I'm trying to repair an audio amp which doesn't power up. I measured voltage at the br and got 123 volts. I measured voltage at the main caps and got 160volts. I noticed that r245 & r288 were getting very hot (I measured it at ~ 120 degrees fahrenheit). So I unsoldered one leg on each resistor and got the proper reading. What could be causing these resistors to heat up? Also what else should I test? I have included the schematic.
Need help repairing an audio amp schematics included
Tags: None
Re: Need help repairing an audio amp schematics included
R245 is in series with the 18V Linear regulator circuit Q28. This is not a good design due to trying to drop 380VDC down to 18V using resistor/transistor.
Are you getting 18V and 380VDC at those two points? VDD?Never stop learning
http://www.badcaps.net/forum/showthread.php?t=24809 -
Budm,
"Are you getting 18V and 380VDC at those two points? VDD?"
Sorry but I'm a newbie. What two points?
JohnnyComment
Since I'm new at this I'm not sure exactly what to do. So I will measure dc voltage. I should put my positive test lead on r288 18volts and where should I put the negative? Same positive test lead on R288 380volts and where does the negative go? Sorry for the newbie question just want to confirm since its high voltage.Comment
First, take some measurements on the PSU primary side. Be careful of the high voltage and the fact that the caps (for VDC) can hold a charge even when things are unplugged.
You would put your multimeter lead (-) on (primary) circuit common somewhere convenient, like the (-) terminal on D40/C190/C192 etc. The schematic shows this as a ground symbol, but it's not really.
Then write down the DC voltage readings on:
18V should be around 18V.
VDC should be around 380V.
VDD should be around 19V.
The power supply has two parts and a bit tricky. It looks like start-up voltage (VDD 18-25V) is first provided by Q28, then U36 starts up and generates VDD. Same for 18V, start-up power is from R288, and again U36 circuit then powers the 18V from VDD.
If R245 and R288 are cooking, I'd guess the PSU is not starting up.
Then you would snoop around U36 to see why it's not running.Comment
Ok so I understand the the negative terminal part. I'm confused about the 18v, 380v & 19v? Do I put the red test lead on one of the leads on the resistor r288 to test the 18v? Im looking at the actual board and the page 6 of the schematics and am confused.Comment
Johnny, if you don't have experience making voltage measurements then I suggest kinda not doing the repair. The voltage is high enough to kill, and even slipping with the probe tip can cause a big boom. Your multimeter and its probes must be good quality too. Just something to ask yourself, because there's a risk and learning on this power amp there is no room for mistakes.
The measurements are made on any component that connects to the signal/power feed of interest as shown on the schematic. As long as you have the correct side i.e. only one side of R288 is the 18V. You have to look around and follow the traces, or just find another part on the 18V rail. If a point is too hard to get to, go to any other part on that rail to make your measurement.
I use an alligator clip (well insulated!) connecting the meter (-) to common, so I just have to hunt around/hold only one probe (+).Comment
Redwire,
I completely agree with you and appreciate the advise. I'm using a fluke 289 and have the amp connected to an isolation transformer. I will solder the resistors back and attempt to do a voltage test and report back. Unfortunately only way to learn is to do it. I'm being as careful as possible. Thank you and everyone else for being so patient.
JohnnyLast edited by johnnydiaz; 05-29-2013, 06:11 PM.Comment
The Fluke 289 will easily survive those voltages safely. If your 289 came with some aligator clips, now is a good time to use them. Even if you can only use the black clip, then at least you can probe one handed (keep the other in the pocket) as redwire mentioned.
Make sure the clips have a good hold/grip before applying power. You don't want the clip to come flying out and causing a short.Attached Filesif you find these attachements useful please consider making a small donation to the site
--- end sig file ---Comment
Retiredcaps,
I did buy the whole kit which included the alligator clips. I will definitely use them. Thanks.
JohnnyComment
The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
The player processes the audio signal using two different reference frequencies. The "R"...2 Photos -
Hi
I have this Lantec PULSE 386 subwoofer I got a while back laying around awating repair for quite some time. Sadly it's missing it's original speakers which it came with.
After plugging in the mains, the LED on the volume controller lights up. When I plug in the 3.5" jack cable to my soundcard (confirmed to work), I get no audio on the subwoofer (nor the speaker jack at the back).
The PCB is quite simple. There is a UTC4558 amp and two D6282 audio amps. When I put my finger on the UTC4558 I can see and hear the speaker "fart". Although, the left...-
11-29-2025, 04:15 AM -
by i_am_patchHi All. I had a Roland KR-3500 Digital Piano (similar to the KR-4500) that exhibited a Crackling audio sound on all keys. After reading somewhere about someone with a similar issue who had replaced all the Electrolytic caps I decided to also go down that route. (Spoiler : It worked !) After some basic troubleshooting I determined that it could be noise feeding thru from the Keyboard scanning since the Demo tunes played back undistorted and the Audio amp / speakers were fine ( Inserted an Audio signal into the rear Audio input). After extracting the main board from the shield, I replaced 7 Capacitors...
04-30-2024, 08:20 PM -
by silver60618Im working on a 2023 Macbook Pro M3 A2991, that had a liquid spill, has no sound. Corrosion found near Speaker Audio Amp IC. Chip ID SN012776B0,
I did find a SN012776B0 on A2442 model, but the sub and replaced it, no go. Anyone know if these audio amp IC's are cross compatible between 2021-2023 models?... -
This specification for the DELL Inspiron 5680 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 5680 boardview and Inspiron 5680 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...09-12-2024, 02:20 PM
- Loading...
