Onkyo HT-S6100: Front right speaker not working.
  • bear518
    • Aug 2013
    I have verified speaker and speaker wire works on another channel. I have also verified there is no right channel sound with earphones.
    Any suggestions?
    Also I hope this is the right place to ask if anyone has schematics to share on this unit
    Thanks in advance,
    Bear518
    Last edited by bear518; 05-03-2023, 11:11 AM. Reason: Forgot to ask about schematics
  • budwich
    • Jul 2015
    • 3097
    Re: Onkyo HT-S6100: Front right speaker not working.
    you might be in tough without a service manual. You can try and see if onkyo will sell you one (Back in the early days, before the "full internet", they use to sell hard copies).
    your testing appears to indicate a problem before the amp section as usually the HP take their feed before going thru the amps. What test instruments to do you have. IF you have a scope and since you have some good channels, you can feed in a 1khz wave (from a test / setup cd / dvd or via computer file output) and find it on the good channel at "strategic points" (ie. some labelled areas maybe) and then compare to the bad channel. Look at the labelling at some of the board connectors for good areas (FL/FR, etc).
    Hopefully someone will have a SM.
    Outside of that, some pictures of the guts might help to remove some of the "blindness" of testing.
    • petehall347
      • Jan 2015
      • 4447
      for fun swap the source input cables .
      • tibimakai
        • Jan 2012
        • 3680
        Maybe elektrotanya has it?
        That receiver, most likely has a different model number without the speakers.
        Something like TX-NRxxxxx
        • budwich
          • Jul 2015
          • 3097
          as tibimakai suggested, this sm might give you clues.
          • tibimakai
            • Jan 2012
            • 3680
            • Robell824
              • Nov 2016
              • 7
              • Usa
              I had similar issue with my Onkyo-A807, first thing i did was checked if there is voltage on the speaker terminal, after that the output transistors and then traced it all the way to the relay. Found out that relay was the defective component so i just ordered a replacement for $4 and replaced it myself.
              • CDNBrewer
                Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
                by CDNBrewer
                Hello Everyone,
                I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
                Symptoms:
                • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
                • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
                • I swapped the Left and Right surround
                08-05-2025, 09:29 PM
              • MegaZAC
                Onkyo TX-SR805 noise in one channel
                by MegaZAC
                Surprisingly enough, this receiver doesn't have the DSP chip issue. The HDMI board does not get hot, and sound over HDMI works fine.
                Regardless of the input, the right channel has noise that is clearly noticeable even on average volume level. The only cases when there's no noise is when VCR input is selected (some tracks on the board are damaged, maybe that's why), or if HDMI input is selected but nothing plugged into it. In all other cases, even when no input is connected I still have the noise.
                There's some logic behind it. As soon as I select an input I get only left...
                04-23-2025, 10:09 PM
              • Sik_6ty_Sixx
                HH Scott Model A510 Stereo Integrated Amplifier/ Graphic EQ - Blowing fuses in the LEFT speaker channel only. Any Help???
                by Sik_6ty_Sixx
                So like the title says, I have an old Stereo Receiver/Amplifier that I picked up from the goodwill, it's a HH Scott Model A510. When I first got it home it had zero output. Opened it up, notice the fuses are missing. Pop in 2 new fuses (AGC4A 250V) and try again, within 5 seconds the L channel fuse POP! I don't see any visible indications of damage or arc burns on the PCB, no popped resistors or diodes, no burnt traces or blown out caps. So I decide to just try another new fuse, POP. Swapped around my R and L speaker wires, and checked the integrity of all wires and connections. Everything looks...
                02-18-2025, 05:06 AM
              • eccerr0r
                old X58 triple channel board... memtest86 memory speed?
                by eccerr0r
                Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
                Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
                Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
                06-28-2025, 09:06 AM
              • spleenharvester
                Reverse engineering of 18650 4-channel tester
                by spleenharvester
                Hi friends
                I have reverse engineered this tester, schematic is attached and is complete except for capacitor values. These testers annoyingly have no model number but they are the ones you find on the first page of just about any website if you type in "18650 4-channel tester". There is also a 2-channel variant and a newer 8-channel variant. They are very cheap (about £15) and can measure voltage, current, internal resistance and capacity. They have a multicolour display for all these statistics. They also have terminal blocks so that if you want to use a breakout board...
                05-04-2025, 02:43 AM
