Marantz SR5007 USB firmware update image
  • frankusb
    • Apr 2015
    • 111
    Does anyone happen to have the latest firmware for the SR5007? Marantz took their update server down and customer support refuses to provide the image to flash over USB. They offered to let me pay a service center to do the update (has to be over USB).
    Thanks.
  • Admin
    • Oct 2003
    • 5334
    If you can find the original site/link the file may be on the Wayback Machine https://web.archive.org/
    • frankusb
      • Apr 2015
      • 111
      That's a good idea. I can't find any evidence that they currently make USB images available on their web site. I see reference to it in the service manual but not the user manual.
      • frankusb
        • Apr 2015
        • 111
        I was able to acquire the file.
        • Admin
          • Oct 2003
          • 5334
          Can you share on the forum for others?
          • frankusb
            • Apr 2015
            • 111
            Well false alarm, the file I obtained appears to be for a different variant and the files in it are timestamped 2012 to boot. USB_SR5007K_100100140500-0001.zip
Name:	Screenshot 2024-02-22 at 4.14.17 PM.png
            • frankusb
              • Apr 2015
              • 111
              I was able to obtain the correct firmware but it's from 2013.
              • pp74
                Marantz NR1508 USB firmware update image
                by pp74
                Does anyone happen to have the latest firmware for the NR1508? Marantz took their update server down and customer support refuses to provide the image to flash over USB.
                Regards
                05-10-2025, 11:55 PM
              • Faluky
                firmware for Marantz SR5008 stuck in update loop
                by Faluky
                After an update it stopped playing audio and video, I have reset it as it says in the manual and tried to reinstall the firmware over the internet but logging failed each time and I tried to download the firmware to install it by usb but it does not appear on the official page, could you help me? Since it would be a shame to have to get rid of him, European version Thank you very much
                Best regards.
                Anyone got their hands on firmware for Marantz SR5008 stuck in update loop
                01-17-2023, 04:33 AM
              • TheUser
                Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
                by TheUser
                Hello to everyone ,
                This is my first post here, and i would like to share with you a small story in case you can help me.
                Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
                All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
                I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
                02-10-2024, 02:07 PM
              • Daniel Larsson
                Firmware file for Marantz NR1501 needed
                by Daniel Larsson
                I picked up a Marantz NR1501 that the seller said did not produce any audio, but was starting up just like normal. This was indeed the case and the hunt for damaged components started.
                After confirming all voltages and replacing all caps on this godforsaken HDMI-board I finally got sound from the AUX input, but all digital inputs are still dead.
                The service menu shows no DSP version so I desoldered IC1604 that should have the serial flash DSP firmware on it and made two dumps that turned out identical.
                The content of these seems to be useless as far...
                05-23-2025, 04:11 AM
              • rumpumpel1
                ThinkPad X12 Detachable Gen 1: keyboard after firmware update without function
                by rumpumpel1
                Lenovo System Update offered me an update for the firmware of the Folio keyboard for my X12 Detachable Gen 1. The update got stuck and after 20 minutes I switched off the laptop. Since then, the keyboard and touchpad have been without function. Does anyone know how I can revive it?
                10-24-2024, 08:59 AM
