Yamaha amplifier emx512sc
  • rkawa
    Richard
    • Nov 2010
    • 10
    HAVE A COMPUTER MODEL CONSOLE YAMAHA EMX512SC.
    SOMEONE could facilitate the schematic, AS TO CHANGE THE SOURCE TRANSISTORS INVESTOR, I WILL BURN THE 2 CONTROLLERS ... XPECTED
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: Yamaha amplifier emx512sc
    language barrier?
    post pics of the damage.
    that will help more than anything.
    • Radio Fox
      • Jan 2010
      • 281
      This site has the service manual for the EMX512SC
      http://www.free-service-manuals.com/...Manual_L92120/
      For $5 you can access the site database & download as much as you want for 7 days.
      mxslick...Is there really any need to insult a member with that attachment whose native language isn't English?
      Edit... found a free site to download from
      ________________________________________________
      Invisible airwaves crackle with life
      Bright antennae bristle with the energy
      • mxslick
        Motocross Racer
        • Oct 2010
        • 19
        It was intended to be humorous and not insulting...no offense was intended. It is a pic I have used on other forums when an OP isn't clear or understandable. Apologies to anyone who was offended.
        kc8adu made a valid point..the OP is not clear and pictures would be helpful.
        • roadrash
          Yamaha HTA-5630RDS Amplifier dead
          by roadrash
          Belongs to my son and he just says it stopped turning on. Any help greatly appreciated. Theres 240v in and fuse is ok but no power anywhere else.
          12-12-2024, 10:19 AM
        • Nevillet
          Yamaha A-520 HiFi amplifier
          by Nevillet
          Hi All,
          I have a Yamaha A-520 that has no sound output.
          I notice after power up the protection protection relay does not click in.
          I'd appreciate any pointers on where to start.
          Many thanks.
          Service Manual below:
          https://www.badcaps.net/forum/attach...1&d=1641841819...
          01-10-2022, 01:11 PM
        • ugamazing
          820-02917 4.69v/2.49a--weird one! New-Style ACE Controllers--where to source?
          by ugamazing
          First time dealing with one of these 2023 16" units, and the board model is 820-02917. No schematic available from what I can tell, but a somewhat similar one in 820-02918. I am going to reference certain chips using the 02918 schematic because it will at least let you know what I'm looking at:
          Unit had liquid-damage to U5500/UF400/UF500 areas. Had to do a ton of precision cleaning since we don't have any parts for this model yet. Got everything cleaned up but had a few resistors with burned pads that we replaced fine, but without knowing where to check for continuity, hard to...
          02-17-2025, 03:30 PM
        • sanalelevenstar
          Yamaha RX-V485 Wn9711 Update
          by sanalelevenstar
          Help Needed: Yamaha RX-V485 Network Issue After Firmware Update (WN9711 Error)
          I'm facing an issue with my Yamaha RX-V485 receiver. During a firmware update, the process failed, and now the USB, Bluetooth, and network functionalities are not working. Occasionally, the receiver displays the error code WN9711.
          I came across Yamaha Technical Bulletin No. 0103, which describes a similar issue for models like the RX-V4A, RX-V6A, and RX-A2A. According to the bulletin, the issue can be resolved by shorting soldering points (e.g., J260 for RX-V4A or...
          12-04-2024, 04:32 AM
        • MrCommunistGen
          Polk Audio RTi100 Plate Amplifier won't power on and intermittently honks and buzzes
          by MrCommunistGen
          My childhood best friend was killed about 9 years ago. His parents are finally letting go of his things, and they offered me his Polk RTi100 tower speakers. The Polk RTi100 towers are one of a handful of designs from the early 2000s that is a full range 3-way tower with a built-in self-powered subwoofer. This is accomplished with a plate amp integrated into the speaker input panel.
          I think they used them for a while, but they've been sitting for at least a few years now. After about 40 hours of driving to their house and back (both they and I have moved in the last 9 years) I got...
          07-12-2021, 05:11 PM
