Boss Audio amps - Which should I choose???
  • stevo1210
    • Oct 2006
    • 4156
    I'm currently re-doing my Jukebox for my living room which some of you are aware of. It's built off car audio stuff for those who aren't aware... if you want to see what it looks like, I had a thread on here about it somewhere.
    Anyway, I am being offered two amps by a friend for a very cheap price of $20 and $25 respectively. Both Boss audio brand and reason for sale is they are EOL at his store and he found these at the bottom of the stockpile... if I don't take them, then he will resell it on the discount table at his shop.
    Anyway... two "Boss audio" 4ch amps. Both 200W RMS (50W x 4). My power supply is a 12V 20A unit which is used for an industrial CNC controller so it's not a problem with the power here (All NCC caps!).
    Boss R1004
    - Frequency Response: 12 to 22000 Hz
    - Total Harmonic Distortion (THD) @ RMS Output: 0.01%
    - Signal-to-Noise Ratio (SNR): 90 dB
    - Minimum Speaker Impedance: 2 Ohms
    Boss CE404
    - Total Harmonic Distortion (THD) @ RMS Output: 0.05%
    - Signal-to-Noise Ratio (SNR): 95 dB
    The CE404 is $25 and the latter is $20. I don't know what these numbers mean... but which one is the better one by looking at those specs?
    Yes I am aware it's Boss audio, blah blah... but for $20-25 I can't say no!
  • mariushm
    • May 2011
    • 3799
    Re: Boss Audio amps - Which should I choose???
    What?!
    Both CE404 and R1004 are about 35$ new... you're drooling over a 10$ discount?
    ce404: http://www.amazon.com/Boss-Audio-CE4.../dp/B004S4XM18
    r1004: http://www.amazon.com/electronics/dp/B004S50ZDA
    They both suck, but if you'd hold me at gunpoint, I'd go with the r1004 simply because it's heavier and has lower thd (though with crappy speakers it doesn't matter)
    • stevo1210
      • Oct 2006
      • 4156
      Originally posted by mariushm
      What?!
      $35 if I was in the USA. Cheapest I could find here RRP is $75! I don't think No-Name China made amps even exist under the $50 price tag here.
      Using a 4CH amp to power my Nakamichi speakers. It'll be better than the head unit powering it... that's for sure. LOL. My head unit, a JVC KD-R206 has been powering these speakers for over a year now, no problems at all... but I guess it is time for an amp...
      • logic7
        • Sep 2009
        • 25
        I know this is an old thread, but I'm an old-school car audio salesman and installer.
        Boss = garbage.
        I wouldn't touch anything with the Boss name on it. We used to call their power ratings "ILS Ratings"
        If Lightning Strikes.
        The only good use for a Boss amp is paperweight or doorstop.
          Into 4 ohms (minimum typical you'd find in a home audio system) you'd be lucky to see 53W peak power, if you like listening to square waves. But if you listen to sine waves, like normal humans, reduce the rating by about half. At 12V, the ratings will be even lower, so you might get 36W/ch at 1% THD.
          Better solution: pick up a decent used stereo mains powered amp, you can get them for very little from most good-will/discount shops and often free on the internet as most people are throwing them out. You'll need two to get 4 channels, but they'll easily be able to do 60~150W/channel with nearly zero distortion in their operating power range. A 6 channel AVR will also work well, though some of the power ratings on those are a little more... dubious.
          Remember to double perceived loudness, you need to increase power by 10x. So 3.6W is half as loud as 36W into the same speaker (ignoring speaker/wiring losses, but it's generally accurate.)
            master hoarder
            • May 2008
            • 12175
            They are both more or less equivalent. I'd probably go with the R1004 since it has lower distortion (lower THD) as mariushm mentioned. But if you like the design of the CE404 better, then go with that. Either way, you probably won't notice much difference in the performance.
            I agree with the others, you can probably get a better deal for $20-25 if you look around. But if you don't want to deal with that, then this would be an okay deal. Grab one and let it rip . If you keep the music at a reasonable volume level, you probably won't notice much (if any) distortion.
            • Stephen
              A2991 Logic Board issue, 20volts 0 amps help!
              by Stephen
              Customer plugged in samsung monitor into the board and used it as a power supply, killed UG800 and UG400. I replaced those two with an exact donor board we had In stock and working, board pulls 5volts and then gets like 2.89 amps on the left side. The singular port is the port that failed. Used a perfectly working chips from donor (board was locked) Now I only get 5volts 0 amps on that power and then 20volts 0 amps on the two left side ports, I checked for DFU and nope nothing, computer not turning on. No shorts present anymore. I am confused as I used the exact components from an identical...
              09-10-2025, 03:16 PM
            • Stephen
              A2991 logic board issue, 20volts 0 amps help!
              by Stephen
              09-10-2025, 03:15 PM
            • Fisher8865
              MacBook Pro A1990 stuck at 5v .592 amps
              by Fisher8865
              Hi guys
              I have a MacBook Pro A1990 that takes 4.9 Volts and .592 to .615 amps on one port. The other port on the left side power cycles with about the same amount of volts an amps but quickly power cycles. The same thing happens on the other side but opposite. So on the left side the bottom port stays on and on the right side it's the top one. I think it is a CD3215 chip but I am not sure how to test it or where to get one. I have checked for voltage at ppbus_g3h and it has 12.6 V which is also on fuses f7000 and f7001 I checked pp1v2_s3 and it has 1.2 V then...
              05-30-2024, 07:36 PM
            • Stephen
              MacBook Air 13" A2179 2020. 5Volts .250 amps issue
              by Stephen
              Customer came in with shorted USB C chips, replaced and the chips are now responding beautifully HOWEVER, I am only getting 5Volts .25 amps (sometimes .243 amps) I see that the T2 chip is turning on, but I am not seeing any voltage at the SSD rails for example,
              PP5VG3S_EN is not present which would somewhat indicate a PMIC U7800 issue, but I checked the voltage on the PMIC and that is present and not shorted. I tested for PP5V_G3S and those rails are not present.
              ISL9240HI is present, I am also getting 12.30 volts at PPBUS_G3H so no shorts there. Both CD3217 chips were successfully...
              02-18-2025, 05:54 PM
            • bialag
              Lenovo ThinkPad E14 Gen 5 - Not Powering On - 3 Blinking Lights - 20 volts 0.224 amps
              by bialag
              I have a Lenovo here that does not want to power on. The motherboard appears to be clean, no sign of corrosion or obvious fried components. When plugged in, I see 3 blinking lights and then off. It would cycle the 3 blinking lights every 10 seconds or so as long as I have the adapter plugged in. Amp meter shows 20 volts, 0.224 amps, no fan spin, red light indicator near the charge port.
              Thermal camera shows a section of the motherboard that is warmer than the rest. It is near the connector labels JRTC1 (CMOS battery). Diode measurement to ground for pin 1 = OL,...
              03-25-2025, 05:56 PM
