This amplifier is in two minds. It claims "1200W 4 channel", but apparently that's the model number, along with C-300.4. It's rated to 75W per channel, 4 channels = 300W. Price £40.
So, my manager gave me one to evaluate for an audio installation.
I connected it up to a variable bench supply set to 14.5V (nominal max bus voltage in a car.) Fed 1Vp-p audio into it. The maximum I can get it to draw is 2.8A with two speakers connected; that's 40.6W total, or about 20W per channel, a fair bit from the claimed 75W, and not even accounting for inefficiency in the amplifier. That's also hideously distorted; clipping right at the rails.
Opened it up to find two ST TDA7377's in it. Now the datasheet claims 2x30W; but that's driving a square wave, no one listens to those. With a sine wave 1kHz, 10% distortion, at 14.4V, that's 2x20W BTL. And coincidentally, about exactly what I'm seeing. 4x75W is complete crap then.
It also appears to be fake silicon as the ST datasheet claims it cuts out at 8V, but the actual amplifier dies at just 12.7V; the Iq is also 200mA per amplifier, not 150mA.
Teardown results showed several bodges too; including free-standing 7808 regulator, ready to fall right off the board especially in a vibrating car. The amplifiers were mounted squiffy, and the soldering was mediocre. Also, the gain control does...nothing? Absolutely no function. Only volume control works... It appears it may have been dropped at some point
It only draws about 1A at those points. When I tore it apart I noticed none of the amps had decoupling; the only decoupling was a measily 1000u near the input, after a massive inductor and an input cap. All caps are off-brand Jyy or similar.
If it had four of
