Diagnosing NAD receiver -- unexplained shut-downs
  • JordanW
    • Jan 2023
    • 9
    Everyone -- I am trying to troubleshoot my NAD C740 stereo receiver, which either won't power on or won't consistently stay powered on.
    I will start by saying that I am a hobbyist, and while I am decently handy with basic DC stuff, I am more hesitant when it comes to mains-powered equipment (that is, reluctant to poke around with a multimeter when it is powered on)
    The central issue is that after a long period of non-use, the receiver powers on and all functions seem to behave normally, but after a couple of minutes, it powers itself off.
    If I attempt to power the radio on again at this point, nothing happens. But if I allow it to "rest" for at least a few hours, I can power it on again. The amount of time it stays on after this "rest" seems to depend on how much "rest" it has had (more "rest" = stays on longer)
    In some cases, the receiver can run quite happily for an hour or more, but if I manually turn it off, and then attempt to turn it on again right away, it simply won't turn on again.
    At first I thought this was a power supply issue, specifically of a relay in the initial power supply stage. The service manual (with schematics) is at https://www.manualslib.com/manual/1254519/Nad-C740.html and in the lower right corner, the initial power supply stage is shown (also highlighted in the attached image). I replaced the relay notated as RL901 in an initial attempt to fix the radio. This doesn't seem to have changed anything.
    It seems from the schematic that this relay is in fact energized (through the transistor DTC123JS -- not sure what type that is) by a signal coming from the socket labelled JL951A. I can confirm that socket connects to the "NAD Link" sub-board (presumably used for components to control each other). But that in turn is connected elsewhere in the radio, which I haven't explored.
    Presumably that "elsewhere" in the radio turns the DTC123JS transistor on and keeps it on.
    I'm really mystified as to what is going on -- the behaviour itself and why it is time-dependent (the "rest" periods). My guess would be that some component is failing as it "warms up" and turns that transistor off. Perhaps a bad cap? Is this the usual failure mode for a bad cap? None of the caps that I can see look obviously damaged or bulging, and the main power fuse is fine. But there are many dozens of capacitors in this receiver (some very large, some very small)
    Has anyone seen behaviour like this in consumer electronics before? What are some other likely culprits?
    Any advice would be appreciated, Happy New Year to all.
  • R_J
    • 9632
    Re: Diagnosing NAD receiver -- unexplained shut-downs
    I would start by replacing C961, it is for the standby circuit and the fact it is always plugged in, this cap can dry out over time.
    • JordanW
      • Jan 2023
      • 9
      Thanks for the tip, I think the one you are referring to is C951 (the second number does look like a 6 at first) -- 220 uF 16 V capacitor that is part of that standby power supply stage across the four-diode rectifier component, correct?
      • jiroy
        • Jun 2016
        • 2416
        • Lebanon
        R_J is right , it's C961.. Compare it to the "5" in the nearby diode ..
        Update : It's C951 ..Sorry
        • R_J
          • 9632
          This one...
          • JordanW
            • Jan 2023
            • 9
            This one...
            Thanks for the advice. I replaced that cap, and while the radio seems to be behaving a bit better, and will stay on and behave normally for several hours, if I power down the radio it will still not power up again right away -- but will do so after what seems like 30+ minutes "rest".
            Any ideas what to try next?
            • R_J
              • 9632
              Another likely problem is C712, it is a .01F capacitor and it is likely bad, it can upset the reset circuit, I would just disconnect it for now and see if the unit operates better, this is a 0.1 farad capacitor used for memory backup, C712 acts like a battery and if dead, it will load the 5.6v and upset the way the unit operates.
              The next voltage I would check is the 5.6 volts, it is supplied by the Q923 (78M56) regulator ic on page 9, C927 may be bad? I would check all the voltages to see if any are wrong ie: +12, -12 etc.
              The +13 volts standby feeds the in of Q923 via D925 this regulator supplies the 5.6v standby, once the unit is ON the regulator Q923 IN is fed by the +25.4v via D926
              A couple other caps that bight cause this type of problem are C707 (1µf/50v) in the reset circuit
              • JordanW
                • Jan 2023
                • 9
                Another likely problem is C712, it is a .01F capacitor and it is likely bad, it can upset the reset circuit, I would just disconnect it for now and see if the unit operates better, this is a 0.1 farad capacitor used for memory backup [...]
                Thank you so much for these tips.
                In another forum, someone suggested that there may be an issue with D951, D952, D953, D954 (the discrete diodes that make up the bridge rectifier) and / or R951, the resistor that feeds them.
                Their thinking is that if one of these diodes is "failing open" as it warms up, or if the resistor is increasing resistance as it warms up, that would explain why the receiver will stay on once powered on, but won't restart once powered down (that is, with hot diodes / resistor there is just enough current to keep the relay RL901 on if already on, but not enough to turn it on if it is not already on)
                What do you think of that idea?
                • R_J
                  • 9632
                  I would go after that .1 farad cap, diodes are likely not the issue, I suspect C712 is bad, just remove it for now.
                  • JordanW
                    • Jan 2023
                    • 9
                    I can do that -- just found it on the schematic. That is a big fat capacitance so it should be one of the largest things on the PCB and hopefully easy to find.
                    I have found that after the power cycles I've been trying out, the receiver "forgets" the last FM station it was tuned to (which I don't recall being its behaviour before) so perhaps that is also a clue in favour of C712 being an issue.
                    • R_J
                      • 9632
                      Yes, C712 is used for memory backup. The cap is located on the narrow side of the display board, next to JL704a plug, (page 7), likely looks like a single cell battery standing up on the board
                      • JordanW
                        • Jan 2023
                        • 9
                        Sorry for the delay, I wasn't able to get to this until today.
                        I managed to find C712 on the board. As you suspected -- there is some kind of orange goo emanating from one side (see photo below). I removed it.
                        The radio doesn't power up at all now, so likely there needs to be something there. I will try to find a replacement tomorrow.
                        • JordanW
                          • Jan 2023
                          • 9
                          An update -- Replacing C712 (the "coin cell" 0.1F cap responsible for maintaining the station memories) got the receiver back into working condition, and I was able to run it for about two hours with totally normal behaviour, including powering it off and on a few times. But after powering it down for the night, it now won't power back on again at all.
                          I got this receiver for a very low price, second-hand, about 10 years ago, so it doesn't owe me anything!
                          I'll try replacing that cap again "just in case" (I got a spare) but otherwise will sell it for parts / someone else's project. Thanks everyone for the advice.
                          • Th3_uN1Qu3
                            Believe in
                            • Jul 2010
                            • 6031
                            • Romania
                            It isn't that cap then. My guess is that orange goo coming out of it corroded or shorted some traces nearby. Look closely around the position of C712, use a magnifier or microscope if you have it.
                            A working TV? How boring!
                            • JordanW
                              • Jan 2023
                              • 9
                              I have both, and will take another look, but I didn't see anything obvious. And the orange goo never hit the circuit board (just on the cap itself) and never made it to the side with the traces.
                              I was so excited when the receiver started up normally after replacing the cap -- and then it died. Could be that the cap I put in got fried within its first use ... or it could be something different.
                              • Th3_uN1Qu3
                                Believe in
                                • Jul 2010
                                • 6031
                                • Romania
                                If you are sure you have no corrosion on the PCB then it is likely to be something else - try checking the other capacitors on the digital rails, maybe there are other bad caps causing glitches and lockups.
                                • wolf1976
                                  wireless receiver for 6 speeds fan control with remote control
                                  by wolf1976
                                  hi i have a receiver that is destroyed from the overvoltage i guess
                                  my question is has three wires u v w for driving a motor fan i found an other receiver wireless from aliexpresss with the same propertiew but for dc motor
                                  the motor fan has not label
                                  i have an other receiver operational
                                  In your opinion can i measure the voltage at the output ?
                                  what do you suggest me with a simple instrument multimeter or using someone instrument more specific ?
                                  thanks in advance...
                                  07-23-2025, 03:12 PM
                                • CdDvdFlash
                                  DSE GE6878 possible TV receiver dying remote not working well
                                  by CdDvdFlash
                                  For this Dick Smith TV GE6878 (Thompson) I replaced the broken remote with a universal it kinda works though if its more than a few meters away sometimes the buttons register and sometimes they wont so I bought another remote from another brand and it has the same problem, I've had an old TV in the past that the sensor died completely and I replaced it to fix it could this be a similar problem? I tried looking for a service manual, spare parts for a receiver and a parts list but I couldnt find any info. can someone please help me to find the info online for a service manual or where I can buy...
                                  07-03-2024, 03:55 AM
                                • sanalelevenstar
                                  Yamaha RX-V485 receiver. After encountering a "version error"
                                  by sanalelevenstar
                                  I'm having trouble with my Yamaha RX-V485 receiver. After encountering a "version error", the USB, Bluetooth, and network functions have stopped working, making it impossible to perform a firmware update through normal methods.
                                  After doing some research on forums, I found that earlier Yamaha models with similar issues (like the internal error message) could be fixed by shorting or soldering specific pads—such as R896—and then powering on the unit to enter a service/boot mode that displays the model info and allows recovery.
                                  I managed to find the service...
                                  09-10-2025, 01:54 AM
                                • Cornito
                                  Denon AVR-2700H audio stops while receiver still works
                                  by Cornito
                                  Hello team,
                                  I've got a new issue with a Denon Avr-2700H.
                                  After several minutes working, receiver stops playing sound with a poc eared in the speakers.
                                  Receiver still work and display video with error message on display.
                                  Seems to me that is the main output relay.
                                  I'm looking for the service manual that I can't find for the moment.
                                  Does somebody have it?
                                  Regards...
                                  08-03-2025, 06:10 AM
                                • JayPoorJay
                                  TV that only has headphone out to receiver/amp
                                  by JayPoorJay
                                  Hello All... Grateful for this site!
                                  I just repaired a 70inch Sharp flat screen I found on the curb in NYC (there are 1000s) thanks to the good folks on this site
                                  I have a question about an audio signal from a TV that only has a headphone jack as a audio output source. I have it hooked up now with a headphone style adapter that converts the headphone plug to an RCA. I plug this into my PHONO input on the receiver. To play it this way I need to turn volume waaaay down on TV and volume up higher than I think I should on the receiver. I get undertone hissy sound, blunt...
                                  02-20-2022, 09:03 AM
