DPA 50S common emitter push-pull schematic
  • kehall
    • Mar 2011
    • 14
    Hi
    I've come across a few emitter-follower/common collector push-pull power amp circuits where NPN / PNP are collector-connected to +ve and -ve respectively, but am working on a repair of a Deltec Precision Audio DPA 50S from circa 1987 where the PNP / NPN power transistors are connected the opposite way (PNP and NPN emitter to +ve and -ve respectively).
    The driving circuitry is therefore a bit more complex than I'm used to seeing and it's giving me a brain-block without any schematic to look at... Does anyone have any information that could be of help please?
    It appears the output power transistors on one channel have gone short (probably drivers too), taking out a pair of 6R0 (odd value!) wirewound resistors (one got so hot as to melt its own solder connection before vaporising itself)! Apparently this blew from cold having previously worked so possibly power-on stress on aged components.
    Power transistors are MJ15003 and MJ15004, drivers MJE15029 and MJE15028 (all pretty expensive so wanting to get this right), there's a couple of trimmers to set the bias/quiescent current for each channel too - they both appear to be fine, reading approx 5ohm, not open but again I have no information to go on apart from the working channel in terms of setting such things.
    I've scoured the net but not finding much info about these amps or this design anywhere, so any info greatfully received.
    Keith
  • eccerr0r
    old X58 triple channel board... memtest86 memory speed?
    by eccerr0r
    Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
    Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
    Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
    06-28-2025, 09:06 AM
  • acedogblast
    [Marantz SR5012] Center channel keeps going into ASO/Overcurrent protection.
    by acedogblast
    First off I would like to thank this community as it has provided me with great information that has helped me greatly on my repair for this Marantz SR5012 AV receiver. I am creating this new thread as the other 2 that I have created here has had their original question/problem solved and I plan that this is the final thread on my repair. Please note that this is my first time repairing audio amplifiers so I may not be aware of common issues and things to know.
    Lets start at what I have done so far. Random speaker popping on all channels is fixed by replacing the 2 large filter...
    03-01-2023, 08:24 PM
  • spleenharvester
    Reverse engineering of 18650 4-channel tester
    by spleenharvester
    Hi friends
    I have reverse engineered this tester, schematic is attached and is complete except for capacitor values. These testers annoyingly have no model number but they are the ones you find on the first page of just about any website if you type in "18650 4-channel tester". There is also a 2-channel variant and a newer 8-channel variant. They are very cheap (about £15) and can measure voltage, current, internal resistance and capacity. They have a multicolour display for all these statistics. They also have terminal blocks so that if you want to use a breakout board...
    05-04-2025, 02:43 AM
  • CDNBrewer
    Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
    by CDNBrewer
    Hello Everyone,
    I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
    Symptoms:
    • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
    • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
    • I swapped the Left and Right surround
    08-05-2025, 09:29 PM
  • dicky96
    Hitachi V19B01922 Channel Tune problem
    by dicky96
    Hi Guys
    I have a customer who has two Hitachi TVs in his bar, one is the model in the thread title and the other is a larger screen but has the same setup menu
    He also has an LG TV, so three screens in the bar
    I installed three Satlink ST-6503 DVB-T Modulators
    This model https://www.aliexpress.com/item/32916553905.html
    These connect to three satellite receivers via HDMI cables and then connect to a 4 way RF Amp that connects to the TVs on aerial cable. There is no incoming terrestrial antenna. I set the channel ID on the modulators to...
    02-09-2023, 09:20 AM
