Focusrite Saffire Pro 40 re-cap
  • Khron
    • Sep 2006
    • 1350
    • Finland
    #41
    Re: Focusrite Saffire Pro 40 re-cap
    I quite doubt it's worth bothering with replacing the headphone amps. If you'll recall that link with the opamp measurements, when used properly (in this case, as current buffers / boosters), 4556's are just fine for 'phones
    Kinda makes sense though, 2122's are the main gain elements, so they'll have the greatest influence, i suppose.
    The most tell-tale test would be 2-3 matched mics, put through separate inputs in various modding stages
    Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
    • PhilippHoeger
      • 20
      I couldn't figure out how many and which opamps work on the monitor out.
      What opamp numbers are these on the saffire 40 ? how can I find out on this multi-layer board?!
      Looks as if the mains were fed from the 4392 chip
      • Khron
        • Sep 2006
        • 1350
        • Finland
        #43
        Yes, the 4392 is a stereo DAC (the other 4 chips are stereo CODECs = ADC/DAC combos).
        Now, at least on my 40, if you look at the photo from the first post, if my eyes don't deceive me, in that group of 12 opamps in the middle of the board, the first column of 4 from the left, are the output buffers / low-pass filters for the DAC's - one half of a dual op-amp per channel. You can see the traces coming from under them, and going to the output section.
        The other 8 i suspect to be the balanced drivers for the ADC inputs. Those small electrolytics are most likely the input caps to those, because the outputs of those opamps have to be centered around the Vcom of the ADC's.
        The rest of the opamps up top, near the output jacks, most likely make up the balanced line drivers.
        • PhilippHoeger
          • 20
          managed to follow the multilayer pcb traces with a bright flashlight
          seems a bit different on the 56. on the main board there are:
          5 opamps pushing the 4392 signal for the mains (Out 1/2)
          4 opamps for the 4 other stereo outs each (Outs 3/4 5/6 7/8)
          this makes a total of 21 output opamps. excluding headamp
          • PhilippHoeger
            • 20
            Conclusion after changing all output opamps:
            I've swapped in 5 LM4562 on the monitor main output (1/2)
            Outputs 3-10 got NE5532 all over because I rarely use them and these were pretty cheap too.
            Before there were NJM4565 on all outputs.
            I'm really impressed with the LM4562. Bass and Mids are very rich and detailed.
            The NJM4565 lacked some Bass and lots of Mids in comparison although they were very! detailed in the highs I think, somehow a bit too much on the bright side making them fatiguing. But loved their attack.
            The NE5532 sounds just fine. Nothing special, nothing outstanding. I'd say they're flat, honest and natural.
            It's a whole new device. Did not expect to hear so much difference with all the little steps and I think I could really get addicted to modding things
            So finally, I'm finished with this. Thank you for your help. You're all invited to take a listen
            • rapido
              • 7
              • Denmark
              #46
              Not to sound lazy, but would anybody be willing to make a BOM for the PSU upgrade and opamp/cap upgrade in a post beneath?
              Not links or anything, just it all gathered in one post, as I don't have time at the moment to pull out my saffire and check. (getting used heavily and are sitting in rack with every connections used).
              Im trying to comprehend all the posts here, but I'm afraid that I will forget something/wrong amounts, when placing my order at digikey.
              • rapido
                • 7
                • Denmark
                #47
                Okay think I got all the caps written down. But one think confuses me.
                You mention replacing 2122's & NJM4565.
                You replace both with LM4562 right?
                And what are the 16 pin packages at the inputs? analog switches or?
                On the pictures I can't read the packages, so if anyone could help with how many op amps I should order it would be a great help.
                I have a saffire 40, and want all in/outs modded.
                • Khron
                  • Sep 2006
                  • 1350
                  • Finland
                  #48
                  If i understood correctly, Philipp replaced only the NJM2122's with LM4562's (since those are the main gain elements in the preamps). Most of the rest of the opamps (NJM4565's), if not all, are merely buffers.
                  Replacing ALL the opamps with 4562's will be pricey, to say the least Not to mention that i'm quite sure it'll be far beyond the "point of diminishing returns" As i've mentioned on the first page, i've quite got my mind set on (someday) replacing all the opamps with NJM2068's - cheap and really low-noise
                  Yes, the 16-pin IC's near the inputs are analog switches indeed, no need to worry about those. They most likely use some switches inside the input jacks to route the signal through the (high-gain) mic preamps or the (lower-gain) line preamps.
                  Regarding opamps - there are 8 (eight) NJM2122's (SOIC-8 wide, with the gray writing), 2 (two) TL072's (SOIC-8 narrow, in the lower left, FET input for the Hi-Z inputs), and all the rest of the 8-pin IC's are NJM4565's - in the picture from my first post i count 24 (twenty-four). That breaks down into 4 (four) for the 8 inputs (they're dual opamps), 12 (twelve) for the ADC/DAC input/output buffers and filters, 7 (seven) opamps for the 10 balanced output drivers (and something else?), and one more with unknown role just below the main DICE processor.
                  • PhilippHoeger
                    • 20
                    I replaced the 5 the main output opamps for LM4562 .
                    All input opamps inclunding buffers were changed to 4562, too. Changing the input buffers did not make a huge improvement. As Khon said, replacing the 2122's (preamp gains) is just fine.
                    But also swapped in some NE5532 all remaining NJM4565.
                    • rapido
                      • 7
                      • Denmark
                      #50
                      Thanks for summing it up.
                      Really looking forward to doing this mod.
                      • rapido
                        • 7
                        • Denmark
                        #51
                        I see the recap you did used Panasonic and rubycon for the audio part.
                        You think using Elna Silmic II or Nichicon Muse's would be worth it to use instead?
                        • Khron
                          • Sep 2006
                          • 1350
                          • Finland
                          #52
                          As you may (or may not) have read on the first page, i'm not a believer in the whole "awe-diophile" / "audiophool" nonsense with capacitors "for audio". I just used what i had available in my stock of parts
                          • rapido
                            • 7
                            • Denmark
                            #53
                            Yeah I read that.
                            I must say I'm not sure I believe the hype either, but I just read so many posts and tests around the internet with electrolytic cap comparisons for audio signal paths, that I can't get it out of my head and ignore it completely.
                            • Khron
                              • Sep 2006
                              • 1350
                              • Finland
                              #54
                              I'd reeeeeeeeeeally be curious about some head-to-head comparisons ("audio" caps versus some normal (but "good" brand) electrolytics, used as coupling caps. "Head-to-head" meaning two identical devices, the only differences being those coupling caps. Y'know, double-blind ABX testing, or at least some measurements...
                              • aaronrash
                                • Feb 2014
                                • 6
                                everyone, this is my first post here. I have a Saffire Pro 24 that has the same OpAmps you guys have in the 40.
                                I'm planning on doing the mods. Is there any BurrBrown chips I could use for the opamps that would fit instead of the LM? I know BLA mods the Saffire and they use BurrBrown chips.
                                I also checked out the AD/DA chip.
                                Also noticed the CapXon caps, those are coming out!
                                • Khron
                                  • Sep 2006
                                  • 1350
                                  • Finland
                                  #56
                                  Not that BB/TI chips aren't good, but i really doubt they're worth the expense.
                                  You really can't go wrong with the venerable old NE5532 (or the JRC version, NJM5532). I myself got a few dozen NJM2068's off fleabay, a few months back. No idea if/when i'll get around to replacing the opamps as well in my Pro 40, but that's what i'm planning to use
                                  You'll wanna stick with some FET-input opamps for the Hi-Z inputs on 1 and 2, though (stock there's 1 or 2 TL072's there).
                                  Actually, if one ventures to replace the NJM2122 chips, at least in theory, one could also adjust (read: increase) the LM317/337 output voltage for the analog stages. The datasheet of the '2122 mentions it needs supply rails of max +/-7V due to power/heat dissipation - the block diagram shows what looks to me like a class-A output stage. On the other hand, if that limitation goes away (by replacing the 2122's), one could increase the analog rails up to, say, +/-10v, or even 12, with no concerns - one effect being a lowering of the noise floor (but i might be wrong, so don't quote me on this )
                                  • aaronrash
                                    • Feb 2014
                                    • 6
                                    Cool,
                                    I am just going to change all the opamps and 2122's with LM4562's. I know it will be pricey to do them all but I don't mind spending a little extra and I'll feel better about it. It sounds like the caps make a big difference too. I will replace them all.
                                    I have been doing regular soldering for years but I have never done SMD. what is the best way to get the components off the board? I'm going to buy a rework gun. Also what is the best temperature to operate at? I would be a little worried to damage the board.
                                    Awesome thread, I'm glad I found this!
                                    • Khron
                                      • Sep 2006
                                      • 1350
                                      • Finland
                                      #58
                                      For chip removal, you'll wanna set the hot air to about 350-400C, and the airflow to about 50% - you want to get the chips off as quickly as possible Might wanna thing about wrapping some tinfoil over the caps around the chips, as a heat-shield; or if you'll be recapping it as well, in one fell swoop, disregard this last tip
                                      Once the chips are off, a nice hot soldering iron (~330C), with a flat tip, and some solder-wick, to clean the pads, and you're golden Soldering SOIC-8 chips is no big deal - after positioning it, get a bit of solder on the tip of the iron, hold down the chip with a pair of tweezers or something, and tack one of the corner pins onto the board, then the opposite corner. Smooth sailing after that
                                      • aaronrash
                                        • Feb 2014
                                        • 6
                                        Thanks!
                                        So I've got the hot air rework station ordered as well as the LM4562 Opamps... I'm clueless about a few things though
                                        I'm not sure witch values to change what to as far as caps go because the layout is totally different on the pro 24 vs the pro 40.
                                        Basically my biggest complaint with the Saffire is the high mid frequencies... The feel very unfocused and somewhat "mushy".
                                        I used to own a Lynx Aurora 16 and loved the way it sounded, it was very easy to pick out different preamps etc... but with the Saffire I can barley hear a different between my Neve 1084 and the stock preamp inside the unit. I'm guessing this must be the Focusrite to blame.
                                        Since I'm only using it to track vocals for now I was actually just planing on modding Line in 3 analog path. But it sounds like changing the caps makes a big difference too, so I want to do whatever is necessary to get a more accurate sound.
                                        • aaronrash
                                          • Feb 2014
                                          • 6
                                          Here are the caps around the AD/DA chip. They are all 10uF/16V.
                                          I'm wondering what I should change these to?
                                            ASUS P5GC-MX motherboard recap
                                            by momaka
                                            Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
                                            This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
                                            So here is what the motherboard looked like with its original caps:
                                            CPU VRM area up close…...
                                            01-27-2021, 11:59 PM
                                            no-name Radeon 9600 XT recap and cooler
                                            by momaka
                                            I've been seeing a lot of cheap-looking (but not always so cheap) no-name AGP video cards on eBay for a while. They started popping up quite a bit when the market for AGP cards became more alive all of a sudden due to interest in “retro” PCs. One thing that struck me about these cheapo cards is that they almost always seem to come with garbage caps - including the abominable Sacon FZ. That aside, though, I've been wondering about the rest of the quality (or lack of?) on these cards. So I decided to satisfy my curiosity yet again.
                                            This one was actually suggested to me by ChaosLegionnaire....
                                            11-06-2020, 07:54 PM
                                          • varunviolin007
                                            Looking for someone to recap Dell XPS T450 motherboard (Live in suburbs outside of Philly)
                                            by varunviolin007
                                            Hi guys,
                                            I’m looking for someone in the Northeast to do a full electrolytic capacitor recap on a working Dell Dimension XPS T450 motherboard (it's an Intel 440BX, Slot 1). The board runs mostly fine but is beginning to freeze after warm reboots (turns back on for 30 secs or so and then freezes up but is perfectly fine after 12 hr cool down).
                                            I’d be sending just the bare motherboard (CPU, cards, bracket, battery all removed). I’m located in Chadds Ford, PA and happy to ship within the US.
                                            Looking for someone experienced with older PC boards who uses...
                                            07-29-2025, 11:53 PM
                                          • Foetuss
                                            Recap motherboards :: Abit KG7-LITE and Soltek SL-75FRN2-L
                                            by Foetuss
                                            Hi all
                                            Hope this is in the correct place.
                                            I'm planning on recapping both motherboards. I actually already ordered recplament caps for them, where I will be changing out most for poly's.
                                            Could use some double checking to see if I'm not doing something stupid .
                                            Pictures of the boards are attached.
                                            What I will be replacing with what : (planned)
                                            Soltek Golden ::
                                            4 1500µF 16V 10mm (5mmL) KZG => APSG160ELL152MJ16S (Chemi-Con 1500µF 16V)
                                            6 3300µF 6.3V 10mm (5mmL) KZG => APSG160ELL272MJ20S (Chemi-Con 2700µF 16V)...
                                            01-18-2025, 11:44 AM
                                          • speggio91
                                            Focusrite Scarlett Solo 3rd Gen component identification
                                            by speggio91
                                            I'm trying to repair a Focusrite Scarlett Solo 3rd Gen audio interface that was accidentally exposed to 12V on the USB-C VBUS line instead of the normal 5V. A component marked as U1 on the PCB has completely blown up together with the capacitors C17, C15.
                                            From the teardown video linked below, it's indicated that U1 is a voltage regulator (switcher) with 6 pins. Unfortunately, the original part on my board is so damaged that I can't make out any markings or identify it.
                                            Video Link: https://youtu.be/8onqBc5iTB4?si=KHtU772wsproFGZy&t=633...
                                            12-04-2024, 04:00 PM
