Rhapsody RY-610 Multiband radio - need schematic\photos
  • Agent24
    I see dead caps
    • Oct 2007
    • 5084
    • New Zealand
    Someone gave me one of these radios several years ago with a faulty amplifier
    I opened it hoping to find out what was wrong but never did (didn't know much back when I was 12 or whatever)
    I put it away, forgot about it for a while. Took it out a year ago, realised I had forgotton where half the wires connected.
    Now I'm hoping I can find a schematic or at least someone with one who can take some photos or otherwise describe where the connections are supposed to go.
    I figure that now I know a bit more with what I'm doing, I should be able to actually get the amplifier working again and use the radio
    I've attached a photo and added this link in case someone has one but with a different brand, as seems happens a lot with these kinds of things.
    -David VanHorn
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: Rhapsody RY-610 Multiband radio - need schematic\photos
    looks a bit like an older panasonic.
    post pics of the board.it may become obvious where things go.and if it is really a rebadged panasonic it may be easy to crossreference to the real model.
    • Agent24
      I see dead caps
      • Oct 2007
      • 5084
      • New Zealand
      Here's some photos, hopefully someone will recognize something there.
      First board is the power supply, 9 volts, F = Positive and G = Negative. I know that much
      From the board (BFO) I am not too sure what goes where. I think the red wire (which broke off) went on the B- point, but there is nothing called B- on any other board.
      As for the amp board, M+ and M- I believe are for the VU meter, and C is audio signal input from the tuner board
      Not sure what M is on the tuner board.
      Several points are not used, as this is the model without the tape deck built in.
      The green wire I am holding comes from a small disc-shaped board on the ferrite antenna, but not sure where it connects to.
      The 2 red wires following that are for the dial light, and connect somehow to the left most switch on the amp board (point A and B, or, A or B & something else)
      I really think a schematic will be needed to prevent major headaches...
      -David VanHorn
      • Agent24
        I see dead caps
        • Oct 2007
        • 5084
        • New Zealand
        It would appear that this is the same design as the RadioShack 12-795. Does anyone have the schematic etc for that?
        -David VanHorn
        • Agent24
          I see dead caps
          • Oct 2007
          • 5084
          • New Zealand
          Also found it goes by the name "Venturer 2959-6"
          -David VanHorn
          • Agent24
            I see dead caps
            • Oct 2007
            • 5084
            • New Zealand
            Good news!
            I found someone selling one on Trademe, and after someone purchased it I contacted the buyer and they took some photos for me!
            They didn't get everything I needed but they got the critical bits (eg: the unlabeled connectors for the BFO board and external antenna jack) and after some careful examination of the circuits and some logical thought I figured out where everything else went.
            Tuner still works, amp still doesn't.
            It will throw a short burst of sound out when you switch it OFF but normally won't do anything. Guess I will pull and test all components for the amp IC (all 10 of them!) first because I have no idea where I'll get a new one of those if it's dead.
            -David VanHorn
            • Agent24
              I see dead caps
              • Oct 2007
              • 5084
              • New Zealand
              Well, I guess when you stick with something you eventually get results!
              With help of the datasheet and some thought, I pulled and tested all the components associated with the IC, and they all tested fine.
              So it was down to finding a new IC and just seeing what happens.
              Luckily I was able to get six NEC uPC1213C amplifier ICs on eBay from a seller in Switzerland - turns out there are quite a few sellers in Europe with these ICs, but the one from Switzerland was actually the cheapest (and for six ICs too, nice!)
              (on a side note, is there a program anywhere that can search eBay for items in ALL countries no matter what? - eBay global works but only for sellers who have listed New Zealand in the shipping list - the problem is most people don't, but after asking nicely they usually ship here anyway)
              Put the new IC in yesterday and all seems to be working fine!
              Now I just have to figure out a way to make a better heatsink for it as the original one fell apart when I removed it, and might have been the reason why the original chip died to begin with.
              -David VanHorn
              • GadgetmaNZ
                • Feb 2013
                • 6
                • New Zealand
                Hi Agent24,
                I also live in New Zealand and got this Technica/Venturer/Radio Shack 2959-6 on my worktable to get fixed.
                I work volunteering for MenZ Shed Richmond and I do not get paid anything for this job but I might get a hand with some woodworking on my van in return.
                The problem is exactly same as yours so I assume it could be the amplifier IC?
                Did you find a schematic somewhere?
                Did you have any IC's left as you got six from Switzerland?
                I have another working one which I thought about using for diagnosing but discovered this Forum and looks like you have done all the hard work diagnosing the fault if lucky?
                Cheers
                Henry from Nelson
                • Agent24
                  I see dead caps
                  • Oct 2007
                  • 5084
                  • New Zealand
                  If it gives a short burst of sound when you turn it OFF, but nothing otherwise, then I expect it's quite likely that it's the same problem.
                  I never got a schematic, if there is one I haven't seen it. Asked one guy in a repair shop who had one of these radios in the window and he just laughed.
                  I can send you an IC if I can find where I put them... send me a PM or Email.
                  Still not totally sure why it died, but I reckon the heatsink is rubbish. The person who gave it to me would have had it blasting out in the garden so I guess that story could make sense.
                  The datasheet for that IC (attached) expects a nice big ground plane for the heatsink legs to be soldeed onto. The radio I have didn't have that, instead used a little bit of tin or something IIRC. Maybe it wasn't enough. I suggest you use something better, just in case.
                  Funny you brought this up today as I finally ordered a sheet of copper to make a better heatsink from just last week.
                  -David VanHorn
                  • kaboom
                    "Oh, Grouchy!"
                    • Jan 2011
                    • 2507
                    I'm gonna rain on this parade- that's no Panasonic. Overall, cheep construction... The real 2200s have both LW & MW antennas in the Gyro-Antenna. This thing has a ferrite rod, immovable, mounted on a board.
                    No Jap caps- they've all got weird names...
                    I see no "M" or "triad" logo on those boards. That looks a lot like various chinese "copy" radios I took apart years ago.
                    Don't get "tunnel vision" looking for an "equivalent model" where one may not even exist!
                    -Paul
                    "pokemon go... to hell!"
                    EOL it...
                    All style and no substance.
                    guilty,guilty,guilty,guilty!
                    guilty of being cheap-made!
                    • Agent24
                      I see dead caps
                      • Oct 2007
                      • 5084
                      • New Zealand
                      Oh for sure it's not a Panasonic, I never thought it was...
                      -David VanHorn
                      • redrooster
                        • May 2011
                        • 114
                        -Paul
                        I just noticed this old post and I cant believe that no-one has rained on his parade for being a troll and bringing this brand of juvenile nastiness to the discussion.
                        HP P6-2203a desktop,AMD CPU A8-5500 with Radeon HD7560D,3.20Ghz. Radeon HD 6670.8Gb Ram.2TB HDD. WIN 10 64 bit O/S.
                        • Agent24
                          I see dead caps
                          • Oct 2007
                          • 5084
                          • New Zealand
                          (Quoted from email - better if you post here)
                          Originally posted by redrooster
                          Hi there,Did you ever manage to get a schematic? My radio has been fiddled with and I need to tune the slugs back in.I must have looked just about everywhere for a schematic,looks like it may be unobtainium.Ha!
                          No, never found a schematic for this. If one was ever released it would have been on paper and nobody has bothered to scan it.
                          Don't know how I can help with the tuning either, unless there are some measurements I can take that would help, but I know very little about radio tuning circuits so I don't even know if that would be of any use.
                          -David VanHorn
                          • Agent24
                            I see dead caps
                            • Oct 2007
                            • 5084
                            • New Zealand
                            Added some docs I found while tidying up my files which relate to the RadioShack 12-795 version. Might be of some use, but there's no schematic. Sorry.
                            -David VanHorn
