Infinity 475a car amplifier 75Wx4Ohm
    Re: Infinity 475a car amplifier 75Wx4Ohm
    When that pin2 of the SMPS IC is less positive than pin1, that is when the SMPS goes into shutdown. Pin2 can be pulled down toward ground if Q3 is turned on due to error signals from output detection circuits, or if the thermal sensor RT1 resistance goes low to cause pin 2 to be lower than pin 1 which will cause pin3 output to swing HIGH (it is normally LO).
    Q7 (2SC1815) symbol is drawn wrong, it is NPN not PNP as shown in the diagram page 28.
    You can defeat output detection by lifting D4, but you have to be careful because if there is problem in the output section in one or more of the amplifiers you can have damaged circuits.
    • tibimakai
      • Jan 2012
      • 3680
      I'm getting frustrated with this amp.
      The schematic doesn't match 100% with my amp. It seems like they were two versions out there judging by the top cover differences.
      There is no variable resistor and I can't find that RT1 either.
      I have cut the power(after the two main capacitors) to the finals(VCc+/-) and protection mode is still on.
      I don't know how to do measurements and the FETs to be installed on the heatsink, it's almost impossible. This is a single layer board and the layer is at the bottom, can't reach it. I guess, I will end up removing the board and re-installing it a few(20x) times.
      I have to be sure that the power supply delivers what it should deliver first, no?
      I can't find the 7815 section either.
      Another thing is, how to discharge the amp, because it takes forever to drop the voltage? I have sparked a couple of times the FEts, while trying to remove the PCB.
      • tibimakai
        • Jan 2012
        • 3680
        It seems like the VH+/- is missing.
        I'm measuring +/-0.2V across C57 and C56.
        • Agent24
          I see dead caps
          • Oct 2007
          • 4981
          • New Zealand
          Can't you test for voltages on leads of components at the top side?
          Try the discharge ideas here: http://www.repairfaq.org/sam/smpsfaq.htm#smpssafdc
          -David VanHorn
          • tibimakai
            • Jan 2012
            • 3680
            OK, I have tried measuring with Min/Max Peak and it showed 30V, but then shut it off.
            I'm trying that way to measure, but not all components can be reached.
            For example C56, is against the toroidal transformer and C55 against it.
            So, I'm guessing that something is still shorting in the amp section, to cause this shut down.
            • tibimakai
              • Jan 2012
              • 3680
              I'm about to quit on this amp.
              It's so nerve racking to follow the PCB and the schematic. I feel like I'm not capable of following the PCB.
              Why they made it so complicated, I don't know.
              It seems, like the schematic is not the same as the amp.
              I can't fine those diodes at each amp's VH voltage. There are a bunch of ZD diodes on the PCB and in the schematic I can't find them.
              There are some diodes like D2, D14 and D1, D3 on the pcb, but I can't find these on the schematic. There are other diodes D2, D3 on the daughter board, which I can't even find on the schematic.
              There are so many jumpers, that my head hurts just following them.
              I have repaired a couple amplifiers lately(home and car amp), but this one will beat me and I will have to quit.
              • conan981
                • Aug 2011
                • 72
                • ITALY
                #27
                hi, i just took in my hands this exact model of amplifier, with the same error.
                it light up PROTECT led as soon as i give power. Amplifier has connected only power cables. now i read discussion and infos from Budm and others and found Q7A-B-C-D transistors and RT100 thermal switch, and another thermal switch that is noted with CN4 (i think an error).
                now, i can do measurements but i don't know what to check to try what Budm was suggesting (give vcc off one amp at a time).
                Also, RT100 thermal switch is an JUC-31F i would know if it is normally closed or opened, since it is always open with over 2MOhm.
                Let me know if someone wants help me, i would be happy to follow istructions to repair.
                thanks
                Conan
                  • 31094
                  • tibimakai
                    • Jan 2012
                    • 3680
                    I still have the amp, I have just put it away.
                    • conan981
                      • Aug 2011
                      • 72
                      • ITALY
                      #30
                      on service manual is written only Temperature Switch JUC-31F65℃ ±5℃ TO-220 1 RT100
                      i don't know if it is normally opened or closed. maybe tibimakai that removed the clips that block these ones to cooler can give more infos
                      • tibimakai
                        • Jan 2012
                        • 3680
                        CN4 shows 32.12Kohm and the RT100 starts around 480Kohm and is going higher and higher.
                        This is how I have it set up for easy testing. Some Aluminum strips, some clamps.
                        To remove the original clips, use a bent screwdriver, like one I made one for myself.
                          Post 21 (if the circuits are drawn correctly) " or if the thermal sensor RT1 resistance goes low to cause pin 2 to be lower than pin 1 which will cause pin3 output to swing HIGH (it is normally LO)." So if the RT1 is closed the unit will go into shutdown.
                          • conan981
                            • Aug 2011
                            • 72
                            • ITALY
                            #33
                            ok, so the RT1 and RT100 are normally opened and mines and tibimakai ones are ok.
                            CN4 (RT1) is measuring 32kohm and RT100 is over 2M Ohm (open circuit).
                            Should we check in some way the 4 transistors?
                            • tibimakai
                              • Jan 2012
                              • 3680
                              I had blown transistors and I have replaced them already.
                              I even had blown off traces at the transistors. All that is done and I still have the protection on.
                              • CapLeaker
                                Leaking Member
                                • 8226
                                Did you check all the transistors mounted on the heat sink for shorts? If they are none, check the big resistors on each output transistor and their driving transistor. If the driver is bad, unit will stay in protection too.
                                • tibimakai
                                  • Jan 2012
                                  • 3680
                                  On mine, I believe that in the power supply section is something bad.
                                  I had a couple FETs blown there, too.
                                  • tibimakai
                                    • Jan 2012
                                    • 3680
                                    Can you believe, that I'm back to repair this? It's been 5 years already!?
                                    I have found a leaky transistor, Q12B.
                                    Replaced it and the first time I turn it on, it turns on OK(blue LED is on). The power supply is only a 5A one. That could be a problem? Turning on this amp, maybe spikes higher then 5A?
                                    If I turn in off and then on again, it goes into protect mode.
                                    I have soldered two wires, at the pin #9 and #10, at TL494 and when it's not in protect mode, I have two nice square waves.
                                    If I turn it off and then on again, protect mode is on and the two square waves are gone. It shows a negative straight line, at both outputs. -29V is gone. +29V is always present.
                                    I have even replaced TL494 again, just in case. All the transistors/diodes, on that daughter board check out OK. It could be a bad capacitor somewhere?
                                    • tibimakai
                                      • Jan 2012
                                      • 3680
                                      It is all good. I guess, it was my power supply, as it was discharging, "causing" the protect mode?!
                                      If I kill the power instantly and apply it again, no more red light.
                                      It is fixed.
                                      • vlady carp
                                        Looking for Dump for P87C51SBPN (Concord Infinity Elevator)
                                        by vlady carp
                                        Hello, colleagues!
                                        I'm currently dealing with an issue while repairing a Concord Infinity elevator. The microcontroller P87C51SBPN used in the control board has failed, and I need the original firmware dump in .bin format to replace it with a new processor.
                                        What I've done so far:
                                        • Diagnosed the issue and confirmed the microcontroller is the root cause of the problem.
                                        • The original processor is beyond repair, and I wasn't able to extract the dump.
                                        • Reached out to the manufacturer (Savaria/Concord), but I haven't received a response yet.
                                        01-16-2025, 02:08 AM
                                      • jinu_j
                                        How to test Subwoofer Amplifier with only a multimeter
                                        by jinu_j
                                        Hi Folks
                                        Need some advice on how to test a subwoofer amplifier if i have access to only a multimeter.
                                        Problem
                                        I have a Boston Acoustics active Subwoofer (soundware S). Its rated output is 200W. But the output i am getting is very low i can barely hear/feel it even if put the gain at max. I replaced all the capacitors in the Subwoofer amplifier but still no change.
                                        Is there anyway to test this without getting an oscilloscope/Function generator to see if the fault is with amplifier, driver or the source??
                                        Any advice would be appreciated...
                                        08-29-2024, 02:05 AM
                                      • UserXP
                                        Mackie CR4 amplifier no sound
                                        by UserXP
                                        Hi, people.
                                        I've got an amplifier assembly from Mackie CR4 parts. It's just an amplifier, there was no speaker housing, so I used my set of CR4s to test it.
                                        Anyway, upon connecting everything and hooking the "new" amplifier to an audio source, the sound played clearly and strongly for the first ten seconds. I was happy it was working. Then the sound started to fade out during the playback until it was no more. After it had "dropped to zero", there were two very short intervals of sound playing at the normal volume, as if the amplifier was trying to...
                                        10-17-2020, 05:06 PM
                                      • mikey5791
                                        Help on car amplifier only one channel works
                                        by mikey5791
                                        Hi all forum members,
                                        Fyi, i have been working on this old model PCT-4082 (4 channel car amplifier). The owner said only one channel is working.
                                        My initial finding is this amp originally use Toshiba 2SA1943 and 2SC5200 transistor for its output but after opening the top casing i found it used Toshiba A1941 (pnp)and C5198(npn). I desoldered all the 4 pairs transistors and found 1 piece A1941 open(tested "OL" on all legs) and replaced the 1st pair with 2SA1943 and 2SC5200, thats why you can see in the picture it is the bigger size transistor. The other A1941 and C5198 all...
                                        08-06-2025, 10:36 PM
                                      • Francesc V.
                                        Rotel RSX-1056 amplifier. Troubleshoot a noisy channel
                                        by Francesc V.
                                        Hi:
                                        I've realized that one of the channels of this amplifier has no proper sound.
                                        This is the signal at the speakers output.
                                        As long as the audio coming in to the amplifier board (blue) looks ok although with some noise due to the wire, I think that there's nothing to look at the preamp section.
                                        Now, I could start looking at components to see whether I find the guilty one.......but I would rather prefer to ask for advice. Here there is the amp. schema. Which points would you check with the oscilloscope to gather...
                                        07-15-2025, 01:33 AM
