Crate KX-80 Keyboard Amp fuse pops immediately
  • ajsemtb
    • Jul 2010
    • 79
    #41
    Re: Crate KX-80 Keyboard Amp fuse pops immediately
    oh, and I used the barrel caps on those ones that I asked about because the axial caps had a factory ESR of 44ohm, and that was way more than what was in there before, and the regular caps, though required some creative bending of the contacts, they had a similar ESR to the one that was not damaged. (I replaced both so they matched, but used the non damaged one as a reference.)
      There may be leaky audio stage coupling caps that no longer block out the DC voltage between audio stages.
      Does it pop when Master volume at '0'?
      • ajsemtb
        • Jul 2010
        • 79
        #43
        It "boofs" when turned on w master at 0 but no pop when turned off. The boof sounds like the speaker getting hit with voltage. I would think it shouldn't be that pronounced when turned on.
          If you can see the cone moves forward or backward at full cone extension, then you should fix it.
          Did it do this before? By the way, did you use the same value caps, it may be that the caps (in the pre-amp, which supplied by the resistors and the Zener Diodes) are charging up slowly due to higher values after the power amp section is already on.
          The rule of powering up sound system is to power up the preamp first then the power amp to avoid popping the speakers. Do in reverse order when powering down.
          • ajsemtb
            • Jul 2010
            • 79
            #45
            Yes it did it before. The high pitched squeal that happened when you shut it off is gone, so that's good . But the pop is still there.
            • corrize
              A funny fuse story – Lumix LX100 II
              by corrize
              Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
              I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
              The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
              There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
              And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
              10-19-2023, 09:58 AM
            • jesterace
              Samsung UE46ES8000 Blown fuse but no other signs of short
              by jesterace
              Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
              09-11-2024, 03:14 PM
            • jshhh
              Help replacing fuse on my Mimaki CJV300-160 vinyl printer
              by jshhh
              Hi guys,
              I'm inexperienced with electronics repairs, I've done a little bit of soldering caps and whatnot, but i have a blown fuse on this mimaki printer I got which I have bought a replacement for.
              How do I remove this type of fuse (see picture)...it kinda looks like it would pull out of that bracket but it didn't come at first pull and I didn't want to brute force it incase it's soldered on there like most of the rest of the components.
              Anybody know how to remove this type of fuse?
              (The fuse is toward the bottom of the image labeled F2)...
              06-17-2025, 01:35 AM
            • Babbar
              by Babbar
              04-12-2024, 01:12 AM
              Surface Mount Fuses Fundamentals Datasheet
              TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
              TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
              10-07-2024, 06:07 AM
