firmware for Marantz SR5008 stuck in update loop
  • Faluky
    • Jan 2023
    After an update it stopped playing audio and video, I have reset it as it says in the manual and tried to reinstall the firmware over the internet but logging failed each time and I tried to download the firmware to install it by usb but it does not appear on the official page, could you help me? Since it would be a shame to have to get rid of him, European version Thank you very much
    Best regards.
    Anyone got their hands on firmware for Marantz SR5008 stuck in update loop
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8292
    Re: firmware for Marantz SR5008 stuck in update loop
    Do a factory reset. Power up holding [Preset +] and [Preset -]
    See what that does.
    • Faluky
      • Jan 2023
      My current theory is that I need to update the firmware via USB, unfortunately Marantz no longer provides these files.
      I would appreciate any assistance!
      Below is steps I've tried and more context:
      * Soft Reset
      * Microprocessor reset
      * Network Reset
      * Unplug receiver and let sit overnight
      * Plug receiver into Ethernet directly to network and let sit.
      * Tried to source Firmware online
      * Tried Marantz's Firmware site on wayback archive.org
      * Called Marantz support. doesn't have the firmware to give to consumer.
      Also, some more context:
      The device when plugged into power, turns on automatically. No view is output over HDMI. The screen on the device will display the input and volume, and this can be changed using the dials.
      • R_J
        • Jun 2012
        • 9581
        Copied from another forum
        AFAIK, firmware update via USB doesn't start until the 2017 models.
        • lotas
          • Jan 2016
          • 4708
          • Russia
          There were links to update for a long time, but these links are no longer working.
          https://www.avsforum.com/threads/the...82248/page-153
          • Daniel Larsson
            Firmware file for LG SK10Y Soundbar stuck in Please wait loop needed
            by Daniel Larsson
            My LG Soundbar, SK10Y, has somehow ended up in an endless "PLEASE WAIT" loop and I am now starting to suspect that the firmware is causing this, and I can't manage to connect via the app to push a new firmware in as it never really starts.
            I can trick it to start via HDMI ARC and it actually starts up, flashes OPTICAL and then goes to ARC where the sound (including sub) is perfect, but the white led indicator keeps blinking and after 20 seconds it says "GOOD BYE" and shuts down.
            During these seconds the function button is not working...
            08-13-2025, 10:29 AM
          • pp74
            Marantz NR1508 USB firmware update image
            by pp74
            Does anyone happen to have the latest firmware for the NR1508? Marantz took their update server down and customer support refuses to provide the image to flash over USB.
            Regards
            05-10-2025, 11:55 PM
          • frankusb
            Marantz SR5007 USB firmware update image
            by frankusb
            Does anyone happen to have the latest firmware for the SR5007? Marantz took their update server down and customer support refuses to provide the image to flash over USB. They offered to let me pay a service center to do the update (has to be over USB).
            Thanks.
            02-20-2024, 11:29 AM
          • Meraxes
            Ps4 Slim firmware update stuck on 53%
            by Meraxes
            I have a Ps4 Slim, it works perfectly, I wanted to update to firmware v 10.1 and now it remains stuck at 53%, before it had version 6.50
            Hdd is ok, it is tested with hdtune pro
            The Blu-ray worked perfectly before the update
            I tried several USB flash drives, no change
            The wifi module was changed does the same
            Can someone help me ? can the southbridge have problems?
            03-07-2023, 09:37 AM
          • TheUser
            Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
            by TheUser
            Hello to everyone ,
            This is my first post here, and i would like to share with you a small story in case you can help me.
            Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
            All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
            I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
            02-10-2024, 02:07 PM
