Kenwood from the Good Will store
  • Junk Parts
    Court Jester
    • Jun 2006
    • 8953
    I have a giant Kenwood reciever that I bought non-working for $5 bucks at the local Good Will store. I don't remember the model as I have had it packed away for years. It would fire up on one channel only. One of the two giant cap in the amp had blown its guts out the top of the cap body. Can these old style caps still found in good working order? I'm going to get the old turkey out, and try a recaping her. I think she is a mid to late seventies model. I wonder if this old Kenwood will have a warmer sound than my Onkyo. I am driving a pair of old Polk Monitor 10 speakers. The Onkyo is a high current amp rated at 104 watts RMS per channel but it just doesn't have that much "ass." This Kenwood it about the same size as the old Pioneer SX 1250 reciever @ 100 watts RMS per channel. Cheers!
    Mark Twain
    John Paul Jones
    Rod Serling
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Re: Kenwood from the Good Will store
    Sure; I have an old amp, well over 30 years, all caps in it are fine. Only thing wrong with it is that the volume knob introduces allot of crackle when it is touched...
    Also it for some odd reason did not have optical input so I've now retired it for the basement
    Caps where Nippon Chemicon
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      i get replacements at a local surplus store.
      midwest surplus in fairborn oh
      been sitting areound awhile so you should reform them first.
      by all means fix it up.
      looking at a sansui g 33000 here.
      recapping a marantz 140 as i type.
      • eccerr0r
        old X58 triple channel board... memtest86 memory speed?
        by eccerr0r
        Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
        Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
        Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
        06-28-2025, 09:06 AM
      • dicky96
        Hitachi V19B01922 Channel Tune problem
        by dicky96
        Hi Guys
        I have a customer who has two Hitachi TVs in his bar, one is the model in the thread title and the other is a larger screen but has the same setup menu
        He also has an LG TV, so three screens in the bar
        I installed three Satlink ST-6503 DVB-T Modulators
        This model https://www.aliexpress.com/item/32916553905.html
        These connect to three satellite receivers via HDMI cables and then connect to a 4 way RF Amp that connects to the TVs on aerial cable. There is no incoming terrestrial antenna. I set the channel ID on the modulators to...
        02-09-2023, 09:20 AM
      • sima112
        Marantz pm 6005 right channel not worknig
        by sima112
        Hi guys,
        I need a help with my Marantz pm6005. It started to have weaker the right channel a few months ago, than it got back to normal and now it has lost sound completely on the right channel. At the final stage it was loosing the channel for a while and than it returned. After it has disappeared completely I could forced it back by unplugging the source form CD (which I normally use) to phone and back. It would then work for a few minutes and died again. Now it is possible power up and all function works normally (apart the right channel ) on all inputs, except the phone both channel...
        01-30-2023, 12:11 PM
      • Logistics
        Supermicro X10DAX and Quad Channel
        by Logistics
        So my dilemma is that I can't seem to get my board to run in Quad Channel. I have an X10DAX with Dual E5 2690 v3's and originally it had four 16GB sticks of Samsung ECC. Figuring I needed to have a stick for each DIMM1 slot I purchased four more identical sticks of Samsung M393A2G40DB0-CPB. So, now I have eight 16GB sticks for a total of 128GB of RAM. When I install the ram so that Each DIMM1 slots is populated the system will not post even if I clear the CMOS, remove the battery, what-have-you. But according to what I'm reading in the Manual, which is admittedly not very clear, populating each...
        09-10-2023, 05:12 PM
      • CDNBrewer
        Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
        by CDNBrewer
        Hello Everyone,
        I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
        Symptoms:
        • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
        • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
        • I swapped the Left and Right surround
        08-05-2025, 09:29 PM
