watts i would imagine that may have something...
                09-14-2024, 03:30 AM
              • ugamazing
                820-02020 Super Weird Issue: Keyboard Input Character Map "Wrong"?
                by ugamazing
                So, I have a really bizarre issue that I'm struggling to identify the cause of. Working on an 820-02020 board with some bizarre keyboard/input-source character mapping. My suspicion is a possible damaged SPI ROM (U1970), perhaps, but I'm really not sure in this case:
                1. The issue is pretty weird, but when installing MacOS, I noticed my WiFi password did not work. I quickly realized the special characters (!@#$%^& etc) were not mapping correctly.
                2. I noticed the keyboard layout/input-source is defaulting to JAPANESE every single time I restore the board. I am not...
                04-10-2024, 08:06 AM
              • Sushi1808
                Onkyo TX-NR609 Sound only on USB/Internet Radio/DLNA Input
                by Sushi1808
                Hi everyone!
                I turn to you in hope someone could point me in the right direction since I lack knowledge and experience in diagnosis of audio equipment. (My experience is in computer chip level repairs.)
                I bought an Onkyo TX-NR609 receiver which initially produced no sound on speakers/headphones, there was no delayed relay click, speaker matrix icon didn't show up, USB/NET stuck in "Now initializing", instead of DSP/1st NET firmware version there were ?????????...
                There was flux residue around the D830K013BZKB4 DSP chip (Q3001) on the HDMI...
                07-01-2023, 07:53 AM
              • UserXP
                Vintage SONY Digital Clock Radio ICF-C12W no audio
                by UserXP
                Dear all,
                I have this old radio clock by Sony from the early 80s, I guess. The clock display works, but is dim, the function board appears to be OK - but the radio unit shows no signs of life. It doesn't produce a single noise, crack or anything from either FM or AM band. It's like it doesn't even power up.
                i opened the radio and it is full of some TRACON gray capacitors. They only have their negative strip printed, voltage and capacitace markings - no series, no temperature marking, nothing else.
                My question is, do you know of this brand of capacitors and how bad are...
                07-21-2025, 08:35 AM
