monitor active sub- instantly blows output transistors
  • rievax_60
    • May 2012
    • 897
    • australia
    Re: monitor active sub- instantly blows output transistors
    Originally posted by onejay09
    no its just Q510 and Q511, i cleaned this one up and the corrosion stripped it back to copper, maybe their toast, anyway ordered some new ones off ebay, how do i go about using a 75watt bulb in series with the power lead?
    A 75w bulb in series with the mains is not certain to save the output transistors if a problem is missed.
    I think its best to do some tests before the output transistors are fitted like I mentioned before.
    You can still do the tests if Q508 and Q509 are ok.
    • onejay09
      • Nov 2011
      • 67
      Ok is it safe to test withlit the board connected to the plate with the transformer ground wise or should I run a wire to ground the board?
      • onejay09
        • Nov 2011
        • 67
        voltage at r519 is 44.2v voltage at r520 is 45.2v
        diode mode
        q507 vbe mpsa13
        1+/2- ol
        1+/3- ol
        2+/3- 771
        3+/2- ol
        3+/1- ol
        2+/1- 1.737
        q508 c3328
        1+/2- .650
        1+/3- .653
        2+/3- .ol
        3+/2- .615
        3+/1- .ol
        2+/1- .ol
        q509 a1275
        1+/2- .ol
        1+/3- .ol
        2+/3- .703
        3+/2- .ol
        3+/1- .635
        2+/1- .641
        anything strange?
        • onejay09
          • Nov 2011
          • 67
          diode mode
          q507 vbe mpsa13
          1+/2- ol
          1+/3- ol
          2+/3- 771
          3+/2- ol
          3+/1- ol
          2+/1- 1.737
          q508 c3328
          1+/2- .650
          1+/3- .653
          2+/3- .ol
          3+/2- .615
          3+/1- .ol
          2+/1- .ol
          q509 a1275
          1+/2- .ol
          1+/3- .ol
          2+/3- .703
          3+/2- .ol
          3+/1- .635
          2+/1- .641
          anything strange?
          • rievax_60
            • May 2012
            • 897
            • australia
            Those transistor readings look ok.
            With Q10 and Q11 removed, I should have asked you to take voltage measurements at R516 and R517.
            There should have been no voltage readings at R519 and R520 with the output transistor removed and Q10 and Q11 removed.
            • onejay09
              • Nov 2011
              • 67
              #26
              Oh forgot to say that I put q510 q511 back in to test before and after I replace them, now last time I replaced the output transistors I couldn't find tip36cw or tip35c and used tip35c tip36c without the w. What's the difference?
              R519 r520 was measured to negative at the rectifier
              • onejay09
                • Nov 2011
                • 67
                #27
                Ok so weird results measuring across r519 and r520
                R519 ranging from 0.6to 1.7 volts fluctuating up and down
                R520 ranging from 0volts to 0.5, if I measure from soldered side I dont get a reading!
                • rievax_60
                  • May 2012
                  • 897
                  • australia
                  #28
                  Its all getting a bit hard for me to follow now, too many variables.
                  Even if Q10 and Q11 diode test ok, I wouldnt trust them unless any possible surface tracking is cleaned from between the legs. I use a small hacksaw blade.
                  Have you tested R519 and R520?
                  voltage measurements are usually taken with respect the 0v/ground/chassis unless there is a reason to use another reference.
                  I cant see a difference yet between the TIP36C and TIP36CW.
                  • onejay09
                    • Nov 2011
                    • 67
                    #29
                    lol sorry, from now on ill reference to ground, my new parts came in today so gunna replace q508 q509 q510 q511, ill leave tip 35 36 out for now, so im thinking that the bias current or voltage is too high, how do i measure for that?
                    • kaboom
                      "Oh, Grouchy!"
                      • Jan 2011
                      • 2507
                      Use the center point of the two large electros in the power supply for your common reference. If the board is removed from the chassis, any bonding link is broken. Therefore, hooking the negative meter lead to the chassis will give meaningless results.
                      With the two finals out, what's the voltage from the output bus, before the spkr relay, to common? Test point is the junction of R516 and R517.
                      Normally, bias current is measured as a voltage across the emitter resistors of the finals, then calculated by Ohm's law.
                      Ex- 0.02V / .22ohms = ~91mA.
                      Don't worry about this now- there are other major problems for now...
                      Unstable bias, and possibly offset. Those output devices are being "told" to conduct when they're not supposed to.
                      Flux or dirt on the board?
                      Make sure all resistors and solder joints for the dual-differential (Q501-Q504) are good. Heck, redo them anyway.
                      You've got funny readings on both sides (R519 and R520) so the dual-diff is my first suspect.
                      Also, check the two 47 ohm (fusible?) resistors, R512 and R515, for cracked solder.
                      If the dominant-pole caps, C505 and 507, intermittently break down, the whole amp will become upset.
                      "pokemon go... to hell!"
                      EOL it...
                      All style and no substance.
                      guilty,guilty,guilty,guilty!
                      guilty of being cheap-made!
                      • rievax_60
                        • May 2012
                        • 897
                        • australia
                        #31
                        Is there any sign of yellow/brown glue used on the PCBs? It causes corrosion.
                        • kaboom
                          "Oh, Grouchy!"
                          • Jan 2011
                          • 2507
                          Ahh, I should've mentioned something about that black (rubberized?) stuff they've got on the board. Sometimes, solder joints can crack, yet the component won't wiggle readily, since it's being held by the glue.
                          It's probably there to keep vibrations from loosening the components. I think that may already have happened, though.
                          http://postimg.org/gallery/91qn1hge/05afb988/
                          Onejay, where are you located? How about Mouser or Digikey for parts? Especially semis, as Rod explains here:
                          http://sound.westhost.com/counterfeit.htm
                          Ok- it seems like that's another one of those "Federal" transformers. Whoever makes these amps has their TXs labeled as such. If it's anything like a similar amp I rebuilt a few years ago, I would definately consider resoldering everything. As well as paralleling output devices- there's room for them after all...
                          EOL it...
                          • rievax_60
                            • May 2012
                            • 897
                            • australia
                            #33
                            The voltages at R519 and R520 needs to be very stable and precise but I cant say exactly what.
                            R519 should be about +0.5v, R520 should be about -0.5v. Its actually the difference voltage, about 1v that is important. It is supposed to be just enough to cause the output transistors to be turned on by a very small amount so they pass a few milliamps of idle current.
                            Confirm that R529 and R520 test ok.
                            Voltage measurements taken from a good channel are useful when in doubt.
                            • rievax_60
                              • May 2012
                              • 897
                              • australia
                              #34
                              That is right. I had forgotten about the black glue. Its just as damaging as the yellow/brown stuff. I still see it in recently made products, mainly on outsourced power and BL inverter PCBs.
                              • onejay09
                                • Nov 2011
                                • 67
                                #35
                                Hey guys, well thanks to all of your advice I have a working active subwoofer again, I replaced q507 and q508 through q511, checked for the strange fluctuating voltages I had on r519 r520 they were completely gone, so I built a light bulb in series with the ac cord and risked my new output transistors, soldered them in, closed my eyes fingers crossed and flipped the switch, fuse didn't blow, the bulbs flashed then went out, yess! Left it for 5 mins, I touched the heatsink it was warm! So i put it back together and tested it carefully, F YEA! works like new, thanks folks much appreciated!
                                I'm from UK, I'm sure I could use mouser or digikey but maybe not the fastest option, I'd try element14 think they've got a UK based sector, I agree that eBay is full of fakes and not ideal :-)
                                It must have been q508 2sd667 and q511 2sb647 the corroded pins were covered in that black rubbery glue, all over the wirewound resistors where the bad trans were, the heat must've been too much, I couldn't see the corrosion untill I got rid of the glue and removed the trans.
                                Yea I couldn't identify the transformer except the output voltage, even the schematic didn't say what the values were
                                Well this time I bought the output transistors as a matched pair, so it's working well
                                I also spent the night recapping the rest of the board, the small electrolytics all except 2
                                Anyway thanks guys happy with the result
                                • rievax_60
                                  • May 2012
                                  • 897
                                  • australia
                                  #36
                                  Happy to hear that.
                                  The idle current is calculated from the voltage measured across the two 0.22 ohm resistors in series.
                                  There is no need to risk taking this measurement if the heatsink feels only warm after the amp has idled for 15 minutes or so. And the audio sounds ok at very low volume, no cossover distortion.
                                  • onejay09
                                    • Nov 2011
                                    • 67
                                    #37
                                    Yes it seems to be working perfectly :-) playing on high volume doesn't heat it up too much either, I'm quite surprised that it doesnt get hot to touch
                                    • Manuel Castellano
                                      • Jan 2014
                                      • EspaƱa
                                      #38
                                      Hello everybody.
                                      I moved my Home Teather system with the VW8 included. (6 speakers). I installed everything in the new house and turn off everything. When I came backe the subwoofer never turned on again. No any red led on. I opened it an checked that the power is not getting out the transforemer. Could anybody helpe me with this?. Does anybody (onejay09) have the transformers spec to replace it?. Any advice?. Tks a lot in advanded. Regards.
                                      • keepread
                                        Dell monitor PSU vs Dell laptop PSU
                                        by keepread
                                        Hi there!
                                        Someone gave me their old monitor, it's Dell S2715ht.
                                        The owner was using it when his PSU began to smell and then to smoke. It literally began to melt. He turned the monitor off, pulled the PSU, and ditched it because it was smelly even after it cooled. So I got the monitor but not the plug.
                                        Now, I tried to bring the monitor back to life, by plugging one of my many Dell laptop PSUs. They are of the same 19.5V, and the wattage of the laptop PSU is higher than that which the monitor is rated for. Visually, the socket on the monitor seems compatible, and the plug plugs...
                                        10-30-2025, 04:45 PM
                                      • FrancescoV
                                        Onkyo HT-R390 no sound output, video output ok
                                        by FrancescoV
                                        Good morning everyone,
                                        I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
                                        The firmware reported is the following:
                                        M:1.00/11107BLP
                                        D:?.??/????????
                                        O:1.00/11107AL
                                        The DSP firmware given the question marks seems corrupt.
                                        On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
                                        05-11-2025, 02:59 AM
                                      • bauto601
                                        KDM 480W PSU upgrade succes! (opinions?)
                                        by bauto601
                                        Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
                                        A "nice" YoungYear unit? - Badcaps
                                        The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
                                        12-26-2023, 03:05 PM
                                      • wattage
                                        AOC AG493UCX 49-inch monitor - Firmware request
                                        by wattage
                                        Hello Badcaps Community,
                                        The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
                                        07-13-2025, 04:41 PM
                                      • ant3202
                                        HP 27es - LED monitor - Monitor Flashing On - Off
                                        by ant3202
                                        Hi Everyone
                                        Lately I am experiencing the deja-vu incident on one of the led monitor like this.
                                        https://www.badcaps.net/forum/troubl...lashing-on-off
                                        The monitor is HP 27es LED Monitor
                                        https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
                                        The monitor will randomly blackout and display no signal and will recover again.
                                        Sometimes need to power and off again to restore the display but...
                                        03-20-2025, 07:30 PM
