LG HT33S - Loud High Pitch Tone
  • blackillusion
    • Nov 2010
    • 16
    Hi guys,
    I have an issue with this. It appears to be coming from the PWM circuit
    http://youtu.be/ryxeJLIIbaY
    I had an inductor L606 the had come loose from the solder joints and replaced it back in circuit. I tested to see if it had shorted but it had not.
    I tested the caps with ESR and they check ok.
    Any ideas what could have failed. I'm leaning towards and IC
    Service Manual/Schematic
    PWM circuit is page 44
    Please note I have a DMM and ESR tester, nothing more.
    Thanks you
  • blackillusion
    • Nov 2010
    • 16
    Re: LG HT33S - Loud High Pitch Tone
    looks like some idiot put a 5v regulator in instead of a 3.5v/3.3v
    it has been opened before by some shop. We got it through ebay.
    schematic says it should be a 278R35, but its got a 78R05 in.
    I cannot source a 278R35 at the moment. Looked on farnell.
    the spec sheet says its a 2a ldo 3.5v
    http://www.digchip.com/datasheets/pa...8R35PI-pdf.php
    can I swap for a 1A? or would that be bad?
    • blackillusion
      • Nov 2010
      • 16
      Ok so I finally got my 3.5v regulator exact match and still get the high pitch tone. It appears that I dont have the 35v on the other connector though Maybe I'm not testing correctly I think I need to check tomorrow as I only went over it quickly. Believe it stops a the switching transistor on the hot side.???
      I will verify that. If a pwm is low or no voltage at a point would that cause the high pitch noise
        The 35v is for supplying the power for the POWER AMP ClassD the amplifirer, the IC's also require 12VDC, do you have the 12vdc?
        If you are getting the high pitch from ALL speaker outputs, then it has to be something that is common to all the amplifier which will be the power supply. So you need to verify if you do have 35VDC or not.
        The 35vdc is generated by transformer T902 on page 37, look at the connector C902 pin 2~4 with black probe of the meter on the chassis.
        The power supply for this unit is ALWAYS running the minute you have it plugged into the AC outlet so it runs 24/7 which I do not like since it be exposing to any spike/surge 24/7.
        You should have all the voltages as shown on the both connectors in page 37.
        • blackillusion
          • Nov 2010
          • 16
          Hi budm thanks for your reply. I have just tested and only have 30.5v. All other voltages are present. Although 12v is showing 11.9v or something similar. But all are present very close to their specified
          The high pitch comes directly from the PWM board, I don't have to have the speakers plugged in and its making the tone.
            The only thing I can think of that can make high pitch is from the inductors for the switching power supply. I need to look at the diagram some more, but you should also hook up the speaker to see if it also comes through the speakers.
            • blackillusion
              • Nov 2010
              • 16
              Hi budm thanks again for your help. Well if the sub speaker is plugged in to the PWM circuit the tone comes through that speaker so I would assume it goes through the rest. I can confirm tomorrow?
              • blackillusion
                • Nov 2010
                • 16
                I have taken another look into this and would assume that the 35v being 30.5v is the problem. Low voltage makes pwm squeal. ?
                • midibob
                  • Nov 2008
                  • 285
                  I can remember some time ago one particular make of PSU giving quite a loud high pitched whine when it was due to pack up.
                  This was invariably due to a low value cap in the oscillator cct drying up.
                  This maybe a red herring but worth checking.
                  Typical values are anything between 1uF and 4.7uF @ 50v and they are normally quite close to a heatsink for the switching transistor which is why they fail.
                  Good luck
                  Midibob
                  • ben7
                    Capaholic
                    • Jan 2011
                    • 4059
                    Good luck
                    Midibob
                    I agree, it seems like maybe a bad cap causing the audio amplifier to oscillate. Depending on how the amp is setup, all the outputs could oscillate too then.
                    Muh-soggy-knee
                    • blackillusion
                      • Nov 2010
                      • 16
                      Ok guys, I am in the process of setting my esr meter around the board I have two ceramic caps that appear to do nothing but I'm not sure if my meter doesn't support the value?
                      2a272J doesn't give a reading when using esr meter just - -
                      Again thanks guys
                      • blackillusion
                        • Nov 2010
                        • 16
                        Well t902 has no output voltage. Ive tested components one by one and capacitors seem to be ok. Could it just be that IC902 is faulty?
                        • midibob
                          • Nov 2008
                          • 285
                          Silly me,
                          I should have played the youtube sound in your first post.
                          It's definitely not a failing PSU noise as this was due to the oscillator whining. In your case you have some audio tone being generated from somewhere.
                          Checking with a software spectrum analyser it shows peak frequencies at 1.5KHz, 3.7KHz and 6.25Khz. I did originally think it maybe some kind of internal test tone but I can't find any mention of it in the manual.
                          Now, as you say you don't have any speakers plugged in, some kind of transducer must be generating the audio. I must admit I've never heard any components manage to produce audio like that barring transducers of course.
                          There doesn't appear to be one that I can see on the diagram either. All very odd.
                          Anyway, back at the ranch, if there's no output from T902 then ic902 has either failed or it's associated voltage supplies/ oscillator components are faulty.
                          I would check the 3 zeners Z902 and Z911 an 12 and possibly the dropper resistor R911. Are the voltages on the chip correct?
                          Also check there are no shorts on the output of T902 if you haven't already.
                          Good luck
                          Midibob
                          • RetroComputingGrotto
                            Viewsonic VA2010wb (High Pitch Squeal At Power On)
                            by RetroComputingGrotto
                            I've got a monitor on my workbench at the moment that makes a high pitch squeal (that I cant hear as my ears are too old) when you power it on and lasts a couple of seconds before quitening and apparently it can be heard at regular intervals whilst on.
                            On opening up the monitor and looking at the PCB the usual suspects showed their heads so I have already replaced all the electrolytic capacitors.
                            The other issue that was reported with this monitor was the fact it took ages to start displaying anything after pressing the power button.
                            What component(s)...
                            02-03-2025, 06:00 AM
                          • karatzdi
                            Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
                            by karatzdi
                            I know some might say... just buy another one. Sell it as parts..!
                            So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
                            Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
                            Spent some time downloading the Service...
                            06-11-2024, 08:38 AM
                          • redwire
                            Honeywell/Ademco Wave2 two-tone siren - recap, sch, pics
                            by redwire
                            My garage alarm siren was sounding a bit quiet and the tone was weird, like mixed with another tone.
                            Powered up it draws about 14V 300mA with a spike to ~1A briefly during the low pitch yelp, seems normal.
                            Teardown reveals only two electrolytic capacitors inside, so I replaced them. 100uF 25V for the warble ramp, and 47uF 16V for decoupling.
                            The old ones tested OK sort of? - 100uF reads 68uF (-32%) ESR 0.80Ω, and 47uF reads 41uF ESR 0.87Ω as well so it was a bit confusing if the caps were to blame.
                            The tone caps are green film caps I left alone. Newer...
                            07-30-2023, 08:21 PM
                          • Alimash
                            op amp circuit function?
                            by Alimash
                            I am repairing a ups which doesn't turn on ,it has the following ICs:
                            SG3525 used to drive inverter mosfets.
                            couple of uc3483, one for the power supply and another to drive a big mosfet at the output stage(i think the technique is called boost)
                            A LM358 and TL074 for control mechanism and of course the uController.
                            The SG3525 is shutting down every time the ups is turned on.
                            I want your help to know the function of LM358 and TL074 in the system.
                            I reverse engineered the LM358 circuit and i think that one of the block(A) is used for battery level...
                            07-31-2025, 07:45 AM
                          • Astonished
                            Fixing the Charge Circuit of the Batteries of the DC Motor
                            by Astonished
                            Hi friends of electronics
                            What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
                            The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
                            Please help me fix this circuit.
                            (the datasheet of the IC: https://pdf.datasheet.live/28...
                            01-28-2025, 06:24 AM
