Troubleshooting Harman Kardon TS-14 Subwoofer
  • romeo_morano
    • Feb 2015
    • Philippines
    #41
    Re: Troubleshooting Harman Kardon TS-14 Subwoofer
    Hi there, newbie here.
    I have an HKTS11 sub, and recently I noticed a low humming sound even without audio signal introduced in to the sub-woofer.
    Further, connecting some wires on the input, I noticed that the sub receives some FM radio station signal.
    Anyway, that FM signal can be eliminated. I am more concern on the humming produced by the sub. Reading on the posts above, I am little bit skeptical if the output filter caps would cause the hum, also the said output filter caps do not show any sign of physical damage. I checked the power supply filter caps (4,700uF/80V x 2) and find it still fine/ok.
    Any suggestion how to proceed with my troubleshooting will be highly appreciated. TIA
      Is the hum there when the there is no connections to any of the input jacks? We need to find out if it is power supply filtering problems or ground loop problems.
      "I checked the power supply filter caps (4,700uF/80V x 2) and find it still fine/ok." How did you figure out if they are good or not? Did you check the ripple voltages?
      • romeo_morano
        • Feb 2015
        • Philippines
        #43
        Hi budm, the hum is there even if no connections to any input jacks.
        I checked the filter capacitors using analog tester. Where, upon touching the test probes (multi-tester is set to x10Ohm) to both terminals of the capacitor, the pointer of the meter goes to the mid-section and slowly moves to right (or infinity).
        With regards to ripple voltage, I cannot check them as I don't have an oscilloscope.
        Thanks..
          • 31218
          i have done loads of harmon champagne/soundstix stuff, i will just say that the caps in them are junk.
          8 out of 10 problems are fixed just by recapping them with panasonic FR's
          HK may be an expensive brand, but they use the worst caps!
          btw, if it uses a switching psu, those often need a recap too - and dont use chinese replacements from ebay.
            Thanks..
            Testing cap with that method does not tell you the capacitance of the cap.
            • betula
              • Dec 2021
              • canada
              #46
              Newbie? yes, guilty as charged. Old thread, yes, I know. I have one of these with the same problem. Does anyone have a lead for schematics for this unit. And oh, ya....does anyone know where that adhesive comes from? All three pub's have it in different colours.
              • viewfindr
                Harman Kardon Soundsticks III Bad subwoofer, low bass
                by viewfindr
                I have a pair of rarely used computer speakers. Recently, I noticed that the subwoofer was barely working. Both satellites are still good, but even when turned up all the way, the subwoofer is extremely weak and produces almost no bass. It definitely still outputs a little bit on the deepest notes, but is far from what it should be.
                I took it apart, and the subwoofer driver measures about 17 ohms on a multimeter. I couldn't get figure out how to get the board out, but attached some photos (cables attached are affixed to the housing). The caps look good to me (no bulging or leaking),...
                03-21-2021, 03:47 PM
              • funky2x
                Harman kardon onyx studio 7 Smd code
                by funky2x
                Cant find what smd code Y0DVA.
                sitting in Harman kardon onyx studio 7. Appreciate any help.
                05-29-2025, 03:44 PM
              • PowellSkier
                Cement resistor swap in Harman Kardon AVR
                by PowellSkier
                Would I be able to swap a 0.27 Ohm Kx2 5W resistor for a 0.22 Ohm Jx2 5W resistor in a Harman/Kardon AVR? Cement type.
                06-04-2024, 06:41 PM
              • PowellSkier
                Harman/Kardon AVR 645 returning to stand-by after a few seconds.
                by PowellSkier
                A Harman/Kardon AVR 645 repair has been a hobby of mine for the past several years. My latest attempt involved the purchase of a DOA unit for part swapping and testing. The original AVR would power up then shut down after a few seconds. I completely tore down both units, found a couple of bad components and reassembled one of them. Same issue, no speakers connected. After extensive research I found a repair document from Harman/Kardon that explains the protection circuit in fantastic detail and provides specific test points for each fault (power, DC detection, overload & power) and the voltage...
                06-17-2024, 11:43 AM
              • falafinasul
                Harman Kardon AVR 3700 Fonte queimada
                by falafinasul
                Harman Kardon AVR 3700 burned, it does not turn on and I have already changed the fuse and when turned on it burns again. It must be shorted.
                I made a new Diagnostic and verified that the input source is shorted.
                Someone help
                02-24-2023, 05:51 PM
