Tx NR646 No Hdmi in/out
  • saphire34
    • Jul 2023
    • 6
    Hello everybody. As it says in the title, I have an onkyo tx nr646 where the hdmi ports no longer work, both inputs and outputs.
    Last night there was a storm. There was a lot of lightning. The electricity was turned off several times.
    The speakers work correctly. Radio net works. Bluetooth works. I managed to update without any error through the usb port.
    Can someone help me? Thanks in advance.
  • tibimakai
    • Jan 2012
    • 3680
    Re: Tx NR646 No Hdmi in/out
    Buna din LA.
    Most likely the HDMI IC(or ICs) are bad.
    • saphire34
      • Jul 2023
      • 6
      @tibimakai
      mersi de raspuns.
      Can you help me find out if the ICs are burnt?
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8243
        Here is the service manual for it. I am not sure if you just can sepal either that Q8000 on that HDMI aboard.as it can be flashed with firmware.
        • tibimakai
          • Jan 2012
          • 3680
          I have some threads on repairalmostanything forum. Tjmotter is the expert on Onkyos, though he quit repairing, but he still shows up once in a while on that forum.
          • saphire34
            • Jul 2023
            • 6
            thanks for service manual. Q800 is a Panasonic MN864788 acording to manual service.
            • saphire34
              • Jul 2023
              • 6
              thanks. I will try on that forum.
              • tibimakai
                • Jan 2012
                • 3680
                The HDMI ICs do not get hot?
                • saphire34
                  • Jul 2023
                  • 6
                  Yes. Only this one Panasonic MN864788 (Q800)
                  • CapLeaker
                    Leaking Member
                    • Dec 2014
                    • 8243
                    she is toasted.
                    • tranquility
                      Onkyo TX-NR809 – no hdmi, DTS or NAND chip ? stuck at starting kernel
                      by tranquility
                      i want to repair an Onkyo TX-NR809 receiver.
                      symptoms:
                      on power on, display appears and i hear one click. enue functions is given.
                      - no hdmi output
                      - audio output not tested, but i think it is not there
                      - usb sticks are not recognized
                      if i read out the chips with display+standby button + tone+
                      both dts show only ????
                      chip is D830K013BZKB4
                      things i have done:
                      - reflow of the dts chip without taking off and reballing
                      - changed the aluminium caps without the big one with 25v because i dont...
                      08-25-2025, 01:04 AM
                    • edugimeno
                      TD Systems K50DLP8F works fine on 1 HDMI, bad on others
                      by edugimeno
                      I have this TV set that I spent a long time fixing it.
                      I finally found a shorted SMD capacitor near the plug from the PS at the main board. It was shorting one of the main voltages (can't remember which one)
                      I removed that capacitor, and as it has another one in parallel, I left it with only one, checked it and it seemed to work fine. The solder near that capacitor was really delicate as I pulled apart one trace so I prefered to not mess much with it after I had to air solder one small thread of copper
                      I didn't use that TV much at that time. Now that I'm using it,...
                      10-06-2023, 03:00 PM
                    • huzo
                      Dell 5590 no image on LCD,HDMI works ,the board works...
                      by huzo
                      The board is LA-F411P ,DELL 5590 ...
                      The screen polarises,no backlight,no image,only black screen,tried another screen,the same,so there is no backlight,but there should be an image when i shine a lamp behind the screen,but there is none...only dark screen...when screen is connected and i press F8 to turn the image over to the external monitor, the external monitor gets coloured bars ,but when i disconnect the cable from the EDP ,the HDMI picture is good...What could be the problem? I don't have another edp cable, but i measured it with meter and it comes out good...i am baffled......
                      02-16-2025, 03:08 PM
                    • amuse619
                      Asus G15 5980HX - 6800M - No Display on Laptop - HDMI/Display Port external monitor works fine. Fried Component.
                      by amuse619
                      Hello!
                      Looks like I fried something when my EDP cable got squeezed on the hinge. I replaced the cable but still no display. Laptop works fine with external monitor connected through HDMI and Display Port-USB C port. I took it apart and I see a burnt component. Can anyone help me identify what this component is? I tried to use schematics for another G15 but it does not match on the amount of pins and size. I attached pictures. The component has a label on it - (21A29)
                      Laptop is a Asus G15 Advantage Edition 2021 Laptop Ryzen 9 5980HX - 6800M...
                      08-14-2024, 01:22 PM
                    • Andreasbest
                      Lenovo Legion Y520-15IKBN Display works only through HDMI
                      by Andreasbest
                      Hello!
                      I received a Lenovo Legion Y520-15IKBN with blank screen but working display though HDMI.
                      Since customer was curious and disassemble it himself before bring it to me i want to check the JEDP1 backlight fuses but i can't find them!
                      Can you please point them to me?
                      Thank you in advance!
                      Schematics & Boardview attached
                      Boardview - https://www.badcaps.net/forum/troubl...o-y520-nm-b191...
                      02-18-2025, 05:45 AM
