820-02917 4.69v/2.49a--weird one! New-Style ACE Controllers--where to source?
  • ugamazing
    • Jun 2013
    • 171
    • usa
    First time dealing with one of these 2023 16" units, and the board model is 820-02917. No schematic available from what I can tell, but a somewhat similar one in 820-02918. I am going to reference certain chips using the 02918 schematic because it will at least let you know what I'm looking at:
    Unit had liquid-damage to U5500/UF400/UF500 areas. Had to do a ton of precision cleaning since we don't have any parts for this model yet. Got everything cleaned up but had a few resistors with burned pads that we replaced fine, but without knowing where to check for continuity, hard to confirm there are no open lines. I am suspecting something amiss since we're getting super unusual USB-C meter readings: 4.69v with a 2.49a draw. Strange.
    Does anyone know if these newer-style ACE controllers are hot-swappable, or are they still paired-off via ROMs like on the 820-01700 boards? We do have a 14" board that utilizes these newer ACE controllers, but don't want to go replacing them without knowing if we can. We also don't have a stencil for these yet, so replacing just one is going to be a headache, let alone multiple. Also, why specifically is UF500 under-filled and the others aren't? Is this the DFU-related controller by chance? Curious to see.
    Where are people sourcing these controllers at the moment? Are we still limited to parts-boards? May end up calling this one and waiting until they're more common. Any insights appreciated!
  • grimacelord
    PS4 CUH-2115B Slim All Controllers Do Not Sync By Bluetooth or USB
    by grimacelord
    Hello. I have a PS4 Slim model number CUH-2115B that is having a problem with syncing any controller by USB and Bluetooth. Every controller I have tried will not sync, and I know that the controllers will sync fine to another PS4, so it's not a controller problem. I have tried 5 different USB cables and 3 different controllers and none of them sync to this PS4, but will on others.
    The USB ports on the PS4 is delivering 5V power and does charge the controllers (I checked with an USB ammeter).
    The controllers also do not work in Safe Mode. I understand that if they...
    08-08-2022, 09:04 AM
    Protection Pin Shutdown in PWM Controllers & LCD inverters
    How to remove the protection of the inverter - several ways to protect shutdown in popular PWM controllers, LCD inverters.
    When repair and diagnosis, it is often necessary to check the individual
    inverter circuits - power converter lamps illuminate the LCD panel.
    Carry out the necessary measurements is sometimes not possible, the
    generation of breaks for various reasons, for example because of the
    imbalance in the loads.
    Together, artists and researches different options for the repair of
    conferences were blocking inverter protection in order...
    11-06-2024, 04:18 AM
  • Rickkap
    Help understanding USB-C controllers
    by Rickkap
    I need help trying to understand how the USB-C controllers work on a PC laptop.
    I have an Asus Notebook PC model:UM425I which doesn't turn on. I check the motherboard and is doesn't have any liquid damage as such.
    The USB-C tester is showing 5.18 - 5.19v fluctuating 0 amps and that's on both ports.
    I checked the coils and there is no short to ground, only one was low in diode mode and with this removed the tester shows the exact same voltage readings.
    There is only one USB-C controller (INFINEON CYPD5225-96BZXI) Link to the datasheet...
    10-19-2023, 12:12 PM
  • xx xx
    dag3mmb2ca0 rev a AYUDA!
    by xx xx
    Hi everyone, I have a big question. Could you help me? I have the dag3mmb2ca0 rev a motherboard, which we already repaired. We replaced a chip that was slightly overheating, and the thermal camera indicated which one it was. We actually had one of the same boards that was defective, so we replaced it, and the machine started back up. We've had a lot of experience with this machine. The charge controllers and GPU components always fail, causing them to burn out (very poor quality). However, I have no way of knowing what the chip is or how to buy it, as the screen printing doesn't indicate the part,...
    10-03-2025, 02:40 PM
  • Techie_hobby1
    Another component identification please - these Xbox controllers are a pain in the rear end haha
    by Techie_hobby1
    Could someone please help me with yet another Xbox controller component..
    I have 2 Xbox Series X motherboards to hand (one being a faulty spare for parts only) and the other being a family friends faulty MB. He inserted 2 x AA Alkaline batteries and decided to plug the controller into USB-C which instantly made some magic smoke appear and wants me to see if I can fix it for him.
    Yet another white (limited edition MB though)
    truclacicr I know you are pretty good at previous id's, but anyone else can help me also
    Many thanks...
    03-22-2025, 07:23 AM
