Tannoy Reveal 6D
  • Khron
    • Sep 2006
    • 1350
    • Finland
    #181
    Re: Tannoy Reveal 6D
    "Bypass switch", as in, the mute switch? Or...?
    Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
    • micdim
      • Apr 2021
      Yes the mute switch. Thanks!
      • Khron
        • Sep 2006
        • 1350
        • Finland
        #183
        It isn't anything special, nor does it need to conduct any meaningful amount of current. Your biggest concern is to find something that's mechanically compatible, so... You or your tech will just need to remove the little front plate and start digging through parametric searches on parts distributor websites, I'm afraid.
        • micdim
          • Apr 2021
          Yes I will will convey this to my New Tech. My previous Tech doesn't seem to want to do the research work.
          Thank you!
          • midibob
            • Nov 2008
            • 285
            #185
            Well, after starting this thread all those years ago my other 6D failed the other day with the speaker cone almost jumping out the box and a loud hum.
            On strip down I found the -15v supply resistor had failed (220R 5W). When replaced I noticed it was running far to warm for my liking. This was due to the digital board which I don't use so it was disconnected as I couldn't be bothered to fault it.
            All now fine.
            • Valden
              • Sep 2016
              • 49
              I've just completed my latest repair of a Tannoy Reveal 6D monitor. It was making a crackling noise on start-up, which would last for ten or twenty minutes, if not more. The audio output would be cracking too. But it would go away and the sound would eventually be fine. I suspected capacitors. (Edit - my kids told me it was making a very annoying high pitched sound as well, but I couldn't hear that. I'll ask them if it's gone.)
              Upon disassembly and diagnosis with an audio probe and separate amplifier I found that the crackling sound was not present at the output of the filter board or at the input to the amplifier ICs on the power board but was present at output pin 10 of both amplifier ICs. So, it was likely to be a problem with the power supply on the board, rather than one of the amplifier ICs. Probing with a multimeter showed that many of the electrolytic capacitors were even weirder than they usually are when assessed while mounted. I removed all of the electrolytic caps (except the two, big, 10,000 uF ones). About 70% of these were dead or way off. Two of the resistors (no 19 and 21) were also out of spec. I replaced all of the small electrolytic caps and the two resistors at a cost of about $5. This Tannoy Reveal 6D monitor is working again. Yay.
              But the main reason for writing this note is to describe the disassembly and reassembly process, which is tricky, given how there are hidden screws underneath the heat-sink and the transformer. Dealing with these could be fun - or not. Let me describe what you will find and how you might proceed.
              There is an aluminium plate onto which all of the monitor's main elements are mounted. This is held into the wooden speaker box with six, 3mm hex cap screws.
              The power board is mounted onto the plate with five screws with flat, countersunk Phillips No 2 screws, which are hidden underneath the heat-sink.
              The large heat-sink is screwed onto the plate with eight screws from the inside. Seven of these are round headed Phillips No 2 screws. Some are hard to get at due to the power board. One of the eight screws is a flat, countersunk screw with a Phillips No 2 head. This one is hidden underneath the transformer. (Note that it has the same thread and head as the screws for the transformer, but is shorter than those four screws.)
              The transformer is mounted onto the plate with four flat, countersunk screws which have Phillips No 2 heads. These act as bolts, onto which 7mm nuts are fitted from the inside. The top two of these bolt/screws are hidden underneath the heat-sink. As such, if the heat-sink is still in place, they can't be held with a screwdriver while the nuts are loosened. It becomes a chicken and egg situation as you try to remove either the heat-sink or the transformer, so that you can remove the power board.
              First, undo the seven round headed screws which hold the heat-sink onto the plate from the inside. The last, hidden screw will still hold the heat-sink onto the plate, but it will pivot. Be careful that its pivoting action does not damage switches on the filter board. To pivot the heat-sink so that the screws for the transformer are Revealed (the real reason for the monitor's name!) remove the power cable socket and the power switch. Pivot the heat sink, smearing white heat paste everywhere, then hold the transformer's screw heads with a screwdriver so the corresponding nuts can be loosened. Or, another way could be to use a cold-chisel and hammer to shear through one or both of the top two screws that are holding the transformer on. Or use a hacksaw blade to cut one or both of them. This is what I did. First a hacksaw blade cut through half of right-hand screw, then a chisel cut the remainder. With only one partly loosened screw holding the transformer on, it could be pivoted to Reveal the last screw that was holding the heat-sink on. Ta da! The heat-sink was removed, then the power board. I left the transformer loosely connected to the plate and put it aside.
              For reassembly, the best thing to do is to use strong epoxy to fix the transformer mounting screws into the plate, so they will remain still while their nuts are being tightened later. With these screws glued into place, the power board can be installed (using thermal paste for the ICs and thermal fuse), then the heat-sink can be installed (using thermal paste) and lastly the transformer. But do a brief performance check before full reassembly. Brief, to avoid cooking the amplifier ICs, which will be lightly screwed onto the aluminium plate for this test, but without the large heat-sink in place.
              Or course, if you want to be able to reuse the transformer mounting screws, destructive removal is not advised.
              But most of all - feel encouraged to dive in and fix your Tannoy Reveal 6D or 8D monitors. Chances are, if you're reading this you've already become adept at repairing them. :-)
              • andymees
                • Jan 2025
                #187
                Hi All
                Bit late to the party, but I've got a pair of Precision 6Ds here and one of them just died on me. I'm not an electronics whiz sadly, so it's unlikely theres anything I can do to fix it, but I was hoping I might be able to get hold of the schematics so that I can provide them to a suitable tech, if I can find one. Tried the links in post #28 put obviously its been a while and the links seem to be dead now. Is anyone able to help out with a new link?
                If it's of interest, the issue with the (right) monitor is that sound output has cut out... it powers up ok, but theres no sound... except when I power off, when, just for a brief moment as I cut the power the speaker will burst into life and the missing sound outputs, as normal, just for a second.
                Huge thanks in advance if anyone can help with those schematics
                Cheers
                Andy
                • midibob
                  • Nov 2008
                  • 285
                  #188
                  Try here...
                  https://elektrotanya.com/tannoy_reve.../download.html
                  • andymees
                    • Jan 2025
                    #189
                    Thanks midibob! Perfect.
                    • willis6732
                      LTO PS 4LA Powerred Speakers - Tweeter Audio Low
                      by willis6732
                      Hello, I have two of these speakers with the same Prioblem. The tweeter volume is very low. I believe it happened after running them too loud.
                      There is a lightbulb on the tweeter output i tried shorting and no change.
                      The tweeters measure 6 ohms and it seems to play loud if i plug them into an alternate amplifier
                      There are a couple resistors and diode getting really hot in the mute circuit...
                      At the bottom left of image. R17 gets the hottest. Over 70 deg C
                      Z1 and R7 next to that get hot as well. Zener tests ok
                      I measured the...
                      11-02-2023, 06:14 PM
                    • goodpsusearch
                      Speakers damaged from children. Can this tweeter be repaired?
                      by goodpsusearch
                      I got these speakers that seem to be damaged from the previous owners small children.
                      As you can see on the first pic, the tweeter's outer membrane has been totally ripped.
                      I also post another pic with the other speaker that survived...
                      Is this beyond repair?
                      I have no clue about soft dome tweeters.
                      12-26-2023, 05:18 PM
                    • Topcat
                      Topcat's Ultimate Pentium 4 Retro Gamer!
                      by Topcat
                      I'll open this build with the comment that the Pentium 4 processor was probably my least-favorite CPU; even in Xeons. Netburst processors were hot-running and quite unimpressive performers considering the high clock speeds....but they were capable to a certain extent.....and are now entering the peculiar era of 'retro-ness'.
                      With that said; I was given THIS LITTLE JEWEL last Friday....a gaming rig built on the very CPU I liked the least....but there were some interesting things in it to say the least....and I really don't have a really good P4 retro gamer in my fleet....so....hmmm...yea...lets...
                      03-07-2022, 08:20 PM
                    • freak
                      JBL LSR25P amplifier chip overheating
                      by freak
                      I have a set of JBL LSR25P speakers in which one had a popping noise about once every 2-3 seconds. A local tech (who only worked on pro equipment) bet without looking it was a bad cap. So I replaced all the caps and the problem persisted. The board has 3 LM3886 amp chips. 2 of them appear to be a push-pull setup and drive the woofer. The other one drives the tweeter. I powered it up and noticed that the LM3886 that ran the tweeter was extremely hot. The other two were room temperature. The datasheet stated that it has thermal overload protection and will shut down at a certain point and then restart....
                      04-06-2023, 07:30 PM
                      Boston Acoustics HD8 – build quality impressions & DIY woofer surround repair
                      by momaka
                      Boston Acoustics fans, this thread might not be for you.
                      A few years back (~2018 time frame), I picked up a set of free JVC speakers from someone on Craigslist that no one seemed to be interested in. The guy also had a single Boston Acoustics HD8 speaker – yes, just one cabinet. He said he had no idea where he got this one from or why it's only by itself. But like the JVC speakers, it was going to get tossed at the end of that week… so I came to collect, as usual. And that's all I know about this HD8. After all, I figured why not take it and see what's inside… show it to the...
                      01-30-2022, 11:57 PM
