Chrysler Car Stereo - One Dead Channel
  • Oklahoma Wolf
    • Dec 2005
    • 353
    I'm currently working on a Chrysler/Infinity car stereo made by Mitsubishi. It came to me with the right front channel dead, and only half the display working. Got the display working no problem after resoldering some 40 bad joints throughout the deck, but would like a second opinion on the dead channel.
    When turned on, the right front channel gives me a short chirp and then goes dead silent. The other three channels work fine. Power amp section looks to be real simple, consisting of 4 Hitachi HA1388 chips, with supporting circuitry looking to have been copied directly from the datasheet itself. When run for a while, the right front 1388 chip runs hotter than the others.
    My question is, given how good the protection features on the HA1388 are, what are my chances I need to replace it? Methinks it's going into oscillation based on the chirp I get on power-up (not to mention the quality of the caps attached to that chip), but I'm not sure if I'll be able to easily get one of these 1388's to replace it.
    The cap compliment is all Towa general purpose 85 degree. The replacements can be no more than 15mm high. I was thinking of using Nichicon HE to replace them, as they're the only thing I can find to replace the 4 15mm by 15mm 2200uf at 16v caps (might as well do all 4 channels while I'm in here). The HE replacements for the big caps are 18mm in diameter but I think I may be able to get them in there - alternate suggestions are welcome though. Going to do the two resistors on the dead channel as well, just in case.
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: Chrysler Car Stereo - One Dead Channel
    i bet its just a dead chip.
    might want to do swaptronics to verify.
    most blown chips in these are from idiots attempting to add power boosters.
    95% of other failures are as you found.bad solder joints.
    • Oklahoma Wolf
      • Dec 2005
      • 353
      Cool - I'm in the process of locating a couple of dead parts decks, so I might scavenge them for the amp chips.
      Now that you mention power boosters, that makes a lot of sense. Chrysler/Infinity systems of this vintage used 20W booster amps on the system woofers that went bad often.
      These particular decks are the worst for the solder joints... I have another non-Infinity one that also had bad joints all over.
      Here's a pic of this deck if interested:
      • willawake
        Super Modulator
        • Nov 2003
        • 8457
        • Greece
        wow thats beautiful vintage looking
        • Oklahoma Wolf
          • Dec 2005
          • 353
          Not only that, it's a very rare deck - IIRC only available in the silver for 1987-1988 Chrysler New Yorkers with the Infinity speakers. Been looking for one on eBay, and finally got this one after 4 years of looking
          The three channels that work sound incredible. The power amp section is identical to my other non-Infinity version, but I don't want to use that one for parts as it too sounds awesome and is in just as good cosmetic shape:
          • arneson
            • Sep 2005
            • 1267
            Possability for a problem in the fader/bal control area?
            Jim
            • Oklahoma Wolf
              • Dec 2005
              • 353
              I thought about that too, and the 3 pots involved with the joystick control were quite dirty, but cleaning them twice did nothing to help. Everything else in that area looked ok. I might go looking for replacement pots though - they still crackle.
              • Oklahoma Wolf
                • Dec 2005
                • 353
                Quick update - the deck is now fixed. It was indeed just a bad chip - pulled one out of the older non-Infinity version as a replacement. Was a pain to install the replacement thanks to a double sided PCB that just would not desolder well, but I managed and all is well. Sounds incredible
                • Sik_6ty_Sixx
                  HH Scott Model A510 Stereo Integrated Amplifier/ Graphic EQ - Blowing fuses in the LEFT speaker channel only. Any Help???
                  by Sik_6ty_Sixx
                  So like the title says, I have an old Stereo Receiver/Amplifier that I picked up from the goodwill, it's a HH Scott Model A510. When I first got it home it had zero output. Opened it up, notice the fuses are missing. Pop in 2 new fuses (AGC4A 250V) and try again, within 5 seconds the L channel fuse POP! I don't see any visible indications of damage or arc burns on the PCB, no popped resistors or diodes, no burnt traces or blown out caps. So I decide to just try another new fuse, POP. Swapped around my R and L speaker wires, and checked the integrity of all wires and connections. Everything looks...
                  02-18-2025, 05:06 AM
                • eccerr0r
                  old X58 triple channel board... memtest86 memory speed?
                  by eccerr0r
                  Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
                  Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
                  Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
                  06-28-2025, 09:06 AM
                • spleenharvester
                  Reverse engineering of 18650 4-channel tester
                  by spleenharvester
                  Hi friends
                  I have reverse engineered this tester, schematic is attached and is complete except for capacitor values. These testers annoyingly have no model number but they are the ones you find on the first page of just about any website if you type in "18650 4-channel tester". There is also a 2-channel variant and a newer 8-channel variant. They are very cheap (about £15) and can measure voltage, current, internal resistance and capacity. They have a multicolour display for all these statistics. They also have terminal blocks so that if you want to use a breakout board...
                  05-04-2025, 02:43 AM
                • dicky96
                  American Audio VLP1500 Distorting on one channel
                  by dicky96
                  Hi guys I have a VLP1500 amplifier here - one channels works fine and the other channel distorts even at low volume settings
                  Protection and Clip LED are off
                  There is something wrong with the BIAS voltages around T16 and T18 (in particular) on the bad channel
                  I tested all diodes and transistors in this area in circuit with diode mode - both channels seem identical. Same in resistance mode across all the resistors here.
                  The output DC voltages on pin1 and pin8 of the 5532D dual op amp at the input of each amplifier module are the same, and the audio...
                  07-13-2022, 05:25 AM
                • dicky96
                  Hitachi V19B01922 Channel Tune problem
                  by dicky96
                  Hi Guys
                  I have a customer who has two Hitachi TVs in his bar, one is the model in the thread title and the other is a larger screen but has the same setup menu
                  He also has an LG TV, so three screens in the bar
                  I installed three Satlink ST-6503 DVB-T Modulators
                  This model https://www.aliexpress.com/item/32916553905.html
                  These connect to three satellite receivers via HDMI cables and then connect to a 4 way RF Amp that connects to the TVs on aerial cable. There is no incoming terrestrial antenna. I set the channel ID on the modulators to...
                  02-09-2023, 09:20 AM
