Trouble fixing Panasonic su-htb500 sound bar
  • chuds
    • May 2023
    • 中国
    I am repairing Panasonic su-htb500 recently, the main power supply is not powered, the standby power supply is 5.84V, I replaced the capacitor C5726 on the main board of the power supply, and now I find that the output voltage of ic700 is only 0.4v, and the main power supply still can't work, can anyone provide a repair In addition, I also found a problem. The pins of IC700 are different from the common ones, and the information cannot be found (the part number is C0CBABC00117). Does anyone know what type of IC to use instead, thank you!
  • chuds
    • May 2023
    • 中国
    Re: Trouble fixing Panasonic su-htb500 sound bar
    Maintenance Manual
    • hugocarmo
      Panasonic TX-24A1UN CRT Sound and Input problem.
      by hugocarmo
      Hi.
      I´ve been given an old CRT from Panasonic, it´s almost new, it was storaged and almost not used since bought.
      It is imaculate inside, almost no dust or debris inside.
      The picture is good, but I have no left sound channel, I tried all the inputs, outputs, even on headphone jack. In AV2 I hear sound from right channel but no image, on tv tuner only right sound channel, the same for AV1.
      So I started to look for a service manual, I found one, and started from the beginning.
      Most of the times the caps are the problem so I orderer all the caps for all boards,...
      04-26-2025, 07:45 PM
    • ChaosLegionnaire
      by ChaosLegionnaire
      09-13-2022, 09:02 AM
    • LEECH666
      Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
      by LEECH666
      Good day ladies and gentleman!
      I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
      This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
      I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
      01-19-2024, 05:46 PM
    • mar1in
      Panasonic TH-55AS670A no picture no sound
      by mar1in
      I've got this Panasonic TV here with the following symptoms:
      * Standby Light is solid RED
      * Turning on using the Button on the TV (long press) would change LED to blinking GREEN
      * After a couple of seconds, LED is solid GREEN and without picture or sound.
      I've tried a couple of things before tearing it apart:
      * Resetting using various combinations of powerbutton and volume buttons pressing down while booting.
      * Activating Self Check according to service manual using IR Blaster (we have no remote unfortunately)...
      09-10-2023, 11:10 PM
    • BigPete
      Panasonic Heatpump Dryer Repair
      by BigPete
      I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
      The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
      In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
      Unfortunately the whole machine has to come apart to fix it.
      I have...
      11-01-2025, 06:40 PM
