How to extend antenna from sony undercounter cd player/radio
  • petehall347
    • Jan 2015
    • 4439
    • United Kingdom
    Re: How to extend antenna from sony undercounter cd player/radio
    ancient thread but going back to my a.m building days and experiments you can add external antenna connections to the bar and also a grounding connection . just cant remember which taps it comes from now . also play with capacitors for sensitivity and selectivity .
    i forgot some of it .was 46 years and more ago now .
    • carl slanemyr
      • Feb 2019
      • Sverige
      Originally posted by C Don 85
      To Jack 3756 - You explained wonderfully
      I know this is an old tread but my wife has decided to throw away her under cabinet radio Cd player (Sony CD543rm) because she likes to listen to Rush Limbaugh on FM and the reception was terrible.
      Jack, you explained the solution perfectly. I took the radio apart and finally found the capacitor C921 on the back side of the board. It is about the size of a half grain of uncooked rice on the line that comes from the power transformer secondary.
      I unsoldered it. I wanted to run an antenna wire from the capacitor but could not get the wire to solder to the capacitor. I gave that up and ran a Teflon coated antenna wire to a 1/8 inch mono phone jack that I installed in a hole I drilled above the vent hole. This kept it out of the way of the power cord wrapping place.
      When I put the machine together the reception was so good that I decided against putting an antenna wire in.
      Than you again for passing on your knowledge. C Don
      C DON 85 and Jack 3756
      Can you please tell me where the new antenna wire needs to be soldered! Photo!?
      Carl, Sweden
      • carl slanemyr
        • Feb 2019
        • Sverige
        where do I solder the new antenna wire?
        • hmeloche
          • May 2019
          Hi. I have a Sony CDK50 under counter radio with identical problem, but interior is different enough that I cannot follow these instructions. Anybody have similar instructions for a Sony CDK50? Thank you.
          • Fairhurc
            • Apr 2020
            Thanks for the great advice. I have a Sony under-mount AM/FM/CD player (Model ICF-CDK50) with weak FM signal. Following the advice to unwind the curl in the power cord (inside the unit) and make it a bit straighter outside the unit (and hidden under the cabinet), the FM reception improved dramatically. Thank you!
            • rtl
              • Oct 2020
              Can't thank you enough Jack. Terrific explanation and the fix worked very well. I would only add that the capacitor mentioned is on the underside of the circuit board.
              • mikey5791
                Sony CFS-5000S radio cassette player no FM reception
                by mikey5791
                Hi forum members,
                In the past i have had many helpful hints from generous forum members in diagnosing and solving issue related to most of my electrical things.
                Fyi, i have been keeping this unit of Sony radio cassette player as the cassette belting has worn off but the radio has been working fine before. Recently, out of a sudden i found out i can't get any radio reception at all (no signal from FM,MW or SW band) except some buzzing warp noise from the speakers.
                I opened the casing inside and checked for any dry solder, burned component or loose wires...
                02-24-2023, 03:48 AM
              • UserXP
                Vintage SONY Digital Clock Radio ICF-C12W no audio
                by UserXP
                Dear all,
                I have this old radio clock by Sony from the early 80s, I guess. The clock display works, but is dim, the function board appears to be OK - but the radio unit shows no signs of life. It doesn't produce a single noise, crack or anything from either FM or AM band. It's like it doesn't even power up.
                i opened the radio and it is full of some TRACON gray capacitors. They only have their negative strip printed, voltage and capacitace markings - no series, no temperature marking, nothing else.
                My question is, do you know of this brand of capacitors and how bad are...
                07-21-2025, 08:35 AM
              • shelby5041
                clock radio / radio lifespan?
                by shelby5041
                hi
                ive got a modern digital clock radio approx 15yrs old
                my question is how long can a clock radio or a simple radio last ss farcas operating hours?
                since elec components have limited hour lifecspan i would imagine the radio or clock radio would eventually fail.
                the reason i ask is because i have my clock radio on radio function 24/7 for the past 7 years and its still working fine....i leave the radio on ..never turn off past 7years...thats approx 60000 hours
                it uses very little power just a few watts i would imagine that may have something...
                09-14-2024, 03:30 AM
              • slothen92
                Volvo HU850 Radio/CD-player repair, LDO-voltage regulator IC
                by slothen92
                Hello
                Im trying to repair the Volvo HU850 radio/CD-player from a Volvo V70.
                I have ordered replacements for the four transistors (SD1760), but Im not sure about a replacement for the low dropout voltage regulator IC (marked by the red circle in the attached picture).
                On the body of the IC it says: “LF33AH GK133544”.
                Does anyone know where to find this part or a replacement for it?
                Cheers
                04-09-2025, 08:30 AM
              • bogosort
                Sony DVD player stuck tray (DVP-SR310P)
                by bogosort
                I have a Sony DVD player with a stuck tray. It seems that moving or pressing on the tray makes it work.
                Anyone knows why?
                Thank you....
                05-11-2024, 04:29 PM
