Junsun V1 pro 2 Android Auto Radio component identification
  • seb68
    • Apr 2019
    • 44
    • France
    Can anyone identify this two component?
    Marking : S87Cd41
    Click image for larger version  Name:	2024_0322_220118_001.jpg Views:	3 Size:	4.42 MB ID:	3240617
    Marking : B2F53S
    Click image for larger version  Name:	2024_0322_220413_002.jpg Views:	3 Size:	4.43 MB ID:	3240618
    Click image for larger version  Name:	2024_0322_220440_003.jpg Views:	2 Size:	5.56 MB ID:	3240622
  • truclacicr
    • Apr 2019
    • 352
    • australia
    S87 = STI9287
    https://datasheet.lcsc.com/lcsc/2009...87_C842664.pdf (datasheet)
    https://www.taobao.com/list/item/744174915443.htm (photo)
    • harp
      • Jun 2022
      • 643
      • Planet Earth
      Maybe this, check pinout against datasheet
      • truclacicr
        • Apr 2019
        • 352
        • australia
        Is B2F the Vdd supply for the SoC (CMS8S6990)?
        https://www.semiee.com/file2/b200ba7...9xx_V1.0.6.pdf
          • 31259
          why 2 blown? do they feed each other?
          reverse polarity mistake?
          shorted ceramic caps?
          • seb68
            • Apr 2019
            • 44
            • France
            For Member Harp and Trucglacier : it's the good component.
            The B2F: Not the VDD supply for the SoC CMS8S6990.
            For Member stj : The guy who brought me this GPS had wired it wrong. No shorted ceramic caps.
            • truclacicr
              • Apr 2019
              • 352
              • australia
              I would be concerned as to whether Vin has punched through the ICs and clobbered the loads. To this end I would measure the resistance between Vout and ground, and between Vin and Vout.
              • seb68
                • Apr 2019
                • 44
                • France
                I removed the component B2F53S and the values are good between Vin and Vout and GND.
                As this component is not identified I cannot go any further with the repair.
                • truclacicr
                  • Apr 2019
                  • 352
                  • australia
                  Can you determine the pinout?
                  It might also help to measure the feedback resistors, as this could tell us the FB reference voltage. Common examples are 0.6V and 0.8V.
                  It would also help to know which chips are powered by this IC, as that might tell us the output voltage.
                  Lastly, it might be worth identifying the manufacturers of other ICs, in case the designer used the same IC maker.
                  • truclacicr
                    • Apr 2019
                    • 352
                    • australia
                    B2F5dc = MT3540-F25
                    https://www.lcsc.com/datasheet/lcsc_...25_C883495.pdf (datasheet)
                    https://pl.aliexpress.com/item/10050...yAdapt=glo2pol (photo of MT3540-F25)
                    https://aliexpress.ru/popular/mt3540.html (photo of MT3540-F23)​
                    • seb68
                      • Apr 2019
                      • 44
                      • France
                      Click image for larger version  Name:	2.jpg Views:	0 Size:	4.90 MB ID:	3241273 Click image for larger version  Name:	1.jpg Views:	0 Size:	4.23 MB ID:	3241272
                      Thank's truclacier for your comment, this help me.
                      • seb68
                        • Apr 2019
                        • 44
                        • France
                        Hello, The car radio is repaired and work's fine, thanks to the members who took time to identify the components.
                        Click image for larger version  Name:	20240406_194259.jpg Views:	0 Size:	7.36 MB ID:	3248761
