Crate KX-80 Keyboard Amp fuse pops immediately
    Re: Crate KX-80 Keyboard Amp fuse pops immediately
    The Diodes are shorted.
    The Zener 1N5353B 5Watts is 16V Zener Diode.
    http://www.digikey.com/scripts/DkSea...google&cur=USD
    So replace all 4 Diode, might as well order the Zener also, then power up and check the DC voltage across the Zener, it should be 16Vdc.
    • ajsemtb
      • Jul 2010
      • 79
      should I go ahead and order the capictors also? the burned looking ones...
        Yes, get them all from Digikey, might as well get the Pansonic FM series 105c rating.
        http://search.digikey.com/us/en/cat/...panasonic%20FM
        • ajsemtb
          • Jul 2010
          • 79
          dont have fm series in what i need. HA and HB available...
            Since we are dealing with linear power supply, then you can use general purpose but must be 105c RATING
            • ajsemtb
              • Jul 2010
              • 79
              #26
              OK, after all the searching, Digikey does not have the diodes I need in stock... is there another website? I usually use Digikey, so I don't know of another supplier..
              • ajsemtb
                • Jul 2010
                • 79
                #27
                btw, the diodes are 1N5392 1.5A 100V
                • ajsemtb
                  • Jul 2010
                  • 79
                  #28
                  i'm getting obsolete messages and not in stock messages at mouser, digikey, avnet, and a couple other sources from google... Any thoughts?
                  • mariushm
                    • May 2011
                    • 3799
                    #29
                    Farnell (Newark) has them :
                    1n5392
                    http://www.newark.com/multicomp/1n53...00v/dp/01P4232
                    http://www.newark.com/nte-electronic...-5a/dp/33C7847
                    1N5353B
                    http://www.newark.com/multicomp/1n53...lar%20Products
                    http://www.newark.com/on-semiconduct...lar%20Products
                    http://www.newark.com/on-semiconduct...7aa/dp/10N9629
                    As for capacitors, I think you needed 100uF 35v - there's no 100uF 35v in the Panasonic FM series, there may be in the FR series but I'm too lazy to look it up now (later edit: nope, same with the FR, only 50v rated ones).
                    Anyway, you can go up in voltage rating with no problems, so then you have more choices.
                    Panasonic FR 100uF 50v will do:
                    http://www.newark.com/panasonic/eeuf...ial/dp/74R3440
                    This Rubycon ZLH 100uF 50v is relatively close in specs to Panasonic FM and Panasonic FR 100uF 50v, should have about the same specs as a hypothetical FM 100uF @ 35v :
                    http://www.newark.com/rubycon/50zlh1...ial/dp/39K2793
                    This 100uF 63v Nichicon PM should be acceptable... not as great as Panasonic FM or FR or the Rubycon above but i'd say good enough...
                    http://www.newark.com/nichicon/upm1j...ial/dp/65R3647
                    You may be able to use this Nichicon KZ 100uF 50v (Muse audio grade capacitors.. though doesn't matter where the capacitor is located):
                    http://www.newark.com/nichicon/ukz1h...ial/dp/70R1183
                      You can go with higher Voltage and current rating for the Diode: 100v and 1.5A sounds kind of low to begin with.
                      http://www.digikey.com/product-detai...ICT-ND/1228202
                      http://www.digikey.com/product-detai...TPCT-ND/950500
                      • ajsemtb
                        • Jul 2010
                        • 79
                        #31
                        Thanks, order made. Now waiting on parts. Thanks for your help!!!
                        • ajsemtb
                          • Jul 2010
                          • 79
                          #32
                          ok, I got shipment #1 in. It had the caps and the zener diodes (what are zener diodes anyway, and what do they do?!) Installed those parts. The other 4 diodes had to be shipped directly from the manufacturer as they are not stocked parts anywhere, it seems. they should have been shipped out today so I'll have those in a couple days. Needless to say, i can't power on yet until those are in. Just wanted to give you all an update.
                          Oh, and I originally ordered the Nichicon 35v caps that matched, but also ordered the 50v Panasonics that were supposed to be better. I installed the 50v caps. I replaced all 4 (they were the yellow ones). Is there anyway to test the caps with a standard DMM that would tell me if they are bad? My DMM doesn't have the capacitance meter. I did however order the Peak Atlas ESR70 that should be here next week as well, so I'll be able to test all these caps that I've been saving from other projects to see which ones ACTUALLY failed, regardless of changing them ALL out.
                          • retiredcaps
                            • Apr 2010
                            • 9271
                            #33
                            http://en.wikipedia.org/wiki/Zener_diode
                            If the multimeter can't read capacitance, then there is no accurate way to measure uF. No multimeter can measure ESR.
                            --- begin sig file ---
                            --- end sig file ---
                            • ajsemtb
                              • Jul 2010
                              • 79
                              #34
                              Just a short update, I got my Atlas ESR70 meter in. It confirmed the 2 "burned" looking caps were bad, as well as the 2 that weren't burned seemed awful high ESR. Glad I changed all 4. Still waiting on diodes.
                              • ajsemtb
                                • Jul 2010
                                • 79
                                #35
                                *UPDATE* Ok, got parts in. Installed the diodes for the bridge rectifier, decided to use my new Atlas ESR70 meter and on the in-circuit caps to test before I add power... Glad I did. (or better yet, wish I'd had it when I ordered the last set of parts... >;F I found a cap that indicated >40ohms, removed it from circuit and retested. Failed miserably. It was a 3.3uf 50V axial cap. While desoldering it and trying to pull it out, I grabbed the wrong cap, and pulled the leg out of the cap. Its a 1uf 50V cap... So great. Now I need MORE Parts that I know frys won't carry.
                                At Newark, the Multicomp caps are .06-.08. The NTE is .35. I was going to order extras, as I always do JIC. Any problems with the Multicomp caps, or stick to the NTE? No panasonics aren't available....
                                Tested all the rest of the caps in circuit, most of them are <10uf and had ESR readings from 3ohm-6ohms. All different amount. None tested bad though. The ones that I felt were kind of high, I removed, retested, tested good, so reinstalled...
                                • ajsemtb
                                  • Jul 2010
                                  • 79
                                  #36
                                  and the 3.3uf 50v axial cap is not available. could I use a radial leaded cap instead?
                                  • ajsemtb
                                    • Jul 2010
                                    • 79
                                    #37
                                    OK, so I ordered the replacement caps, they will be here Friday. I ordered both the axial caps that are 3.3uF 63V (because the 50V were not available in axial) and I also ordered 3.3uF 50V "can" caps because they are the correct voltage. What I don't know, is which would be better? Anyone have an opinion? I know there shouldn't be anything wrong with going up in voltage, but can you use the radial caps in place of the axial caps?
                                    • 999999999
                                      • Sep 2006
                                      • 774
                                      The voltage on those is "probably" irrelevant (measure voltage while unit is powered on to be sure), when the uF value is so low it is just easier to make higher voltage parts that cover a wide array of circuits. Use what physically fits on the PCB better then what has better specs like temperature, ESR, etc.
                                      If you were to reverse engineer the subcircuits and determine the role of the capacitors, then we might better determine if there's any realistic expectation that choosing a different capacitor type would be an improvement and then there could be a need to measure operating voltage since other capacitor types like film, ceramic, tantalum, have lower capacitance density per area and space available on the PCB would be more of an issue. For example in the signal path a film cap could be desirable or for decoupling, either film, ceramic, or tantalum. However since it is located in the speaker enclosure some ceramics may not be ideal as the vibrations can affect their performance.
                                        if the audio coupling was 3.3uF, you can use 4.7uf (most of the 1. 2.2. 3.3, 4.7uF will be rated at 50Vdc which are fine) it will give more extended low frequency response. In the high end audio if they use electrolytic for coupling, they will also use a small value cap (0.01uF polyester, non-inductive type, or ceramic) in parallel with the coupling cap. I do not have golden ears, some people do not want to use any coupling cap between audio stage at all.
                                        • ajsemtb
                                          • Jul 2010
                                          • 79
                                          #40
                                          update, it works! Replaced 8 caps, 4 diodes, 2 zener diodes, and put it back together. Now, it is functioning as well as it did before it died, however, it still "pops" loudly when turned on, and off. Is there any reason for that? If its not a "oh that's a problem with the ...... and you just have to replace ....." then I'm not going to tear it back apart. If its a simple thing, I'll open her back up. Thanks again for all your help! Again, you have fixed yet another piece of equipment, and saved it from the trash!
                                          • corrize
                                            A funny fuse story – Lumix LX100 II
                                            by corrize
                                            Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                                            I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                                            The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                                            There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                                            And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                                            10-19-2023, 09:58 AM
                                          • jesterace
                                            Samsung UE46ES8000 Blown fuse but no other signs of short
                                            by jesterace
                                            Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
                                            09-11-2024, 03:14 PM
                                          • jshhh
                                            Help replacing fuse on my Mimaki CJV300-160 vinyl printer
                                            by jshhh
                                            Hi guys,
                                            I'm inexperienced with electronics repairs, I've done a little bit of soldering caps and whatnot, but i have a blown fuse on this mimaki printer I got which I have bought a replacement for.
                                            How do I remove this type of fuse (see picture)...it kinda looks like it would pull out of that bracket but it didn't come at first pull and I didn't want to brute force it incase it's soldered on there like most of the rest of the components.
                                            Anybody know how to remove this type of fuse?
                                            (The fuse is toward the bottom of the image labeled F2)...
                                            06-17-2025, 01:35 AM
                                          • Babbar
                                            by Babbar
                                            04-12-2024, 01:12 AM
                                            Surface Mount Fuses Fundamentals Datasheet
                                            TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                                            TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                                            10-07-2024, 06:07 AM
