Onkyo TX-DS575
This topic has been answered.
  • frankusb
    • Apr 2015
    • 111
    Onkyo TX-DS575
    The receiver is going into protect mode when switching inputs or enabling/disabling A or B speakers on the front panel. I removed the protect signal from the main microprocessor and the system played normally on FR and FL speakers from an analog input. I measured the protect signal and it's attached.
    I checked the idle current adjustment on each of the 5 channels and adjusted them slightly (less than 2mV). I checked the DC offset of each channel and it was very small.
    I'm guessing to diagnose further I'll need to figure out which one or more of the channels is triggering protect. What doesn't make sense to me is why changing inputs would cause protect to trigger.
    Any other thoughts on what I might look at?
  • Answer selected by frankusb at 04-12-2024, 02:32 PM.
    frankusb
    • Apr 2015
    • 111
    Thank you redwire for your help. I got the part in the mail today and replaced it and everything is working perfectly. Now I have 9 extra RN1241s. Q3383 has been replaced and no more protect shut offs or popping from Speaker B.
    • petehall347
      • Jan 2015
      • 4426
      there is overcurrent protect .i suspect its that . try without speaker loads first
      • redwire
        • Dec 2010
        • 3907
        The fact that protection trip happens when switching speakers on/off is not good. Normally a power amp doesn't care about this happening- unless it's got problems or a DC offset present on a channel but you say there is none. Are you for sure measuring upstream of the output relays?
        If a pwr amp failure (i.e. output transistor shorted) ever had happened, it can damage electrolytic capacitors and sometimes these get forgotten when replacing semi's.
        Prot DC detect filter cap like C581 on V-PRO. It will false-trigger protection on thumps or low bass if it goes low value. Or the feedback caps get damaged like C505, C506, C607, C608, C1503- if these short then you get a DC offset or the amp cannot go to 0V quite right.
        I would ID the bad channel by checking DC offset on each channel, comparing spkrs on/off with a load resistor present.
        The pre-amp could be making huge thumps if there's a problem there, such as the muting (bad muting transistor) is not working.
        • frankusb
          • Apr 2015
          • 111
          The only time I had speakers hooked up was to test 2 channels. The rest of the time no speakers are connected.
          • frankusb
            • Apr 2015
            • 111
            I measured output voltage between positive and negative after the relays but I probably only got 2 channels of good measurements in stereo mode. Thanks for that hint.
            I don’t know the history as it’s from the trash heap.
            What type of load resistor should I use?
            The pre-amp muting would fit the protect triggering when changing inputs. And I did notice unexpected popping when enabling B speakers during audio testing. I can’t recall if I tried switching inputs but that seems like a good test.
            • frankusb
              • Apr 2015
              • 111
              I thought I attached the schematic for this but I don't see it.
              • redwire
                • Dec 2010
                • 3907
                Need to narrow down where the problem is. Is the popping occuring in all channels? Might have to disable the protection DC detect.
                Wild guess, there is a problem with the muting circuit or the audio switching circuit.
                Or it could be a power amp channel but you can measure the DC offset (must be upstream of prot relay) and see if a channel is sick. Headphones are after the relay so not useful I think.
                The "multi-channel" outputs/inputs could be checked if they are OK. I don't have time right now to give a detailed strategy.
                Try have fun and play around with it, look for anything.
                • frankusb
                  • Apr 2015
                  • 111
                  No need to take any more time, I have items to research (for fun - it really is just fun, I have no use for this receiver but it's a shame to see it thrown away). Thank you for your time thus far.
                  Protect is currently disabled altogether, all types. So I believe I can measure after the protection relays (RLC are hard to get to before the relay with the heat sink) if I enable 5 channel stereo mode.
                  I too agree with muting or audio switching. I believe after some more data collection, that is where I will focus, trying to remove those from the protect circuit and see what protects I can leave enabled.
                  • frankusb
                    • Apr 2015
                    • 111
                    In 5 channel stereo mode, CD input, warmed up:
                    FL: -10mV
                    FR: -2mV
                    C: -1mV
                    SL: 0mV
                    SR: -10mV
                    • frankusb
                      • Apr 2015
                      • 111
                      I-Pro has 5 transistors, Q527, Q528, Q627, Q628 and Q1514. V-Pro has 5 resistors, R1528, R658, R657, R553 and R554. The V-Pro resistors feed into Q582/Q581. The output of Q582/Q581 then feeds along with the output of the I-Pro transistor into Q583 which is the Protect signal.
                      I assume I-Pro is current protect and V-Pro is DC detect?
                      • frankusb
                        • Apr 2015
                        • 111
                        Switching inputs does not make any noticeable sound on the FR and FL speakers. All inputs tested. Only the FR and FL speakers are connected for all tests (A speakers).
                        The only popping on the FR and FL speakers is heard when the A speakers are enabled and the B speakers are turned on or off. The pop when turning on the B speakers is not a lot. The pop when turning off the B speakers sounds like something you would want to avoid.
                        If I turn the A speakers off and on, the speakers do not pop. If I turn the A speakers off, then turn the B speaker on and then off, then turn the A speakers on, they will pop. Followed by a pop when turning off the A speakers. Subsequent on/off cycles do not pop unless I involve the B speakers.
                        • redwire
                          • Dec 2010
                          • 3907
                          V-PRO should be called V-PROTECT, it's a summation of the outputs of all channels with low pass filter C581. It needs around 1VDC seen to trip.
                          I-PRO should be called /I-PROTECT, it goes low if any power amp sees over-current OR V-PRO is asserted. They get tied together.
                          It can be perfectly normal for the amp to thump and activate the protection circuit, if there are big thumps coming into the amplifiers.
                          Your idle DC offsets look reasonable. It needs to be several volts for many 100's milliseconds before the DC detect gets activated.
                          • frankusb
                            • Apr 2015
                            • 111
                            I've got some data that I don't understand. I disconnected JL501B (+24V, I-PRO, V-PRO, REM_EN, GND and SUR_EN) from the surround/remote amp board hoping to isolate the source of the protect between the two amplifier boards, and it half worked. The protect is no longer being triggered by switching between inputs (DVD, VIDEO 1, 2, etc). But it still is being triggered by toggling Speaker B on and off (mostly off).
                            What could be causing the A speakers to pop (and trigger protect) just by toggling the B speakers?
                            • frankusb
                              • Apr 2015
                              • 111
                              I'm guessing FMUT to NCVD-6566 is where I should be looking.
                              • redwire
                                • Dec 2010
                                • 3907
                                I think JL501 goes to just include the surround channels in the protection circuit. The front channels are always hardwired to PROTECT (which is the summation of all channels V-PRO and I-PRO) by Q583.
                                I can't find the Speaker A/B switch on the schematic.
                                If the MCU activates MUTE while switching the A/B relays? then it looks like the muting circuit is making thumps.
                                If it's just a plain speaker switch, then that looks a front power amp channel has DC offset.
                                • frankusb
                                  • Apr 2015
                                  • 111
                                  It also includes the relay controls.
                                  It's in the switch array in NADIS-6576. 3rd row, 3rd column.
                                  I think it does activate MUTE while switching B on or off. I am suspecting either MUTE or whatever switches between surround and remote speaker input signals. I will look at this tonight.
                                  • frankusb
                                    • Apr 2015
                                    • 111
                                    I think I found a problem responsible for the B speaker popping. It's only on the left channel. What's happening is when enabling the B speakers, I believe the output of Q3383 is sitting at -2.0V. So the output of Q3181 gradually drifts down to -2.0V. Then when disabling the B speaker, it pops back up to around 0V.
                                    I measured the output of Q3483 to compare and it's sitting at 0V.
                                    This is on NCVD-6566. I disconnected P601 so it's not connected to anything.
                                    • frankusb
                                      • Apr 2015
                                      • 111
                                      If anyone can suggest a replacement part for a Toshiba RN1241 I would appreciate it.
                                      • frankusb
                                        • Apr 2015
                                        • 111
                                        Would you trust this?
                                        • redwire
                                          • Dec 2010
                                          • 3907
                                          I don't know, it looks like a reasonable store 98.5% feedback. You can swap the muting transistor with another from an unimportant section to confirm it is the problem.
                                          The RN1241 has an internal 5.6kΩ base resistor so it would not test the usual E-B junction 0.7V
                                          • jjne
                                            Bad DC offset on Onkyo TX NR414 - doesn't appear to be in the analogue section
                                            by jjne
                                            I have a TX NR414, well I have two actually which are both exhibiting the same issue.
                                            The one I've had since 2012 developed DC offset of around a volt under load on the front right speaker output. Not enough to trip the protection but enough to be noticeable in terms of sound quality. I checked the preamp board and couldnt see anything obvious. The offset is too high really to be a drift issue right?
                                            I put the amplifier away for a while. I managed to pick up another example with a dead HDMI board very cheaply (common on these - mine was replaced by Onkyo several years...
                                            07-28-2025, 07:51 AM
                                          • MegaZAC
                                            Onkyo TX-SR805 noise in one channel
                                            by MegaZAC
                                            Surprisingly enough, this receiver doesn't have the DSP chip issue. The HDMI board does not get hot, and sound over HDMI works fine.
                                            Regardless of the input, the right channel has noise that is clearly noticeable even on average volume level. The only cases when there's no noise is when VCR input is selected (some tracks on the board are damaged, maybe that's why), or if HDMI input is selected but nothing plugged into it. In all other cases, even when no input is connected I still have the noise.
                                            There's some logic behind it. As soon as I select an input I get only left...
                                            04-23-2025, 10:09 PM
                                          • eccerr0r
                                            old X58 triple channel board... memtest86 memory speed?
                                            by eccerr0r
                                            Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
                                            Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
                                            Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
                                            06-28-2025, 09:06 AM
                                          • spleenharvester
                                            Reverse engineering of 18650 4-channel tester
                                            by spleenharvester
                                            Hi friends
                                            I have reverse engineered this tester, schematic is attached and is complete except for capacitor values. These testers annoyingly have no model number but they are the ones you find on the first page of just about any website if you type in "18650 4-channel tester". There is also a 2-channel variant and a newer 8-channel variant. They are very cheap (about £15) and can measure voltage, current, internal resistance and capacity. They have a multicolour display for all these statistics. They also have terminal blocks so that if you want to use a breakout board...
                                            05-04-2025, 02:43 AM
                                          • dicky96
                                            American Audio VLP1500 Distorting on one channel
                                            by dicky96
                                            Hi guys I have a VLP1500 amplifier here - one channels works fine and the other channel distorts even at low volume settings
                                            Protection and Clip LED are off
                                            There is something wrong with the BIAS voltages around T16 and T18 (in particular) on the bad channel
                                            I tested all diodes and transistors in this area in circuit with diode mode - both channels seem identical. Same in resistance mode across all the resistors here.
                                            The output DC voltages on pin1 and pin8 of the 5532D dual op amp at the input of each amplifier module are the same, and the audio...
                                            07-13-2022, 05:25 AM
