Cat + snowglob = dead sub
  • Marsman
    • Sep 2011
    • 17
    I am trying to repair an Aiwa TSW-45 subwoofer after my cat knocked off and busted a snowglob on. I am trying to cross all of the semis. I have found replacements for all of the transistors but I am having trouble with the Mosfets because they have ben discontinued. Does anyone know of a current replacement for a 2SJ460 and a 2SK2158. I have tried looking thru the datasheets to try and cross them. I would be nice if they would all list the same specs. I got out of school before FETs were popular and therefor don't know which specs are the important ones.
  • mariushm
    • May 2011
    • 3799
    Re: Cat + snowglob = dead sub
    Have you tried alibaba.com?
    The people there usually have minimum orders of 5-10 pieces but you may get lucky requesting samples...
    http://www.alibaba.com/trade/search?SearchText=2sk2158
    http://www.alibaba.com/trade/search?SearchText=2SJ460
    • Marsman
      • Sep 2011
      • 17
      Has anyone done business with them? How does it work?
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        have never trusted them enough to try.look up the specs of your parts and try to match on digikey.
        • Marsman
          • Sep 2011
          • 17
          That's been my problem. Since I am not familiar enough with FETs I don't know which specs are the important ones and that no two will list all of the same specs (even by the same manufaturer), I haven't felt comfortable about choosing one.
          • hardwareguy
            • Jun 2006
            • 405
            First and foremost...breakdown voltages and maximum drain current. Rds on is not that critical for amps, lower is better.
            • Marsman
              • Sep 2011
              • 17
              I am looking at the BSS138LT3G to replace the 2SK2158. Would this be an acceptible replacement? Would I have to change any bias resistors? These are used in the buffer amp and the auto power switching sections of the sub.
              • Marsman
                • Sep 2011
                • 17
                I am also looking at the ZVP4105A to replace the 2SJ460. I am concerned if these replacements are acceptible because the orginals have a Vgs of 7v and the replacements have a Vgs of 20v.
                • Scenic
                  o.O
                  • Sep 2007
                  • 2642
                  that site suggests the 2SK1590 / 2SK1591 as a replacement for the 2SK2158
                  http://english.electronica-pt.com/db...hp?ref=2SK2158
                  According to Renesas, the 2SJ461 is the official substitute for the 2SJ460
                  http://www2.renesas.com/maps_fronten...product=2SJ460
                  dunno how accurate this is or if the substitues are still available though.. :|
                  • Marsman
                    • Sep 2011
                    • 17
                    Those replacements aren't available either. But after looking at the specs for them, the ones I am looking at have similar Vgs and Rds values. So if the ones you listed are valid replacements the ones I listed will work.
                    • double_DD
                      How can I be sure that my EC chip is dead?
                      by double_DD
                      As the title suggests, how can I be sure that my EC chip is really dead?
                      I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                      Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                      03-12-2025, 07:47 AM
                    • connorcc2005
                      Thermistor specs and cross reference
                      by connorcc2005
                      I'm getting some conflicting information and thought I'd toss it out to all of you for input.
                      What I have is a TTC-104 thermistor. This is part of a temp sense circuit that will drive a small 12v fan to cool components mounted to SMPS heat sink.
                      The physical diameter of the piece is 5.1mm measured with a caliper.
                      Other than what you see in the pic, there is no other writing on the part.
                      My research of the TTC-104 says it should read 100 ohms at 25C. Out of circuit measurements have it at approximately 100k. It does change as the temp changes....
                      06-16-2022, 04:16 PM
                    • disorder
                      ps5 edm-033 dead after hdmi/usb ports destroyed
                      by disorder
                      hello guys,
                      i need help to repair a edm-033 ps2
                      history : as always hdmi port and usb ports destroyed after unplugged
                      after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
                      so i changed it
                      now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
                      but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
                      i don't see any projection of liquid metal on pcb.
                      01-14-2025, 12:48 PM
                    • Beton
                      Finding a dead short component
                      by Beton
                      Hi guys!
                      I searched for the term "dead short" in the forum but no specific thread came up however if I'm just blind and couldn't see the thread talking about this please forward me to that direction.
                      So my problem is I don't know how to find the source of a dead shorted voltage rail. Dead short = ~0 ohm resistance.
                      I have two VGAs (HD 4850 and HD 4870), both dead shorted to ground on the memory rail. I have the boardview file for the 4870 and the memory rail consists around ~7892346 capacitors...
                      I have a bench PSU and if I try to inject voltage the voltage...
                      12-10-2021, 01:05 PM
                    • zunasthegreat
                      Chieftec GPS-450-AA with dead 20N60C3
                      by zunasthegreat
                      Hello everyone hope all doing well!
                      I have this PSU (GPS450-AA delta oem) around for like 4-5 years and I had it recapped early 2020 or 2021 with mostly UCC KY and Nichicon PW's. The bulk was and still is fine, the original Ltec's were bloated and empty. The previous issue was some major coil whine noise and at times random shutdowns when going idle. Today it started tripping the mains breaker and I think I have dead APFC mosfets (20N60C3). Right now upon checking I have the Q1 and Q3 FETs dead so far and I guess those are responsible for the PFC circuit. The only thing I care is If there...
                      09-01-2024, 07:12 PM
