Ps4 Slim firmware update stuck on 53%
  • Meraxes
    • Mar 2023
    • 5
    I have a Ps4 Slim, it works perfectly, I wanted to update to firmware v 10.1 and now it remains stuck at 53%, before it had version 6.50
    Hdd is ok, it is tested with hdtune pro
    The Blu-ray worked perfectly before the update
    I tried several USB flash drives, no change
    The wifi module was changed does the same
    Can someone help me ? can the southbridge have problems?
  • the old man51
    • Dec 2022
    • 11
    • yorkshire
    Re: Ps4 Slim firmware update stuck on 53%
    try connecting it direct to your router....not usb
    • diif
      • Feb 2014
      • 6978
      • England
      More likely to be hard drive than southbridge if you say its working
      • lotas
        • Jan 2016
        • 4850
        • Russia
        Try ver. 10.50
        • Meraxes
          • Mar 2023
          • 5
          I tried with 3 different hdd + a samsung ssd + 4 different firmware versions v 6.50, 7.50. 9.00, 10.01, the console used to have version 6.50 and now it's the same, it works perfectly up to 53%, then it freezes
          • Faluky
            firmware for Marantz SR5008 stuck in update loop
            by Faluky
            After an update it stopped playing audio and video, I have reset it as it says in the manual and tried to reinstall the firmware over the internet but logging failed each time and I tried to download the firmware to install it by usb but it does not appear on the official page, could you help me? Since it would be a shame to have to get rid of him, European version Thank you very much
            Best regards.
            Anyone got their hands on firmware for Marantz SR5008 stuck in update loop
            01-17-2023, 04:33 AM
          • Daniel Larsson
            Firmware file for LG SK10Y Soundbar stuck in Please wait loop needed
            by Daniel Larsson
            My LG Soundbar, SK10Y, has somehow ended up in an endless "PLEASE WAIT" loop and I am now starting to suspect that the firmware is causing this, and I can't manage to connect via the app to push a new firmware in as it never really starts.
            I can trick it to start via HDMI ARC and it actually starts up, flashes OPTICAL and then goes to ARC where the sound (including sub) is perfect, but the white led indicator keeps blinking and after 20 seconds it says "GOOD BYE" and shuts down.
            During these seconds the function button is not working...
            08-13-2025, 10:29 AM
          • TheUser
            Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
            by TheUser
            Hello to everyone ,
            This is my first post here, and i would like to share with you a small story in case you can help me.
            Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
            All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
            I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
            02-10-2024, 02:07 PM
          • dkneyle
            Sony KDL-46HX850 Can't upgrade/update firmware
            by dkneyle
            Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
            Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
            09-25-2024, 10:44 PM
          • piernov
            Infineon TPM firmware update files
            by piernov
            Infineon TPM firmware update files:
            Infineon_firmware_update.zip
            Code:
            TPM12_4.32.879.0_to_TPM12_4.34.1010.2.BIN
            TPM12_4.33.949.0_to_TPM12_4.34.1010.2.BIN
            TPM12_4.40.119.0_to_TPM12_4.43.257.0.BIN
            TPM12_4.40.119.0_to_TPM12_4.43.258.0.BIN
            TPM12_4.40.119.0_to_TPM12_4.43.259.0.BIN
            TPM12_4.40.119.0_to_TPM20_5.62.3126.0.BIN
            TPM12_4.40.119.0_to_TPM20_5.63.3144.0.BIN
            TPM12_4.40.119.0_to_TPM20_5.63.3353.0.BIN
            TPM12_4.42.132.0_to_TPM12_4.43.257.0.BIN
            TPM12_4.42.132.0_to_TPM12_4.43.258.0.BIN
            TPM12_4.42.132.0_to_TPM12_4.43.259.0.BIN
            10-25-2025, 10:09 AM
