Help monitor audio rxw-12 subwoofer
  • old_marantz
    • Aug 2023
    • 7
    I have a monitor audio subwoofer rxw12 that is clicking. Avsforms has a thread on this and I saw someone posted schematics here for it. Since I’m a newbie and no one here in salt lake will work on it, I guess I’m elected.
    Supposedly the issue is “ smd type and located on the soldering side of the amplifier board”. Can you experts help me identify which one it might be? And what to order? How difficult to put these in? I’ve replaced caps before but just eyeballing what these resisters might be on the board, they look pretty small.
    I saw some utube videos on these resisters so hopefully that will be helpful.
    I have 4 of these subs and this is a common issue in them. So I better learn how to fix if I have 4.
    https://www.badcaps.net/forum/showth...ighlight=Rxw12
  • petehall347
    • Jan 2015
    • 4427
    • United Kingdom
    Re: Help monitor audio rxw-12 subwoofer
    post some pics of it and explain the problem better . and a link to the supposed fix .
    • old_marantz
      • Aug 2023
      • 7
      https://www.avforums.com/threads/mon...cking.2378009/
      • old_marantz
        • Aug 2023
        • 7
        Pics
        • Per Hansson
          • Jul 2005
          • 5895
          • Sweden
          Post the PCB picture in much higher resolution please.
          • old_marantz
            • Aug 2023
            • 7
            Just an fyi I noticed most of the 500w (and other lower wattages) Subwoofers that MA makes all have the same size cabinets and holes for the plate amp. So I contacted them and I just ordered a newer plate amp to go into my cabinet and reuse my speaker. Obviously they sorta tweak these and supposedly add newer features to the newer plate amp. So, for just under $400, you get their latest plate amp that will drop into your existing sub cabinet and reuse speaker. So, just do a little home work and make sure a newer plate amp will work for you.
            Just another way to fix you broken MA sub. Ya, more expensive if you don’t have electronic diagnostic skills. But, still much cheaper than their newer 500watt sub at $2200.
            I’m about to retire so I’ll keep the old plate amp and try and fix it with my future spare time.
            • foisamoi
              • Sep 2023
              • 4
              • Greece
              Hi, from Greece can anyone to help me
              I want to know what is the voltage in the circle up left.
              • dobrykamil
                • Jun 2013
                • 62
                Don't remember exact value, but VCP is around 16-17V, so VIB should be a bit less than that.
                • foisamoi
                  • Sep 2023
                  • 4
                  • Greece
                  thank you very much
                  • foisamoi
                    • Sep 2023
                    • 4
                    • Greece
                    Can you tell me which transformer is in the blue circle?
                    thank you.
                    • dobrykamil
                      • Jun 2013
                      • 62
                      thank you.
                      That's the standby psu transformer.
                      • foisamoi
                        • Sep 2023
                        • 4
                        • Greece
                        I installed 2 transformers +12v and -12v, but the previous transformer also gave a voltage of 16-17 to get voltage to the vcp.
                        Do you know of a way to get voltage to the vcp or find the previous transformer as a spare part.
                        thank you very much
                        • dobrykamil
                          • Jun 2013
                          • 62
                          thank you very much
                          That small transformer is only there to provide positive and negative, standby power rails. All other ones are generated by large-main transformer.
                          • exceptional
                            • Aug 2023
                            • 4
                            Had similar problem with that type of amp.
                              by momaka
                              03-15-2023, 10:17 PM
                            • wattage
                              AOC AG493UCX 49-inch monitor - Firmware request
                              by wattage
                              Hello Badcaps Community,
                              The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
                              07-13-2025, 04:41 PM
                            • ant3202
                              HP 27es - LED monitor - Monitor Flashing On - Off
                              by ant3202
                              Hi Everyone
                              Lately I am experiencing the deja-vu incident on one of the led monitor like this.
                              https://www.badcaps.net/forum/troubl...lashing-on-off
                              The monitor is HP 27es LED Monitor
                              https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
                              The monitor will randomly blackout and display no signal and will recover again.
                              Sometimes need to power and off again to restore the display but...
                              03-20-2025, 07:30 PM
                            • Rick_1234
                              LG 23MP55HQ LED Monitor turns off after a few seconds or flickers.
                              by Rick_1234
                              Good evening, gentlemen.
                              I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
                              To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
                              https://drive.google.com/file/d/1L6S...ew?usp=sharing
                              Things I tried
                              - Bought a new AC adapter thinking that was the problem but the problem...
                              06-22-2024, 04:44 PM
                              Wise Wing F199 19'' LCD monitor - recapped
                              by momaka
                              Looking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
                              I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
                              When I saw the Craigslist post, I wasn't...
                              08-24-2020, 10:58 AM
