Has anyone here Repaired the LCD screen to a Korg X-50 Keyboard?
  • Paul678
    • Nov 2011
    • 402
    Sorry if this is in the wrong forum, but thought
    it couldn't hurt to ask.
    This guy has a Korg X-50 was a non-working
    LCD screen. I found a replacement here:
    http://www.syntaur.com/4600.html
    But there is no guarantee it's only this part
    that is bad. He also said he tried to fix the power
    supply, which also went bad. That's not good news,
    because most likely he made it worse.
    He wanted $80, but I'm thinking I should offer
    around $30-40, due to the fact that I may not be
    able to fix it properly.....
  • smason
    • 1652
    Re: Has anyone here Repaired the LCD screen to a Korg X-50 Keyboard?
    Bit of a gamble as to whether it's the display or the driving electronics.
    My rule of thumb for buying broken things is never pay more than 1/2 of the going used price, and that's if I'm fairly confident I can fix it.
    If he wants 80, I'd try your ide of 30-40 you can always meet at 55ish.
    • redrooster
      • May 2011
      • 114
      I know this is an old post but if you haven't fixed it or whatever you can try and rub the ribbon cable that goes to the LCD screen with a pencil eraser,it usually fixes it.
      HP P6-2203a desktop,AMD CPU A8-5500 with Radeon HD7560D,3.20Ghz. Radeon HD 6670.8Gb Ram.2TB HDD. WIN 10 64 bit O/S.
      • Paul678
        • Nov 2011
        • 402
        The original LCD screen was completely cracked. He
        dropped something really hard on it.
        I bought the rather pricey replacement on Syntaur,
        and a power board from someone locally, and
        now it works great!
        Korg X-50 for about $150......SWEET!
        • Ryan.man
          by Ryan.man
          02-04-2025, 12:23 PM
        • reformatt
          by reformatt
          07-31-2025, 08:37 PM
        • smic717394
          by smic717394
          07-25-2024, 10:16 AM
        • Chrissygizmo
          by Chrissygizmo
          02-10-2025, 12:33 AM
        • pappothar
          Lenovo legion 5-15ach6h IT8227E-192 CXA shorted, repaired but no screen / no boot
          by pappothar
          hi
          i bought a defective legion, tested it had the IT8227E-192 CXA shorted.
          I ordered on aliexpress, carefully changed it under microscope, and now when i plug the dc in, keyboard flashes in all colors in loop, on button is white, and nothing more
          The battery led is charging, it seems is the only thing that works
          Screen is off, nothing, not even the backlight
          could it be a non programmed IT8227E ?
          Awaiting for your feedback
          Thank You
          Stefano
          09-15-2025, 08:37 AM
