TDK headphones
  • kiddznet
    • Jul 2010
    • 176
    TDK headphones
    Kids have a set of cheap headphones (TDK) that one side went dead on
    I rescued them (silly me) and heres what I got
    Stripped and disconnected everthing. Both phones test ok . Same impedance same noise.Rewired red to left green to right earth etc etc.
    Continuity tests fine
    Plug em in. Bugger, sound on one side only. PC sound card tests fine with other devices.Swapped wiring over. Bugger, sound goes to other speaker..
    Any ideas before I bin 'em?
    Oh have tried new jack cable.
    939 DualCore AMD Opteron, 1800 MHz (9 x 200)
    Abit AN8 / Fatal1ty AN8 SLI Series
    3072 MB (PC3200 DDR SDRAM)
    ATI Radeon HD 4300/4500 Series (1024 MB
    Lian LI Aluminium mesh case
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: TDK headphones
    toss em... those POSs are sh!tcan quality anyway. chinese throwaway junk.
    sigpic
    (Insert witty quote here)
      master hoarder
      • May 2008
      • 12175
      • Bulgaria
      Re: TDK headphones
      Sounds like a typical wiring/plug problem, but you said you've already tried a new jack and cable. When you did that, did you get the same results again?
      Also, do you know the model number of the headphones, or perhaps at least what kind of headphones they are - earbuds, over the head, behind the neck...? If earbuds, keep them for the wires/plug if you like, but don't bother fixing them like ratdude said.
      • weirdlookinguy
        • Sep 2007
        • 1638
        Re: TDK headphones
        I go through a lot of headphones. Every 3 or 4 months they either break on me or I lose them. Here's my proposed solution to your problem:
        Shitcan them. Not worth fixing.
        As for a replacement, may I suggest a set of JVC FLATS. They are JVC's current headphone series, you can find them at Frys or Walmart for ~$20. Forget in-ears, forget earbuds... these cheap JVCs are where it's at. After you let them wear in they will bump like nobody's business. I'm blasting the shit out of them as I type this.
        • kiddznet
          • Jul 2010
          • 176
          Re: TDK headphones
          I hear you all in stereo!
          Shitcan 'em yes, but I not gonna let two iddy magnets get the better of me.
          Now I got 'em hooked in parallel and lo, there's noise outa both sides....
          • weirdlookinguy
            • Sep 2007
            • 1638
            Re: TDK headphones
            I did that to an old pair of huge Sony cans a few years back. I got a few more months of (mono) use out of them before they broke again.
            Semi off-topic: does anyone here use a CMoy?
              • 31036
              Re: TDK headphones
              the wire breaks just behind the plug - allways.
              it has nothing to do with china, just the use of thin cables.
              • smason
                • 1652
                Re: TDK headphones
                I've had the same pair of Sennheisers for about 20 years now. No problems, even when getting stuffed into carryon luggage and camera bags.
                Good stuff.
                • kiddznet
                  • Jul 2010
                  • 176
                  Re: TDK headphones
                  YaY
                  Yup the cable. Absolutely rotten was getting intermittent open circuit and earthing even after cutting back so replaced it and bingo..stereo
                  I never seen such a bunch of crap cable. The reason I never got it sooner was the cable i was given to test it was MONO, even tho it had 3 ring plugs.
                  Beer time...
                  • ChaosLegionnaire
                    by ChaosLegionnaire
                    09-13-2022, 09:02 AM
                  • LEECH666
                    Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                    by LEECH666
                    Good day ladies and gentleman!
                    I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                    This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                    I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                    01-19-2024, 05:46 PM
                  • Christos Tsiligiannis
                    Marian Trace Alpha sound card repair help
                    by Christos Tsiligiannis
                    Hello to the forum.
                    My name is Christos, I am new to the forum here and i am posting from Greece.
                    So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
                    To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
                    So i tried asking for a schematic from the company and they would not give me one. Instead they...
                    11-18-2024, 05:26 AM
                    HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i5-9500T Specification for Upgrade or Repair
                    This specification for the HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar boardview and ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                    09-12-2024, 02:30 PM
                    HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i7-9700 Specification for Upgrade or Repair
