Pioneer VSX-521, doesnt power up
  • scampo77
    • Dec 2010
    • 233
    can anyone please help me find a schematic for this reciever?
    I found a shorted output but only one of (what looks like to me) a darlinton pair. do i have to change both if only one is shorted?
    they are part numbers 5160 (shorted) and D2390
    there is a TO-220 case inbetween the darlinton pair, what is this?
    K
    C3964
    133
    Re: Pioneer VSX-521, doesnt power up
    C3964 =
    • scampo77
      • Dec 2010
      • 233
      Thankyou so much for the reply I got the data sheet but was looking more for the purpose of that piece and if I should check or replace it.
      I've never seen one in the middle of a darlington pair like this
      • Tube_Dude
        • Feb 2011
        • 51
        Maybe the VBE transistor, used to stabilize the quiescent current of the output stage (Bias) in all temperatures of operation...
        • scampo77
          • Dec 2010
          • 233
          does anyone know where i can get schematics?
          can i replace just one transistor in a darlington pair? (if only one is shorted)
            • scampo77
              • Dec 2010
              • 233
              BUD!!!! where have you been hiding?
              thanks for the schematic!!!!!
              • scampo77
                • Dec 2010
                • 233
                i got the output in the mail and installed it and it still doesnt power up.
                I followed the diagnostics sflow chart and right at the begining it says to check for 12v at plug CP1304. this seems to be a plug where the digital stuff gets its supply voltage from and it seems to come right from the power supply. i have 110v coming in and the fuse is good.
                do these linear transformers fail? im not sure what to do next because the flow chart just says "if you dont have volatge then to check the main board. im not sure what to check next
                the plug CP1304 is on page 102 of the schematics that bud was kind enough to put up.
                • scampo77
                  • Dec 2010
                  • 233
                  can anyone offer some advice? i can take more pictures if it will help
                  • scampo77
                    • Dec 2010
                    • 233
                    I am still struggling with this amp and could sure use some help.
                    i put a picture up of the standby board what is FLAC and FLCT?
                    and standby relay has no voltage when i push the on off button.
                    I do have voltage (10v) at standby VCC
                    what actually happens when i push the power button? and shouldnt i have voltage to drive a standby LED?
                    HELP
                    • ajal14
                      • Jul 2014
                      • 7
                      • canada
                      hi there, i am facing a strange issue on my vsx 821. After reseting the unit it woks for days! after turn it off for hours , it go bck dead, no power! i have to reset it again to make it working for days!!!! i couldnt find any short on the main board or amp section. Any help? thx.
                      • mmartell
                        • Oct 2013
                        • 3189
                        I will guess that FLAC is FLourescentAC for the display and maybe Flourescent Circuit for the other. Find out how to bypass the power button by jumpering at the HDMI board and see if listen for your relay to click. Or even easier tap it with the butt end of a screwdriver several times and press the button to see if it's sticking.
                        I think these also blow the small inline fuse on the primary winding of the transformer but I could be mistaken.
                        • reessi
                          Acer Alienware Nitro 5 (GH51G LA-L181P Rev: 1C) & Dell Alienware M15 (GDP50 LA-k452P Rev:1) - Both Shorted PCH (SRKMA)!
                          by reessi
                          Hello:
                          I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
                          I started on the ACER:
                          Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
                          All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
                          I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap...
                          10-29-2024, 11:31 AM
                        • Yanleb
                          Panasonic TC-P50S1 shorted TXNSC1EDUU (TNPA4782AB) SC Board
                          by Yanleb
                          Hi every one. I just want to share the successful repair of my shorted Panasonic TNPA4782AB SC board.
                          I don't usually do it but so many parts were shorted that I decided to buy the ShopJimmy repair kit instead of sourcing each components individually. Here is the list of components the kit contained, with a remark indicating if I needed that part or not :
                          D608, good
                          D618 RF101L4S, good (See warning 1 below)
                          D619 RF101L4S, good (See warning 1 below)
                          D865 RF101L4S, shorted (See warning 1 below)
                          IC464 Inverter HA MC74HC1G14, shorted...
                          03-09-2020, 12:00 AM
                        • modtool
                          HP Victus 15-FA1025NL , board DAG3PAMB8D0 REV:D, shorted CPU DrMOS and n-mos
                          by modtool
                          Hi to all,
                          the owner of this machine gave it to me after having opened it to take off the dust from the inside, telling me that after that it didn't start anymore.
                          I found that one of the DrMOS (AOZ5016QI) on the CPUCORE was shorted between VIN and VSWH, and that one of the two n-mos connected to the power jack was shorted aswell.
                          I unsoldered the two shorted components and verified that there were no other short circuits, then decided to power the mainboard, firstly with the lab power supply, then with its original HP 200w charger, but the behaviour is the same, the board starts...
                          04-01-2025, 08:22 AM
                        • BalkanBoy
                          Dead Razer Blade 14 2022, shorted CPU?
                          by BalkanBoy
                          today I got Razer Blade 14, Ryzen 9 6900HX and RTX 3070Ti.
                          Laptop was completely dead. I found shorted CPU VRM mosfet, shorted 19V mosfet and blown battery fuse.
                          I replaced it all, but still on CPU coil where mosfet was shorted I got very low resistance, near 0 ohms. On other CPU coils I got around 3 ohms.
                          Laptop now raises voltage on whole board, but still nothing comes on the screen. CPU gets 0.7V on all coils except the shorted one. CPU gets only slightly hot, below 40 C.
                          I removed coil and injected 0.7V, it draw around...
                          09-27-2024, 12:44 PM
                        • barry101
                          Apple 820-3662 VCore shorted to ground.
                          by barry101
                          Hi, Would appreciate some help.
                          I have an Apple Late 2013 15" A1398 MacBook Pro with Logic Board 820-3662.
                          Get charger light but no fan spin or chime. No liquid damage.
                          Found PPBUS and VCORE both shorted to ground. Other rails were ok.
                          Removed VCORE MOSFETS U7310, U7320 and U7330. Found U7330 was in fact shorted.
                          With the 3 MOSFETS removed, get PPBUS and fan spin. VCORE is still hard shorted to ground (0 ohms).
                          Attempted voltage insertion on VCORE to locate short using bench supply set at 1.0 VDC and 4.95 Amps (max current for my...
                          06-24-2025, 07:34 AM
