Roland HP-1 Electric Organ/Keyboard audio output noise
  • notallbad
    • Oct 2012
    • 1190
    Happy to get pictures up of the boards and shall do in due course.
    Everything works as it should as far as I can tell.
    But on the built-in speakers and the headphone jack output is a regular occurring whoosh noise which is proportionate to the volume control, so the louder you turn up the volume the louder the whoosh noise gets, though it is not particularly loud just obviously present and annoying and occurs immediately after switching on.
    Hopefully someone can assist with this and I would be extremely grateful.
  • ben7
    Capaholic
    • Jan 2011
    • 4059
    Re: Roland HP-1 Electric Organ/Keyboard audio output noise
    Sounds like something oscillates as the power source is turned on. Maybe a bad/dry capacitor, or a bad voltage regulator?
    Muh-soggy-knee
    • notallbad
      • Oct 2012
      • 1190
      OK, thanks.
      If I get some photos up would you be able to direct me where and what to check?
      Just to be clear I should state that it occurs constantly from powering up and at regular intervals every 3-4 secs. Also it does not effect the acoustics, it plays music fine. If this helps to narrow it down.
      Thank-you
      • notallbad
        • Oct 2012
        • 1190
        Photos as promised.
        • notallbad
          • Oct 2012
          • 1190
          Another
          • notallbad
            • Oct 2012
            • 1190
            And lastly.
            • notallbad
              • Oct 2012
              • 1190
              CORRECTION:
              The sound is definately coming through the speakers and 'plays' over and over again without a break, the sound is just like an old LP playing on a gramophone when it gets to the end of a record, you'll know if your old enough to remember like me, when the needle is at the middle of the LP and keeps turning with no more to play. And at the end of this annoying noise is like a click noise.
              Also just to note, there are no external devices connected, i.e. pedals, speakers, amps etc...
              • notallbad
                • Oct 2012
                • 1190
                Zipped Audio file
                • rhomanski
                  nowhere man
                  • 5157
                  • U S of A
                  78, 45, or 33 1/3?
                  Sounds like a transistor going out. It may start motorboating soon. When it goes budda, budda, budda, budda. It'll be close to the output transistors, maybe one of the drivers? You should be able find it with a scope.
                  sigpicThe Sky Is Falling
                  • notallbad
                    • Oct 2012
                    • 1190
                    Maybe I'm not that old, I remember my grandad playing those really thick plastic LP's on his wind up gramophone, happy memories.
                    Thanks for your response.
                    Budha, budha, budha might sound a little better, has a good beat to it!
                    Sorry, I'm not musically gifted or knowledgeable so probably wrong terminology to use.
                    How would I connect a scope to check?
                    Thanks again.
                      "Just to be clear I should state that it occurs constantly from powering up" But if you have the volume pot all the way down, do you still hear the noise. If not, then it is from something before the volume control. Does this thing has the TREMOLO/VIBRATO effect, or any effects settings are turn on?
                      • notallbad
                        • Oct 2012
                        • 1190
                        Hi Budm, thanks
                        With volume control all the way down I can not hear it!
                        Not sure about those settings, vibrato etc... shall have to look into it.
                        • notallbad
                          • Oct 2012
                          • 1190
                          It has a Reverb setting, gives the impression that you are performing in a concert hall or similar space, which does work, it can be toggled on and off.
                          It also has the facility to set the reverb volume level, which also works and changing the reverb volume level has the effect of making the annoying noise louder with the setting high and quieter with the setting low.
                          The other facilities/options that I have played with all appear to be working but do not make any effect to the annoying noise.
                          • notallbad
                            • Oct 2012
                            • 1190
                            Not sure if this also backs your theory but looking at the service manual there is a test procedure to follow and one of them is 'Panpot Check', in this test there is a 'Sound Off' option, not sure exactly what it does perhaps simply a mute but the annoying noise is still there and pressing the keyboard keys gives no sounds, so this could back what you say.
                              upload the service manual so I can look at it.
                              • notallbad
                                • Oct 2012
                                • 1190
                                Thanks Budm
                                The manual covers 2 models HP-1 and HP-2e
                                Had to zip it due to its size I'm afraid.
                                • notallbad
                                  • Oct 2012
                                  • 1190
                                  Is there any way of connecting an external speaker in-circuit to eliminate at which stage this noise is being generated? Just a thought.
                                  • notallbad
                                    • Oct 2012
                                    • 1190
                                    I have disconnected the keyboard (connectors CN5 and CN6) from the main board and the fault still persists. I thought perhaps it was a key issue but obviously not so thats eliminated the keyboard.
                                    • notallbad
                                      • Oct 2012
                                      • 1190
                                      Just to see I'm going to disconnect the headphone jacks, there are 2 of them, at the amp/power board side. I doubt this is causing the fault but worth a try to eliminate.
                                      I did read somewhere in my travels someone had a curious sound issue and had something to do with the headphone jack.
                                      • notallbad
                                        • Oct 2012
                                        • 1190
                                        Well that proved pointless as I'm sure 'you' already knew but have now satisfied my own curiosity.
                                        • tony359
                                          by tony359
                                          11-28-2023, 05:18 AM
                                        • MegaZAC
                                          Onkyo TX-SR805 noise in one channel
                                          by MegaZAC
                                          Surprisingly enough, this receiver doesn't have the DSP chip issue. The HDMI board does not get hot, and sound over HDMI works fine.
                                          Regardless of the input, the right channel has noise that is clearly noticeable even on average volume level. The only cases when there's no noise is when VCR input is selected (some tracks on the board are damaged, maybe that's why), or if HDMI input is selected but nothing plugged into it. In all other cases, even when no input is connected I still have the noise.
                                          There's some logic behind it. As soon as I select an input I get only left...
                                          04-23-2025, 10:09 PM
                                        • courtcircuit
                                          Philips HTS8000 home cinema noise problem
                                          by courtcircuit
                                          Hello
                                          I have since a long time a Philips HTS8010S/01 which has been old but was doing the job.
                                          Since a few days, it starts by making a weird "static" nois when switches on for a few seconds to a minute and then works like a charm.
                                          Noise loudly outputs from the 3 channels, even if no signal is sent by the controler.DVD to the subwoofer/amp unit.
                                          I was thinking of a soldering that was starting to be damaged and that was only doing the job after a few seconds of heating, most probbaly on the power board
                                          Removed each of tyhe boards
                                          02-08-2025, 08:22 AM
                                        • Dannyx
                                          Electric piano distorted notes (Roland RD100)
                                          by Dannyx
                                          Good day folks. Today, I came across something kinda special, which I haven't worked on before: a Roland RD100 electric piano. It was just sitting there in the shop covered in dust, no doubt having been ravaged and then abandoned by my oh-so-skilled co-worker. I actually remember seeing him struggling with this thing and I recall briefly witnessing the problem too: some of the notes play distorted. I'll try plugging it myself and maybe do some captures for you to hear for yourselves, but let's just say it sounds....bad.
                                          I haven't actually dug into it myself yet, so this is mostly...
                                          03-29-2021, 02:08 PM
                                        • roadrash
                                          Old PC PSU making noise etc
                                          by roadrash
                                          A vintage 1980's PC power supply has started making a hissing and whining/squealing noise and the PC is now giving random errors like memory and video etc. Ive tried the PSU with just the Motherboard plugged in and its quiet but soon as I increase the load adding controller interface cards and drives etc, the noise starts. I think there is something about to fail but cannot see anything like a bulging cap or anything. Does anyone know whats the most likely suspect component? Here is a link to a video i took....
                                          11-18-2025, 09:02 AM
