Sharp LCD Integrated Amp Mod issue
  • pentium
    • Mar 2006
    • 2778
    From the other thread I own an older Sharp Aquos LCD TV that's missing the control box. I instead used it as a 720p DVI monitor for a media center system in my room and thought I would also try to hack an audio in port to it so I could use the internal amp and speakers.
    With the control unit missing the amp output is fixed so it's perfect for me to control the volume from the PC and not from the TV. I rerouted the audio in from CONNECTOR 2 to the external speaker out jacks. The modifications are seen below.
    It worked with one glitch. If you had turned the TV on and off a few times you would not get audio out of the speakers. The only way to fix it was to unplug the TV for about 30 seconds.
    Then two days ago my inverter had a fit again and when it was rapidly turning the set on and off I lost the audio. If I crank the volume all the way up on the computer I can faintly hear it through the speakers. During troubleshooting I found that if I funneled the audio in directly to pin 10 or 13 on IC3803 I would get audio back. Same applied if I went directly to 10 or 11 on IC3812, however with severe clipping.
    The catch was that it would do so in mono only and if one of the internal speakers were unplugged both speakers would go totally silent.
    I'm not sure what exactly shorted out here but it would be cool to get it fixed instead of replacing it all with some small amp.
    Find Nedry!
    Check the Vending machines!!
    <----Computer says I need more beer.
  • pentium
    • Mar 2006
    • 2778
    Re: Sharp LCD Integrated Amp Mod issue
    No ideas?
    Find Nedry!
    • ben7
      Capaholic
      • Jan 2011
      • 4059
      Originally posted by pentium
      No ideas?
      Im confused as to where both the internal speakers are connected.
      And, are you sure that you cut the right wires?
      BTW, are the audio system control inputs (eg mute) connected to anything? If they are floating, that might explain the odd behavior.
      Muh-soggy-knee
      • pentium
        • Mar 2006
        • 2778
        They all receive control such as muting from the external box which isn't present. It appears that without the box things like volume and muting on the TV side are effectively locked out because there's nothing to tell the audio board what to do besides amplify the input signal.
        I believe my modifications are correct. They are at the least positioned correctly on the schematics. The only thing that did however confuse me a little was if there was a relation between ground and the SPK- lines. In someplaces they show 0 ohm to ground and in other places they are infinite.
        Audio amps were never really my thing.
        Find Nedry!
        • ben7
          Capaholic
          • Jan 2011
          • 4059
          Try connecting your inputs to the L in and R in of the amp part of the circuit (2/2, your third image)
          That way the sound won't go through the audio processor circuits.
          Muh-soggy-knee
            master hoarder
            • May 2008
            • 12170
            • Bulgaria
            Don't ground L-OUT- and R-OUT-! (at least that's what you're showing in your 3rd picture) With the speakers removed, you should get no continuity between L-OUT- and ground and R-OUT- and ground - if you do, that's bad. The main AMP IC schematic can be found here:
            https://cdn.badcaps-static.com/pdfs/...d4899c0579.pdf
            Particularly, have a look at the sample circuit on page 5 and compare to yours. Should be very similar.
            • joshnz
              • Feb 2011
              • 969
              • New Zealand
              I Agree I was going say that yesterday but didn't get round to it.
              My pc
              CPU : AMD PHENOM II x4 @ 3.5Ghz
              MB : ASUS M4A89TD PRO USB3
              RAM : Kingston ValueRAM 16gb DDR3
              PSU : Cooler Master 850W Silent Pro
              GPU : ATI Radeon HD 6850
              • joshnz
                • Feb 2011
                • 969
                • New Zealand
                Hi I have made corrections to schem2
                The inputs have been marked with left in and right in
                connect the signal to the points marked
                and connect the speaker terminals as marked.
                My pc
                  So did you lift the left side of the resistors R3942, and R3943 and feed the line level audio to those two resistors?
                  • joshnz
                    • Feb 2011
                    • 969
                    • New Zealand
                    Not my project it's Pentium's
                    Pentium had connected the inputs much earlier in the system,
                    I have marked where I think will be a good place to insert the signal at (R3942 and R3943) just after the muting circuit.
                    And for the outputs I have marked where I think is the best place to take the audio from to drive the speakers, and that is ferrite beads (fb3807 and fb3808) and (fb3809 fb3810)
                    before the relay RY3801 that sets the output to the internal speakers or the external speakers.
                    My pc
                    • pentium
                      • Mar 2006
                      • 2778
                      Ah, so I CAN tack in later on. The SRS circuitry was really confusing me. I'll give it a try tomorrow.
                      Find Nedry!
                      • pentium
                        • Mar 2006
                        • 2778
                        *pop*
                        *fizz*
                        Oops. Looks like I'm going to have to shim in another amplifier instead.
                        Find Nedry!
                        • ben7
                          Capaholic
                          • Jan 2011
                          • 4059
                          *pop*
                          *fizz*
                          lol
                          Muh-soggy-knee
                          • joshnz
                            • Feb 2011
                            • 969
                            • New Zealand
                            *pop*
                            *fizz*
                            What did u do?
                            My pc
                            • ben7
                              Capaholic
                              • Jan 2011
                              • 4059
                              Originally posted by joshnz
                              What did u do?
                              Probably connected a bunch of wires randomly to the board!
                              lol, just kidding, but yeah, its annoying when you fry something xD
                              Muh-soggy-knee
                              • claytongarcia
                                Issue with Sharp LC-42SB45U
                                by claytongarcia
                                I recently got a model Sharp TV, and I've noticed that the green power LED is flashing without any specific pattern. Additionally, there appears to be no voltage coming from the power board. I haven't observed any leaking or bulging capacitors, although the top of the larger capacitor doesn't seem to be perfectly flush with the jacket—if that makes sense.
                                Has anyone dealt with this issue before?​
                                03-10-2025, 07:27 PM
                              • Ven
                                Dell Latitude 3510 Overheating & Fan Control Issue – Need Help
                                by Ven
                                Dell Latitude 3510 (Intel Core i7-10510U) CPU Overheating
                                Issue Description:
                                1. CPU Overheating to 100°C
                                  • When I start the laptop from a cold state, it takes about a minute to reach temps around 80-90-100°C, and CPU thermal throttling triggers.​
                                  • When the CPU fan is running at full speed (by disconnecting PWM and TACH cables), CPU temperature stays around 50-60°C.
                                  • However, when the fan is connected normally to the motherboard, it does not kick in at high temperatures.
                                  • I also noticed a few times that the fan kicked in for a very short time, but it does not stay on consistently.
                                  • Thermal
                                02-12-2025, 03:57 PM
                              • leorivers
                                Issue with Sharp LC-47SB57UT
                                by leorivers
                                I bought Sharp LC-47SB57UT 6 years ago. I had to have a vhf antenna to pick up one local station(koco channel 5 OKC). It has worked great up until a week ago. Sometimes I couldn't get channel 5, now I can't receive it at all. I can hook up a digital convertor box I have from another tv and can receive channel 5.
                                I think the antenna and cable is ok. I doubt that this would be the tuner board or possibly something else.
                                Any ideas where I should start?​
                                10-24-2024, 03:11 AM
                              • vincentedel
                                Samsung SyncMaster 740n Phase Control Issue
                                by vincentedel
                                I'm having an issue with the Samsung 740n's phase control setting. When I use the automatic adjustment, it sets the value to around 54 (with a range of 0-100), and the picture looks clear and sharp. However, after some time—like after playing a game—the text starts to look blurry. When I auto-adjust again, it may increase the value to 80, and everything becomes sharp once more. Yet, after a while, whether it's a few hours or a day later, the same blurriness returns, and I have to adjust it again.
                                I'm using the Samsung 740n monitor drivers instead of the default plug-and-play...
                                04-22-2025, 12:33 AM
                              • rounin
                                MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                                by rounin
                                🛠 Original Issue
                                ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                                04-19-2025, 01:18 AM
