Troubleshooting Harman Kardon TS-14 Subwoofer
  • Jdog420
    • Jun 2011
    • 15
    Found this cool site while looking for some answers on my sub. Started off intermittent, switching it on and after a minute of thumpage, going into standby. Now when I switch it on, it is trying to turn on but it cycles back into standby, continually. I took it apart and damage wise it looks to be this. Apparently it overheated and melted the coating, but am somewhat newbage and am unable to figure out what the specs are to this, resistor?
  • Dgtech
    E. Technician
    • Apr 2009
    • 1462
    • Steeler
    Re: Troubleshooting Harman Kardon TS-14 Subwoofer
    From what I can make out (pics too small), It's an inductor. They rarely go bad and will work with the melted outer shell. What makes these hot is whenever there is too much current going thru them. I can't make it out but it looks to be a bad cap or two near it. These will need to be replaced but it would be nice to see larger pictures of the whole board to make a proper determination. Use "Manage Attatchments" just like you did but larger pictures. Not too large though.
    • Jdog420
      • Jun 2011
      • 15
      Cool, working on the bigger picture. I was disappointed myself when I clicked on it.
      • Jdog420
        • Jun 2011
        • 15
        Resized photos in.
        • seanc
          • Nov 2008
          • 1319
          Yes there are two bad caps there.
          • lti
            • May 2011
            • 2557
            They leaked all over the board too. You will need to clean the residue off of the board.
            Harman Kardon likes to use crappy caps and place them in very warm locations. I found that out while repairing a set of Harman Kardon computer speakers.
            • Longbow
              • Jun 2011
              • 623
              I'd like to see any other boards that are part of the subwoofer also. The main focus at the moment is to remove the inductor and the 2 caps and start cleaning the pc board to remove the conductive electrolyte that spilled. Also look carefully at the bottom of the board where these parts are soldered, as the fluid might have done damage underneath as well.
              I'm wondering if the board we see in the photo is a power supply? The inductor is a high current high value (ferrite core) part, connected to a NP cap. Those parts might actually be part of the subwoofer's crossover/low pass filter for the audio. Let us know the results after cleaning and replacing the caps.
              Is it plugged in?
              • Jdog420
                • Jun 2011
                • 15
                I was gonna take it to the local electronics guy, but appears he isn't open anymore or moved. Looking at irons ( don't have any tools) and replacement caps right now. I'm gonna take the boards apart and post some more pics tomorrow.
                • Longbow
                  • Jun 2011
                  • 623
                  This is something that YOU can fix! All you need is an old toothbrush, a soldering iron and some alcohol or lacquer thinner to clean the board. Caps can be ordered from Digikey, Mouser, Newark, etc for a few bucks. Here's your chance to be a hero!
                  Is it plugged in?
                  • Jdog420
                    • Jun 2011
                    • 15
                    Thanks for the push Longbow, I usually do surprise myself when I tackle something. I have a habit of talking myself out of things, but once I get into them, turns out they aren't as bad as I perceive them to be. I did take go to a vocational Industrial Electrical Maintenance program, that lightly touched on solid state electronics. However not as in depth as I would have hoped it to been. Looking at this makes me want to go to an actually electronics program. Here are some picks of the rest of the boards. Does they look like quality workmanship to you guys?(made in China, which you guys probably already knew)
                    • lti
                      • May 2011
                      • 2557
                      Those boards don't look bad. That is typical Harman Kardon quality.
                      If the amp runs hot, a full recap might be needed. In the computer speakers I mentioned above, almost every cap was bad.
                      • Longbow
                        • Jun 2011
                        • 623
                        If we are talking subwoofers with internal amplifiers, it is absolutely certain that the electronics will run hot. The boards are mounted inside the cabinet along with lots of fiberglass insulation (for audio purposes). But that doesn't mean that every part is in immanent danger of failure. Jdog, get yourself a soldering iron and some solder wick and a few supplies. The knowledge and experience I've seen presented on this forum is far more than you'll ever get at the tech school. I'm very big on hands-on. Remember, if it is already broken, you can't do much worse trying to fix it!
                        Is it plugged in?
                        • Jdog420
                          • Jun 2011
                          • 15
                          Good point Longbow. I have been checking out some amplifier circuits on buildingGadgets.com, and figure I want to get into it as a hobby. As I play guitar, and wouldn't mind being able to tweak some things here and there or make a little amp. I'm looking at irons, have been going through the Test Equipment Usage, Techniques, and Reviews and gonna make a decision soon, very soon. Not gonna buy a cheapie, but can't go high end. No Bass = Bad
                          • hardwareguy
                            • Jun 2006
                            • 405
                            Want a cheap, reasonably well behaved soldering station....look at the Weller WLC 100. Its a simple unit with coarse thermal control but it works and is available for around $40 USD. I use one and once you get a feel for what number on the dial corresponds to what size joint you want to rework, its a good unit.
                            It comes with a small chisel tip, add on the fine conical tip for smaller circuitry. Tips are of good quality, WAY better than the tips you find on cheap "fire stick" type irons. I actually am still on my first tip 6 months in, with an old Radio Shack or ECG iron, I'd have gone through at least 3 tips due to their poor coatings.
                            If you have more money, step up to the WESD51....that's about the cheapest thing that I'd call a "real" soldering station. Buy one of these or a WD1 if you get serious about electronics. See Hakko's stations as well, they are comparable.
                            As for multimeters....you CAN NOT get a good, safe meter for under $20 new....I've tried. All of them came with terrible leads and questionable components. Don't skimp too much here....My multimeter has literally saved my life a couple of times. (Test before you touch...and test again!) Excellent units with good reliability and safety features can be found for $35-50, good True RMS units can be found for about $100 new. If buying used, dont get one that's too old....if it lacks an IEC 61010 -1 classification (Category rating), its too old for my tastes as it may or may not have modern safety features. For electronics, you want at least a Cat II unit.
                            • kaboom
                              "Oh, Grouchy!"
                              • Jan 2011
                              • 2507
                              And absolutely none of those "830" meters, or their clones (of clones).
                              "pokemon go... to hell!"
                              EOL it...
                              All style and no substance.
                              guilty,guilty,guilty,guilty!
                              guilty of being cheap-made!
                              • Jdog420
                                • Jun 2011
                                • 15
                                Thanx guys, I think I have narrowed it down to that Weller WLC 100 and the Goot PX-201. I'd go with the Weller WESD51 If I was working (been holding out to see if this one i got on a line goes through). But yea as far as the DMM, I so want a Fluke. Been checking Craigslist and ebay, but hold their value quite well. Ive used them (company supplied) and they are awesome. Funny you mentioned the under $20 category. I bought some POS from Marcs for like 4 bucks just to check really low voltages. One day i felt the need to check an 110v outlet, and blew the leads off. MUhahaha!!
                                • Th3_uN1Qu3
                                  Believe in
                                  • Jul 2010
                                  • 6031
                                  • Romania
                                  The 830s are (reasonably) safe if you use proper leads with them. I own three... But for a more serious meter, if a Fluke seems too expensive i recommend the Uni-T UT60E. I have little to complain about it, and where i do have complaints it's minor things.
                                  A working TV? How boring!
                                  • kaboom
                                    "Oh, Grouchy!"
                                    • Jan 2011
                                    • 2507
                                    Uni-T UT60E.
                                    MCM's 72-7740 is the non-TRMS w/o RS232 version of that. 72-7735 has RS-232, but is not TRMS.
                                    EOL it...
                                      On the subject of multimeters I use a BK 2709B and it works well but will set you back nearly $100. Very nice inside (good safety features), true RMS and the first auto and manual ranging capacitance test I have seen on a multimeter to date!
                                      • Jdog420
                                        • Jun 2011
                                        • 15
                                        So got some things to gear up for the attempted fix. Bought a Hakko FX-888 and well what are supposed to be rubycons (can any of you spot fakes?). However I think I had a fail in the caps department, the temp is only rated 85C while the OEM are 105C. Maybe not a big deal, but the OEM are noticeably larger.
                                        • viewfindr
                                          Harman Kardon Soundsticks III Bad subwoofer, low bass
                                          by viewfindr
                                          I have a pair of rarely used computer speakers. Recently, I noticed that the subwoofer was barely working. Both satellites are still good, but even when turned up all the way, the subwoofer is extremely weak and produces almost no bass. It definitely still outputs a little bit on the deepest notes, but is far from what it should be.
                                          I took it apart, and the subwoofer driver measures about 17 ohms on a multimeter. I couldn't get figure out how to get the board out, but attached some photos (cables attached are affixed to the housing). The caps look good to me (no bulging or leaking),...
                                          03-21-2021, 03:47 PM
                                        • funky2x
                                          Harman kardon onyx studio 7 Smd code
                                          by funky2x
                                          Cant find what smd code Y0DVA.
                                          sitting in Harman kardon onyx studio 7. Appreciate any help.
                                          05-29-2025, 03:44 PM
                                        • PowellSkier
                                          Cement resistor swap in Harman Kardon AVR
                                          by PowellSkier
                                          Would I be able to swap a 0.27 Ohm Kx2 5W resistor for a 0.22 Ohm Jx2 5W resistor in a Harman/Kardon AVR? Cement type.
                                          06-04-2024, 06:41 PM
                                        • PowellSkier
                                          Harman/Kardon AVR 645 returning to stand-by after a few seconds.
                                          by PowellSkier
                                          A Harman/Kardon AVR 645 repair has been a hobby of mine for the past several years. My latest attempt involved the purchase of a DOA unit for part swapping and testing. The original AVR would power up then shut down after a few seconds. I completely tore down both units, found a couple of bad components and reassembled one of them. Same issue, no speakers connected. After extensive research I found a repair document from Harman/Kardon that explains the protection circuit in fantastic detail and provides specific test points for each fault (power, DC detection, overload & power) and the voltage...
                                          06-17-2024, 11:43 AM
                                        • falafinasul
                                          Harman Kardon AVR 3700 Fonte queimada
                                          by falafinasul
                                          Harman Kardon AVR 3700 burned, it does not turn on and I have already changed the fuse and when turned on it burns again. It must be shorted.
                                          I made a new Diagnostic and verified that the input source is shorted.
                                          Someone help
                                          02-24-2023, 05:51 PM
