Philips FCD565 midi system ~1987 - Transformer buzz
    Re: Philips FCD565 midi system ~1987 - Transformer buzz
    Is there a plug at the end of the grey/red cables (two greys and one red) on the power supply board to the main board, they are the secondary side of the winding of the transformer, if you can disconnect the cables then you can install the transformer back in and power up and it will not have any load on the secondary side if we disconnect the grey/red cables.
    • quattro alex
      • Mar 2012
      • 92
      The one red wire goes to the top pcb (8204 090 45003) on connection D112. and the two grey's go to the main board. I have highlighted these in red.
      I have removed these connections leaving just the yellow and black wires connected (highlighted in purple)
      Transformer has been soldered back in and is still buzzing unfortunately
      Fixed so far: GNR TS902W monitor, Sony Game Gear, Philips FCD565, Arcam Alpha 10, Memorex SA 404amp
      • quattro alex
        • Mar 2012
        • 92
        This lacquer is available down the road, is it suitable ?
        http://www.toolstation.com/shop/p44132
        • 999999999
          • Sep 2006
          • 774
          ^ Looks like it might work but being a spray does it come with a straw or else you have one that will fit? It needs some way to get into the tight areas for highest likelihood of success. Might work without a straw if you take off the copper belly band and the steel wrap around the core to apply it, then spray again after the steel wrap is put back on (or leave it off).
          • ben7
            Capaholic
            • Jan 2011
            • 4059
            Did you test the big filter caps and replace any bad ones?
            Muh-soggy-knee
              You mat as well take a reading of the voltage of the secondary side so you will know what the AC output voltage is if you need to get the new transformer.
              • quattro alex
                • Mar 2012
                • 92
                I have replaced 20 caps on the main board, 7 on the top board and 5 on the equaliser. The main filter cap has been tested with an ESR of 0.03
                I have just picked up some PCB lacquer from maplins so I will have a go at the transformer this evening. I will also take some voltage measurements from the secondary side aswell.
                • quattro alex
                  • Mar 2012
                  • 92
                  Ok so I've removed the steel outer band to reveal the copper belly band, and you can see from the photo that the joint is already cracking. I have also removed the plastic cover around the copper coils.
                  I am assuming I can get spraying at the copper coil section and then once dry reinstall the plastic cover and copper belly and finally the outer metal band and then spray those components as well?
                  • 999999999
                    • Sep 2006
                    • 774
                    ^ Yes. Also spray the core laminations, around the perimeter, in the holes, in the slight gaps on the sides of the coils. I'd probably put some masking tape or similar over the pins on the bottom so you don't have lacquer to clean off, though some types allow soldering still, it just burns or melts off when soldering.
                    Be sure to put a lot on, enough that it's dripping off and really saturating the coils. Once dry, decide if it needs another coat. It may take a long time to dry, if the air dry type then a fan may speed that up or you might want to leave it outside as it may stink from fumes. It may be difficult to get the copper belly band soldered back together again, I suspect a pencil torch would work as well as a soldering iron unless it's a quite powerful iron... but might as well try an iron first.
                    • quattro alex
                      • Mar 2012
                      • 92
                      999999999 - Thank you for your advice - it gave me the confidence to go ahead. I used the nozzle from an air spray can with a straw and directed it into all the nooks and crannies and used copious amounts. I repeated this process 3 times allowing time to cure in between coats.
                      The copper belly band was quite difficult as it was soaking up all the heat from the iron, but I got there in the end. Unfortunately I couldn't get the external banding to fit tightly so I used some electrical tape around instead.
                      Anyway the end result is a silent transformer! My colleague has tested it and he is delighted - he thought it wasn't working initially as he was so used to noises when switching the unit on.
                      Thank you to everyone who's helped me in this post.
                      • zombie.guitarist
                        Reading Serial Midi data with an oscilloscope
                        by zombie.guitarist
                        Hey all, I have one last thing I'm looking to fix with my Synthaxe. This time, the schematics I have are actually the same as the PCBs I have.
                        The Synthaxe, works as its a guitar midi controller hooked up to a floor pedal. Thats the most basic way of using it, and it has a midi output. You also can connect a console to it, that stores your tunings and other things. The console has 8 midi outs, as well as a midi in and midi thru.
                        When I first got the unit, I thought I was using it wrong, but it turns out its just broken. The 8 midi ports on the console don't output...
                        07-05-2023, 09:29 AM
                      • ohren
                        Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
                        by ohren
                        Hello!
                        I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
                        Measured voltages with no load:
                        After rectifier diodes
                        12V: 6.17 V
                        5V: 5.67 V
                        Secondary transformer pins AC measurement (really don't know if this says anything)
                        12V: 2-2.5 V
                        5V: 1.04 V
                        I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
                        03-18-2023, 10:33 AM
                      • mikey5791
                        Is it possible for transformer substitution?
                        by mikey5791
                        Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
                        Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
                        My questions are
                        1. How do i test to see if the transformer is in good working condition?
                        2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
                        Hope you guys understand what i was asking. My intention is...
                        11-03-2022, 02:11 AM
                      • dennis_elx33
                        3PHASE STEP-DOWN Transformer in Check
                        by dennis_elx33
                        Hello All,
                        i would like to post an interesting topic regarding 3-phase stepdown transformer which we suspect to cause an overcurrent (138A) which resulted to power tripped off of the HV power supply (80KV output).
                        Problem statement: Power tripped Off
                        Initial Problem: Found 2 IGBT and 2 rectifier diodes shorted (burnt).
                        Action Done:
                        1) Replaced the faulty parts with good spare.
                        2) Measured impedance of the 3phase input lines and found that L2 to L3 has 23.3ohm while other pairs are 51Kohm. This pins will...
                        12-02-2024, 06:52 AM
                        ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) Book Specification for Upgrade or Repair
                        This specification for the ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T101HA - X5DHD boardview and T101HA - X5DHD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                        09-06-2024, 04:40 PM
