Infinity 475a car amplifier 75Wx4Ohm
  • tibimakai
    • Jan 2012
    • 3680
    I have picked up this amplifier for $10 from CL.
    The amplifier is in protect mode.
    I have tested all the heat sink mounted components and they all look good.
    It uses a TL494 PWM IC which I think is the problem here.
    There are one diode at each output and only one of them hows real voltage, 12.07V, the other is only 0.2V.
    There is a way to check it to be sure that it's bad?
    The IC is mounted on a small daughter board vertically, so it's very hard, or almost impossible to take measurements with it installed.
    Diode D2 and D3 are on the main board.
    I have never dealt with this IC in the past, any help would be appreciated.
    Schematic is available here:
    Re: Infinity 475a car amplifier 75Wx4Ohm
    The outputs of the TL494 E1 (PIN 9), E2 (PIN 10) are 180 deg. out of phase form each other to drive the Gates of those MOSFETs which are setup as push-pull output to drive that power transformer, only one set of the MOSFETS will be on one at a time. D2 and D3 are for the clamping circuit, if too much current flows through the DIODEs, it will bias on the transistors Q8, Q9 which will route the Gate drive signals to ground. You can at least compare the resistance readings on those two outputs, you can also look at those pins with the scope.
    • tibimakai
      • Jan 2012
      • 3680
      It's safe to remove the PCB from it's case/heatsink for measurements? (no signal)
      • tibimakai
        • Jan 2012
        • 3680
        I have replaced the TL494, just because it was so cheap, but it didn't change anything. It's still in protect mode.
        There are two other diodes D2 and D3 on the little daughter board and I can't get with the scope to them. There are some other components in front of them.
        • tibimakai
          • Jan 2012
          • 3680
          Actually, I have managed to reach in there and I have got two nice sinuses at both diodes.
          I have noticed that there is a +/- 29.24V at both sides of the amp, at the finals.
          What else can it be?
          The wire that I'm powering with it matters, how thick it is?
          I'm using the wires from the Chinese power supply(GQ A-305D), basically I'm tightening the alligators into the wire slots.
          I'm measuring the speaker outputs of all four channels, they all show 0.079V.
          That is not to high? It shouldn't be under 0.01V?
            Check lines PRO and DC which could be indicating a fault. They are on the schematic area for the final output transistors.
            Incidentally I'm having a little giggle with them using TIP35 output transistors, I guess they aren't targeting audio fidelity (I'm no audiophile, but I can appreciate the difference between standard and audio rated, high linearity transistors...)
            • tibimakai
              • Jan 2012
              • 3680
              I'm noticing these designations, like PRO, VH and such.
              What they mean?
              • Agent24
                I see dead caps
                • Oct 2007
                • 5039
                • New Zealand
                What they mean?
                PRO probably stands for protect, either used to show the protect mode status (active or not) or it carries the actual signal that will turn protect mode on or off.
                VH would likely be some voltage rail.
                Look a the schematics in your manual there, you will find the names.
                It's a car amplifier, who cares for audio quality?
                -David VanHorn
                  VH+, VH- are the power supplies (generated by T1 windings pin 5/8/10) for the output stage driving circuits, see page 22~25, 28.
                  'PRO' is the protection signal which are generated by Q7A/B/C/D that monitor the output section of all 4 amplifiers, see page 22~25. The outputs are OR gated to Q10 which feeds Q3 which feeds pin2 of U1, page 28.
                  • tibimakai
                    • Jan 2012
                    • 3680
                    Thank you for all the info.
                    The question is, how much it should be the supplied power at the finals?
                    Right now, I'm getting +/-29V. It should be much higher then that, no?
                      OK, this is an estimate (assume 100% efficiency for easy calculation), the power supply is putting out +/- 29V = 58V P-P, or about 20V R.M.S, so with 4 ohm load, the power will be 100W, but this amp is Class A/B so the efficiency may around 60~70%, so output is about 60~70W.
                      So +/- 29V should be OK, the caps are also rated at 50V (about twice the output voltage, so it looks right for you are getting).
                      • tibimakai
                        • Jan 2012
                        • 3680
                        The transistors are good, the power is there and it's still in protect mode.
                        What do you think I should be concentrating here?
                          There are 4 amplifiers PROTECTION detectors Q7A~D, and the Temperature detector RT1, any one of those 5 detector can activate the shutdown.
                          It can be one of the amplifier has DC off set that set off the protection so you will have to find out which one by disconnecting the +VCC/-VCC feeding the amplifiers one at a time, or if you can disconnect the +VCC/-VCC from feeding all 4 amplifiers to see if the power supply will stay on, but make sure to put some load on the +VCC/-VCC.
                          Also check RT1 resistance.
                          • tibimakai
                            • Jan 2012
                            • 3680
                            Bud, do you think that is safe to do the measurements without the heatsink mounted? Basically the whole PCB pulled out of it's housing?
                              For the Audio power amp sections will be OK since there will not be any speakers at the output and the Idling current on the output transistors will be very low, but you do need to have heatsink on the switching MOSFETs because it will be still driving the power transformer.
                              • tibimakai
                                • Jan 2012
                                • 3680
                                I will pull it out half way then. Thank you.
                                  So, the situation right now is that you will see the +/-29V at the power supply output, then the protection kicks in with 'PRO' LED lit up, correct?
                                  BTW, I also spot en error of the schematic on CN5 PIN 4 and PIN 5 connection.
                                  • tibimakai
                                    • Jan 2012
                                    • 3680
                                    I can't get proper measurements with the board in it's place, so I can't even measure the PS outputs.
                                    I have measured the 29V at the finals.
                                    I still haven't measured the +/- 15V supply.
                                    As I apply the power, it goes right into the protection mode. The power LED doesn't tun on at all.
                                    Yesterday I was busy with a Kenwood nav unit(I have picked it up for $150 and it's already for sale for $350, no problems at all. I have done some software upgrades and tested all the functions.), I didn't have time to look at this amp, but today I will do some measurements.
                                    The two LEDs are switched?
                                      The LED connections are OK in the unit, just the drawing is wrong. So the +/-29V is there even when the 'PROTECTION' LED is on? The power supply caps may maintain the voltage for awhile even after it goes into shutdown until they are discharged.
                                      • tibimakai
                                        • Jan 2012
                                        • 3680
                                        I have spent a half an hour with this amp, and I have measured a couple of spots.
                                        The voltage is 25.4V now and not 29V as before, not sure why though.
                                        I have measured a discrepancy at the output, at the resistors R25.
                                        R25C(third amp from the top of PDF) measures 0.081V, while the other three R25s measure 0.041V.
                                        I'm having a hard time finding the amps components on the board.
                                        I still don't know where is the RT1D and other components. How this components should measure if it's bad or good?
                                        I will take the board out and look for these components and while at it, I will check all the components on the channel C.
                                        Tomorrow, I start checking the LG TV.
                                        • hayrieker
                                          Infinity M7-11R7N-888 (GM7TN7)
                                          by hayrieker
                                          Hello, I need Infinity M7-11R7N-888 bios. serial no : GM7TN7M2213600193
                                          Attached original bios from motherboard, and pictures
                                          the problem is no power on. 3v, 5v, 1.8v are comming. there is no any short, I read 00.10 ah on my power suppley (dps5020)
                                          So I think bios is damaged. If you have an idea pls help me. Regard masters....
                                          09-12-2025, 08:21 AM
                                        • vlady carp
                                          Looking for Dump for P87C51SBPN (Concord Infinity Elevator)
                                          by vlady carp
                                          Hello, colleagues!
                                          I'm currently dealing with an issue while repairing a Concord Infinity elevator. The microcontroller P87C51SBPN used in the control board has failed, and I need the original firmware dump in .bin format to replace it with a new processor.
                                          What I've done so far:
                                          • Diagnosed the issue and confirmed the microcontroller is the root cause of the problem.
                                          • The original processor is beyond repair, and I wasn't able to extract the dump.
                                          • Reached out to the manufacturer (Savaria/Concord), but I haven't received a response yet.
                                          01-16-2025, 02:08 AM
                                        • jinu_j
                                          How to test Subwoofer Amplifier with only a multimeter
                                          by jinu_j
                                          Hi Folks
                                          Need some advice on how to test a subwoofer amplifier if i have access to only a multimeter.
                                          Problem
                                          I have a Boston Acoustics active Subwoofer (soundware S). Its rated output is 200W. But the output i am getting is very low i can barely hear/feel it even if put the gain at max. I replaced all the capacitors in the Subwoofer amplifier but still no change.
                                          Is there anyway to test this without getting an oscilloscope/Function generator to see if the fault is with amplifier, driver or the source??
                                          Any advice would be appreciated...
                                          08-29-2024, 02:05 AM
                                        • UserXP
                                          Mackie CR4 amplifier no sound
                                          by UserXP
                                          Hi, people.
                                          I've got an amplifier assembly from Mackie CR4 parts. It's just an amplifier, there was no speaker housing, so I used my set of CR4s to test it.
                                          Anyway, upon connecting everything and hooking the "new" amplifier to an audio source, the sound played clearly and strongly for the first ten seconds. I was happy it was working. Then the sound started to fade out during the playback until it was no more. After it had "dropped to zero", there were two very short intervals of sound playing at the normal volume, as if the amplifier was trying to...
                                          10-17-2020, 05:06 PM
                                        • mikey5791
                                          Help on car amplifier only one channel works
                                          by mikey5791
                                          Hi all forum members,
                                          Fyi, i have been working on this old model PCT-4082 (4 channel car amplifier). The owner said only one channel is working.
                                          My initial finding is this amp originally use Toshiba 2SA1943 and 2SC5200 transistor for its output but after opening the top casing i found it used Toshiba A1941 (pnp)and C5198(npn). I desoldered all the 4 pairs transistors and found 1 piece A1941 open(tested "OL" on all legs) and replaced the 1st pair with 2SA1943 and 2SC5200, thats why you can see in the picture it is the bigger size transistor. The other A1941 and C5198 all...
                                          08-06-2025, 10:36 PM
