Need help repairing an audio amp schematics included
  • johnnydiaz
    • Apr 2012
    • 52
    I'm trying to repair an audio amp which doesn't power up. I measured voltage at the br and got 123 volts. I measured voltage at the main caps and got 160volts. I noticed that r245 & r288 were getting very hot (I measured it at ~ 120 degrees fahrenheit). So I unsoldered one leg on each resistor and got the proper reading. What could be causing these resistors to heat up? Also what else should I test? I have included the schematic.
    Re: Need help repairing an audio amp schematics included
    R245 is in series with the 18V Linear regulator circuit Q28. This is not a good design due to trying to drop 380VDC down to 18V using resistor/transistor.
    Are you getting 18V and 380VDC at those two points? VDD?
    • johnnydiaz
      • Apr 2012
      • 52
      Budm,
      "Are you getting 18V and 380VDC at those two points? VDD?"
      Sorry but I'm a newbie. What two points?
      Johnny
      • newbiesat
        • Dec 2012
        • 25
        • usa
        Those 2 points that budm mention should be across the resistor R288 (100K/1W) in the schematic diagram, page 6.
        • johnnydiaz
          • Apr 2012
          • 52
          Since I'm new at this I'm not sure exactly what to do. So I will measure dc voltage. I should put my positive test lead on r288 18volts and where should I put the negative? Same positive test lead on R288 380volts and where does the negative go? Sorry for the newbie question just want to confirm since its high voltage.
          • redwire
            • 3910
            First, take some measurements on the PSU primary side. Be careful of the high voltage and the fact that the caps (for VDC) can hold a charge even when things are unplugged.
            You would put your multimeter lead (-) on (primary) circuit common somewhere convenient, like the (-) terminal on D40/C190/C192 etc. The schematic shows this as a ground symbol, but it's not really.
            Then write down the DC voltage readings on:
            18V should be around 18V.
            VDC should be around 380V.
            VDD should be around 19V.
            The power supply has two parts and a bit tricky. It looks like start-up voltage (VDD 18-25V) is first provided by Q28, then U36 starts up and generates VDD. Same for 18V, start-up power is from R288, and again U36 circuit then powers the 18V from VDD.
            If R245 and R288 are cooking, I'd guess the PSU is not starting up.
            Then you would snoop around U36 to see why it's not running.
            • johnnydiaz
              • Apr 2012
              • 52
              Ok so I understand the the negative terminal part. I'm confused about the 18v, 380v & 19v? Do I put the red test lead on one of the leads on the resistor r288 to test the 18v? Im looking at the actual board and the page 6 of the schematics and am confused.
              • redwire
                • 3910
                Johnny, if you don't have experience making voltage measurements then I suggest kinda not doing the repair. The voltage is high enough to kill, and even slipping with the probe tip can cause a big boom. Your multimeter and its probes must be good quality too. Just something to ask yourself, because there's a risk and learning on this power amp there is no room for mistakes.
                The measurements are made on any component that connects to the signal/power feed of interest as shown on the schematic. As long as you have the correct side i.e. only one side of R288 is the 18V. You have to look around and follow the traces, or just find another part on the 18V rail. If a point is too hard to get to, go to any other part on that rail to make your measurement.
                I use an alligator clip (well insulated!) connecting the meter (-) to common, so I just have to hunt around/hold only one probe (+).
                • johnnydiaz
                  • Apr 2012
                  • 52
                  Redwire,
                  I completely agree with you and appreciate the advise. I'm using a fluke 289 and have the amp connected to an isolation transformer. I will solder the resistors back and attempt to do a voltage test and report back. Unfortunately only way to learn is to do it. I'm being as careful as possible. Thank you and everyone else for being so patient.
                  Johnny
                  • retiredcaps
                    • Apr 2010
                    • 9271
                    The Fluke 289 will easily survive those voltages safely. If your 289 came with some aligator clips, now is a good time to use them. Even if you can only use the black clip, then at least you can probe one handed (keep the other in the pocket) as redwire mentioned.
                    Make sure the clips have a good hold/grip before applying power. You don't want the clip to come flying out and causing a short.
                    --- begin sig file ---
                    --- end sig file ---
                    • johnnydiaz
                      • Apr 2012
                      • 52
                      Retiredcaps,
                      I did buy the whole kit which included the alligator clips. I will definitely use them. Thanks.
                      Johnny
                      • samson7point1@yahoo.com
                        Help troubleshooting an audio problem with an RCA SGT-250 CED Player
                        by samson7point1@yahoo.com
                        The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
                        The player processes the audio signal using two different reference frequencies. The "R"...
                        04-30-2024, 11:22 AM
                      • snpulse3344
                        USB Audio Interface - Steinberg UR 12 or similar schematics
                        by snpulse3344
                        I need to find out schematics diagram of Steinberg UR 12., pcb printed these numbers YAMAHA YF989 ZM60700, I searched everywhere but I didn't find the schematics of this USB audio interface, If anyone has it please let me know and if anyone has similar schematics diagram please let me know as well.
                        03-01-2024, 01:07 PM
                      • Felipe_Serra_83
                        Cambridge Audio Minx x200 - request for schematics or service manual
                        by Felipe_Serra_83
                        Hello all. I dunno if this is the right forum for making this request. If not so, I'll be happy to post this somewhere else.
                        I have a Minx200 which has several shorted caps. I'm guessing a power source and/or regulator short circuit. I can't find schematics for this device. Any help is kindly appreciated. Thank you!
                        06-23-2024, 04:21 PM
                      • glaquerre
                        Lenovo IdeaPad S145 no power - Capacitor? (schematics included!)
                        by glaquerre
                        I have a Lenovo IdeaPad S145 that does not power on. After pressing the power button (on the keyboard), the white light (in the key) blinks six times when both battery and power adapter are plugged in, or blinks three times when only power adapter is plugged in. In both case, the LED in the DC power jack never lights up. I've tried hard & soft reset (this laptop has a pin hole for reset purpose) without any success.
                        I've found a shorted capacitor (red circle in the included picture) near a mosfet. This mosfet receives 19V but no voltage at the gate and...
                        03-18-2022, 01:46 PM
                      • i_am_patch
                        Roland KR-3500/4500 Digital Piano. Crackling audio sound on all keys -Fixed
                        by i_am_patch
                        Hi All. I had a Roland KR-3500 Digital Piano (similar to the KR-4500) that exhibited a Crackling audio sound on all keys. After reading somewhere about someone with a similar issue who had replaced all the Electrolytic caps I decided to also go down that route. (Spoiler : It worked !) After some basic troubleshooting I determined that it could be noise feeding thru from the Keyboard scanning since the Demo tunes played back undistorted and the Audio amp / speakers were fine ( Inserted an Audio signal into the rear Audio input). After extracting the main board from the shield, I replaced 7 Capacitors...
                        04-30-2024, 08:20 PM
