Suspect Denon Power supply issue
  • lottathought
    • Feb 2013
    • 9
    I am very new to the world of troubleshooting electronics...so please be patient with me. I got my hands on a Denon 3802. It appears to be in protection mode. The unit is getting power and has the red standby light. When you try to turn it on however, the display does not light up and the red on/standby light just starts to flash. I have read that Denon installed 4 surge protecting resistors in the power supply that are known to fail. So far so good.. Here is where I am running into a problem and am probably showing my newness. I have no idea where the 4 resisters are...or where to find the schematics to track them down. And I am not sure how to test a Denon power supply to see if that could be the trouble. As this was supposed to be a common issue for Denon, I am hoping somebody could point me in the right direction.
  • Khron
    • Sep 2006
    • 1350
    • Finland
    Re: Suspect Denon Power supply issue
    I've managed to find 11 of the 15 pages of schematics of this receiver. The only "surge protecting resistors" that i've been able to spot upon a quick perusal are R503 and R504 (page 9, right edge of section A) - 0.1ohm / 5watt. They look like they're used more like some current-sense shunt.
    You might also wanna run a check on all the fuses - they might offer an indication where the fault might be located, in case it is indeed some overload-damage of some sort.
    EDIT: Now i noticed there's a few resistors in the speaker output section as well (page 8), although they're much less likely to have "gone".
    Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
    • lottathought
      • Feb 2013
      • 9
      Thank you so much for this. I have checked all the fuses. They seem to be fine. I have a feeling that this is going to be a long term project. I am learning as much about how test as any actual troubleshooting here. But that is why I got this receiver.
      • Khron
        • Sep 2006
        • 1350
        • Finland
        What about that pair of power resistors on the +59v rail?
        I hope you've at least got a multimeter of some sort.
        If all the fuses are fine, you might wanna check if all the voltages are around the values they're supposed to be.
        Do any of the relays click on when the receiver's supposed to "power up"? You might wanna check for DC on the "input" side of the output relays.
        • lottathought
          • Feb 2013
          • 9
          Khron666...yes I do have a multimeter. I have a Fluke 87v. Yes,I know it is overkill and I will likely never fully grow into it....LOL It is a little hard to explain but although I have never done much of this, it is in my blood. I strongly suspect that I will be troubleshooting electrical equipment for a long time and wanted a solid machine. I will have to get back to you on the voltages. The relay does click at startup. But it then the on/standby starts to flash and there is never a display.
          • Khron
            • Sep 2006
            • 1350
            • Finland
            I don't suppose the owner's manual has a list of flash / error codes, does it?
            • lottathought
              • Feb 2013
              • 9
              The display never lights up. Even if there were an error code readout, there is no way to see it.
              • Khron
                • Sep 2006
                • 1350
                • Finland
                I meant about that stand-by led flashing
                • redwire
                  • Dec 2010
                  • 3912
                  lottathought, there are many ways to troubleshoot. Make sure you have small sharp probes for the Fluke, lest you slip and cause damage. It takes patience
                  I would start by measuring and recording all power supply voltages. There's a lot of them. Just at the connectors. The red traces on the schematics highlight the power paths too. Find a good ground point and then just roam around with your positive multimeter probe only, it's easier. Troubles with the power amps outputs and +/-59V rails are the first place to look.
                  "Surge protecting resistors" is poorly translated Japanese for "fusible resistors" but I didn't see any (grey box and ! symbol on schematic).
                  The protect system is fairly complex, based on overtemp and any channel having too much DC offset. It would be hairier to troubleshoot back from that.
                  Ignore the flashing red light, it just tells you there is trouble "somewhere". I would think the display should come up but it might not have power too, although the CPU is up.
                  Khron666 thanks for posting the schematics.
                  • Franco76
                    • Oct 2013
                    • Danmark
                    Hi there
                    1. Check that the main trafo works. Measure ohm across the input plug on the trafo (below 20 Ohm.).
                    2. If the trafo is ok. Then check the output transistors isen't shorted.
                    My bet is one of the two is faulty.
                    Happy hunting!
                    • dwu
                      • Jul 2014
                      • Brazil
                      New to this board, not sure if this is the right spot to post.
                      I have what seems like the same problem with an AVR 486. Changed all power supply capacitors. I suspect when I had rewiring done in my house they reversed my rear channel wires and something blew. Tried the standard reset, no luck. Powers on the get that flashing red light
                      • Soulzink
                        Samsug washing machine. Power supply DC41-00189a board issue
                        by Soulzink
                        I am trying to fix a samsung washinmachine power supply main board.
                        I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
                        Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
                        The power supply board reference is the following: DC41-00189a
                        I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
                        04-19-2025, 06:26 AM
                      • GLISIT
                        by GLISIT
                        01-16-2025, 02:29 PM
                      • Tynan Dill
                        by Tynan Dill
                        Assuming...
                        11-22-2024, 01:46 PM
                        07-01-2024, 06:34 AM
                      • Cookybaby
                        Samsung UN60ES6500FXZA Power Supply Issue
                        by Cookybaby
                        Hello Everyone, this is my first post and I am excited to be a part of such a great community. I've been reading these forums for awhile and there really is some good friendly people here. No bashing and being rude like 90% of other forums Ive been to. Lets get to the good stuff.
                        I have two years of college in Electronics Engineering Technology. Ive been tinkering with electronics sine about 1990. I know enough just to be dangerous, so be gentle.
                        Make: Samsung
                        Model: UN60ES6500FXZA
                        Power Supply P/N: BN44-00525A
                        Symptoms: The TV was...
                        08-20-2023, 12:26 PM
