YAMAHA AV Receiver RX-V585 No Power
  • alfredomfr1
    • Oct 2014
    • 318
    • usa
    120v ok, No voltage on the connectors, Fuses OK, 165v DC on the main capacitor
  • R_J
    • 9551
    Re: YAMAHA AV Receiver RX-V585 No Power
    Standby circuit is defective, are you sure F5401 is good? Also check F5405 (2A/63V)
    • alfredomfr1
      • Oct 2014
      • 318
      • usa
      F5401 and F5405 are ok
      • R_J
        • 9551
        Are you sure you are not getting any 5.5 volts from the standby circuit?
        Check the voltage across C5419 and C5420
        • alfredomfr1
          • Oct 2014
          • 318
          • usa
          C5419: 161v dc
          c5420: 9.7v dc
          • R_J
            • 9551
            C5420 is for the vcc voltage, it needs to be 15 volts to start up. Try replacing C5420, Check that there are no shorts in the secondary side like D5409.
            Check the solder connections on the transformer and check R5407 (47Ω)
            • alfredomfr1
              • Oct 2014
              • 318
              • usa
              C5420 replaced, R5407: 47ohm, transformer connection resoldered, no shorts.
              Same as post 5
              • R_J
                • 9551
                Are you getting any voltage at all on the secondary side across C5423? if not it may be that ic541 is bad and not operating, the circuit is very simple and only has a few components.
                • alfredomfr1
                  • Oct 2014
                  • 318
                  • usa
                  Today I received the IC541 (3A453D) and voltage across C5423 look like a pulse, go to 1.7v DC and back to 0v and back to 1.7v
                  • tibimakai
                    • Jan 2012
                    • 3680
                    Relay is OK? Once I had a two year old Yamaha with a sealed relay, that was rusted inside.
                    • alfredomfr1
                      • Oct 2014
                      • 318
                      • usa
                      But the relay come to play after, first I have to have the standby voltages
                      • saisoni20
                        • Feb 2022
                        • 111
                        https://www.youtube.com/watch?v=NqYDAyJBjBU
                        Check the protection code
                        • PantherDave
                          by PantherDave
                          Hi all!
                          05-29-2024, 02:01 PM
                        • GLISIT
                          by GLISIT
                          01-16-2025, 02:29 PM
                          by sam_sam_sam
                          03-31-2024, 02:12 PM
                          09-06-2024, 05:59 AM
