Lenovo Legion Y520-15IKBN Display works only through HDMI
  • Andreasbest
    • Aug 2014
    • 1163
    • Hellas ( Greece )
    Hello!
    I received a Lenovo Legion Y520-15IKBN with blank screen but working display though HDMI.
    Since customer was curious and disassemble it himself before bring it to me i want to check the JEDP1 backlight fuses but i can't find them!
    Can you please point them to me?
    Thank you in advance!
    Schematics & Boardview attached
    Boardview - https://www.badcaps.net/forum/troubl...nm-b191-rev1-0
    Schematic - https://www.badcaps.net/forum/troubl...post1352445​
    Last edited by SMDFlea; 02-18-2025, 05:55 AM. Reason: Boardview & Schematic link........
  • Andreasbest
    • Aug 2014
    • 1163
    • Hellas ( Greece )
    JEDP1 voltages pin#:
    1 20v 11 0v 21 0v
    2 20v 12 0v 22 0v
    3 20v 13 0v 23 3.3v
    4 20v 14 0v 24 0v
    5 0v 15 0v 25 0v
    6 3.3v 16 0v 26 0v
    7 3.3v 17 0v 27 0v
    8 0v 18 0v 28 0v
    9 0v 19 0v 29 0v
    10 0v 20 0v 30 3.3v
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Fuse is ok as you're receiving +LED_VDD on pin1-4 of edp connector.
      Voltage on pin 8-9-10 is incorrect.
      Pin10 EDP_HPD at zero volt may indicate a faulty cable as the edp cable seems not detected.
      • Andreasbest
        • Aug 2014
        • 1163
        • Hellas ( Greece )
        So you suggest to measure again just for confirmation and if voltages the same, order a new cable?
        • MontyL
          • Feb 2025
          I'd disconnect, clean and reconnect first.
          • FriedFred
            • May 2024
            • 137
            Backlight fuse can also be on the inverter board, not mainboard. As far as I can see on page 35, there is no BL fuse on mainboard.
            So, if you have 20V at JEDP1, and you can observe something like a picture trough a torch lighting into the display, then you need to check whether the 20V find its way onto the inverter board inside the display.
            • Andreasbest
              • Aug 2014
              • 1163
              • Hellas ( Greece )
              I disconnected, cleaned with contact cleaner and connect it again firmly. No luck.
              Should i remove the screen bezel and measure the other side of the LVDS cable too?
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                Measure resistance to GND on pin 8-9-10 of edp connector
                01.With edp cable connected
                02.Without edp cable connected.
                Under both circumstances, NO POWER attached.
                Please confirm its a no display on internal screen or Dimm display on it.
                • Andreasbest
                  • Aug 2014
                  • 1163
                  • Hellas ( Greece )
                  Goodmorning from Greece.
                  Just returned to bench.
                  Measurements below
                  With EDP cable connected:
                  Pin 10 17.62κΩ
                  Pin 9 84.6kΩ
                  Pin 8 89.6kΩ
                  With EDP cable disconnected:
                  Pin 10 85.10kΩ
                  Pin 9 42.3kΩ
                  Pin 8 99kΩ
                  No display on internal screen. I see nothing with torch, i even entered BIOS that are many graphic elements but i see nothing.
                  • pc_okay
                    • May 2022
                    • 241
                    • FRANCE
                    Do you try With another Working screen ?
                    • Andreasbest
                      • Aug 2014
                      • 1163
                      • Hellas ( Greece )
                      No, i haven't disassemble the lcd bezel yet but i'm about to do it in a few minutes to measure the fuse and the edp cable.
                      • Andreasbest
                        • Aug 2014
                        • 1163
                        • Hellas ( Greece )
                        With panel replacement works great, indicating something wrong with the screen itself. I'll measure all fuses on LCD board and report back.
                        • Andreasbest
                          • Aug 2014
                          • 1163
                          • Hellas ( Greece )
                          Fuse F1 32v 1.5A is blown.
                          Gonna replace it and report back.
                          • Andreasbest
                            • Aug 2014
                            • 1163
                            • Hellas ( Greece )
                            Fuse replaced, still no display, fuse not blown after two tries but nearby capacitors seem shorted, desolder them all and short remains on pads, solder them back. Out of ideas (except screen replacement).
                            • pc_okay
                              • May 2022
                              • 241
                              • FRANCE
                              Can you send photo of the LCD board?
                              Maybe it's another component that's shorted to ground.
                              Compare resistance to ground with the working one.
                              • Andreasbest
                                • Aug 2014
                                • 1163
                                • Hellas ( Greece )
                                Sure, screen model is LP156WF6 SP K6
                                The green marked components, mostly capacitors, were desoldered and short remained, the red marked not desoldered yet.
                                All of them seem shorted to GND, both pins.
                                The other screen i tried is not exactly the same model so can't use it for measurement comparison.
                                • Andreasbest
                                  • Aug 2014
                                  • 1163
                                  • Hellas ( Greece )
                                  Desolder the last 2 capacitors that seemed shorted, no problem there either. The short is elsewhere.
                                  • pc_okay
                                    • May 2022
                                    • 241
                                    • FRANCE
                                    It could be a lot of thing not only caps…
                                    Everything connected to This Line is suspect, and you can’t desolder everything…
                                    I never repaired screen but I think you can try to inject low voltage on the fuse if resistance is super Low (compare With other screen)
                                    DON’T inject With motherboard attach or EDP câble…
                                    Check With thermal cam if something heat.
                                    Up voltage graduatly if nothing seems to heat.
                                    • Andreasbest
                                      • Aug 2014
                                      • 1163
                                      • Hellas ( Greece )
                                      Main IC got very hot, so i guess the short is there.
                                      Ordered a new screen. Thank you all!
                                        LENOVO Legion Y720 Legion i7-7700 Specification for Upgrade or Repair
                                        This specification for the LENOVO Legion Y720 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Legion Y720 boardview and Legion Y720 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for LENOVO Legion...
                                        09-12-2024, 02:30 PM
                                        Lenovo Legion Legion 5 17ACH6H Notebook Specification for Upgrade or Repair
                                        This specification for the Lenovo Legion Legion 5 17ACH6H Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Legion 5 17ACH6H boardview and Legion 5 17ACH6H schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                        09-07-2024, 05:00 AM
                                        Lenovo Legion Laptop Gamer Notebook Legion 5 15ACH6H Notebook Specification for Upgrade or Repair
                                        This specification for the Lenovo Legion Laptop Gamer Notebook Legion 5 15ACH6H Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Laptop Gamer Notebook Legion 5 15ACH6H boardview and Laptop Gamer Notebook Legion 5 15ACH6H schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                        Lenovo Legion Legion 5 15ITH6H Notebook Specification for Upgrade or Repair
                                        This specification for the Lenovo Legion Legion 5 15ITH6H Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Legion 5 15ITH6H boardview and Legion 5 15ITH6H schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                        09-07-2024, 04:10 AM
                                        LENOVO Legion T730 Legion i9-9900K Specification for Upgrade or Repair
                                        This specification for the LENOVO Legion T730 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Legion T730 boardview and Legion T730 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for LENOVO Legion...
