Weird amp problem
  • DJduck
    • Dec 2012
    • 229
    • Estonia
    Weird amp problem
    Hey, I recently built an amplifier based on the AN7125 chip. I used the sample schematic included in the datasheet. I built it inside an old power supply case and it worked fine. Now I built a new case for it and had to take it apart, to put it into the new case. I put it all together and powered it up. There is no sound in either of the channels. Once I turn it off from the mains power switch and the voltage drops to 0v, the sound comes on for about half a second. I measured voltages on the transformer: the main supply coil reads 14v and the 5v coil reads 4v, -35v coil reads -35v (not used). Voltages seem fine after bridge rectifiers. I have no idea what the problem could be, it seems to turn on only for a moment when the voltages drop down before going to 0v. Ideas?
    Datashit: http://www.alldatasheet.com/datashee...IC/AN7125.html
    I can put text here?!
  • Mrx3750
    • Jul 2013
    • 311
    Re: Weird amp problem
    IC could be shutting off at higher voltages for some reason. Can you reduce the voltage going into it by half and see if it does anything?
    • DJduck
      • Dec 2012
      • 229
      • Estonia
      I don't think that this is the case, since I used the same transformer before, and it is reading 14v but the maximum for the IC is 24v
      • DJduck
        • Dec 2012
        • 229
        • Estonia
        All the components in my amp are the exact ones in the diagram, except for the main power filter cap, mine is a 25v 6800uf Rubycon if I remember correctly, and the two other caps are Nichicon and Panasonic.
        • Mrx3750
          • Jul 2013
          • 311
          Only other suggestion is to recheck all your components. Also check your case to see if it's grounding anywhere it shouldn't. Herd of that issue on a PC motherboard, worked fine in one case, went berserk in another. Turned out it was making ground contact where it shouldn't have.
            According to the spec: :Operating voltage range 6 V ∼ 18 V (12 V typ.)" max input is 24V, STBY pin is 5V.
            14V transformer will put out about 19V, 5V winding will be about 6V. You may want to check the MUTE pin 9 and STBY pin5 voltages.
            • DJduck
              • Dec 2012
              • 229
              • Estonia
              I think I know. Before i used 4 diodes with low voltage drop to convert 5V for standby. Now i use a bridge rectifier and it drops the standby voltage down from 5V to about 3.9V or so. So the standby off 5V is not getting enough power and is not turning off from standby. But since I do not want to go back to 4 diodes, I'm going to put a 7805 after the rectifier to pump the voltage back up to 5V. But i can't do it now, since my shitty soldering iron died and i have to get a new one. Probably another cheapo one, since i am poor as fuck and can't even afford 40€ pair of speakers
              • lti
                • May 2011
                • 2545
                A 7805 won't increase voltage. It can only drop a higher input voltage to 5V. The minimum input voltage is around 6.7V.
                  The standby pin only draws about 100uA (worst case, 5V feeding 51K resistor), very very small, you can easily use the resistors voltage divider and cap and Zener Diode. to drop the main power supply, or use half-wave rectifier from the 5V winding. That 5V winding should not drop down to 3.9V, 5V - 1.2V (Vf for 2 Diodes on each half cycle) = 3.8V, 3.8V x1.414 = 5.37VDC with only 100uA current draw.
                  • chaos-theory
                    Nitro rx580 very weird problem, VCORE and EN
                    by chaos-theory
                    Hello!
                    I have this very weird problem, I got this rx580 nitro saphire and the fans don't even spin but the saphire logo is lit.
                    All voltage rails are present except for VCORE at the coils, then I started checking NCP81022 and it has voltage but vdd pwrgd is missing, enable EN is missing it shows 2.5ohm, everything seems fine, i tried checking the back of the card, to see where the enable pin goes, i dont have a schematic so i started touching randomly until i measured a resistor on the back and the fans started spinning, now I was amazed like what is wrong here? So I thought it's a...
                    08-17-2024, 04:56 PM
                  • sorrowfulfloyd
                    Samsung UE32J5373AS Weird LED Problem
                    by sorrowfulfloyd
                    Hi all, first time seeing a LED problem this weird so I wanted to discuss with y'all before handing back this TV to my costumer.
                    This TV came to my shop with no picture but sound present. So I thought ok this must be a LED problem and I shine a light with my phone's torch amd and yup I see the image. So I disassemble it and before changing the LEDs I check the motherboard voltages (this unit works with an external 16V DC brick) and I see 54 volts at the input pin of LED strip, considering this TV has 2 strips of 7 LEDs which at 3~ volts it must be equal to like 42 volts. I remove...
                    12-23-2022, 07:00 AM
                  • brockauly
                    Macbook M1 A2337 EMC 3598 weird battery charging problem
                    by brockauly
                    Hi guys,
                    If I unplugged the battery and the charger, then plug the battery then the charger, it charges without problem.
                    Then if I unplug the charger and plug it back, it won't charge anymore.
                    In the first case, main voltage is regulated at ~12.5V and charges the battery.
                    After unplugging the charger, main voltage drops to battery voltage at ~11.5V.
                    After replugging the charger, main voltage stays at ~11.5V and won't go up to ~12.5V again.
                    I found C520A (2.2µ after current sensor from USB-C source) completely burnt and removed it properly. I cleaned...
                    02-05-2025, 10:51 AM
                  • wnt2fx
                    a1398 2015 weird keyboard problem
                    by wnt2fx
                    I installed a new keyboard and it can smc reset and the power button works. but nothing apart. no boot picker e.g. I am wondering how this can be explained if the alt key (smc reset) is working. I am aware that on the board side shift, ctrl, alt and pwr are separately wired but the board, trackpad/cable are good. The keyboard was tested working prior installing and as another keyboard now tested on the same board improvised works as well the only idea I have is that I damaged the keyboard flex cable while installing it into the case. But why hell smc reset and power are working then ? Anyone has...
                    04-27-2025, 08:41 AM
                  • VikramB
                    Samsung QN55LS03 | The Frame TV | Weird power cycle and restart problem
                    by VikramB
                    First thread here on this forum, excuse me if I miss something in my first post.
                    I have the 55” variant of the Frame TV which is essentially a QLED tv. There's a weird problem where it would keep on restarting on its own. Funny thing is it might work perfectly for couple of days and then decides to go down the restart route. A few pointers:
                    1. If I let the TV sit idle for a day, for the very first time it boots after that time period it usually keeps working for 5 minutes before restarting. After that it restarts every 5 seconds.
                    2. I've tried the tape method and...
                    03-17-2023, 02:56 PM
