Carpet overlocker motor gradually increases speed by itself
  • CptChronic
    • Jul 2022
    • 39
    • United Kingdom
    I have an overlocker for stitching carpets and once I turn it on and leave it on the slowest setting, the speed will slowly increase by itself. When this happens, the voltage between the speed increase potentiometer, increases by 0.001V. I've stripped the thing down and the circuit board looks fine. Could this be a faulty potentiometer? Or something else? There is some soot inside the housing near the transformer and drive belts
    Pictures here: https://imgur.com/a/sUjRJrU
  • CapLeaker
    Leaking Member
    • 8327
    Re: Carpet overlocker motor gradually increases speed by itself
    Go for the simple things first. Check the current it is drawing from the socket. Maybe it needs to be taken apart, cleaned and lubed?
    You can check the pot with your DMM and verify for smooth operation.
    • CptChronic
      • Jul 2022
      • 39
      • United Kingdom
      Thanks for your reply, I did check the potentiometer and when increasing/decreasing the speed (with the thing turned off) it shouldn't smoothly increase/decrease in ohms, it often jumps right up before settling on the value it should be.
      What do you mean by socket?
      • redwire
        • 3912
        Someone else has been in here doing repairs. The main speed control IC Atmel U2010 is in a socket and many connections resoldered etc.
        The IC socket looks like it's cracked or pins did not go in straight? The triacs need a heatsink so I can't see them taking much abuse.
        The speed control potentiometer resistance should not jump around unless it is dirty or burnt inside. I would disconnect any two of its wires and check with an ohmmeter.
        The motor's commutator has a lot of carbon on it, I take fine sandpaper and scrub that off. Most of this looks new.
        If you add a pic of the board's backside, I could figure out the calibration trimpots VR2, VR3 what they do.
        There's a loose metal washer in the picture, shake it out.
        • CptChronic
          • Jul 2022
          • 39
          • United Kingdom
          Ah yes I didn't spot that.
          I've just had it running with a thermal camera and only one of the triacs got hot and a few of the other parts, only ~50C so nothing crazy. The 2 resistors above the IC went to 300C after a few minutes though!
          I stripped down the potentiometer, it looks alright inside but gave it a good clean. It did seem to run a little better but the speed wasn't solid, at least we can cancel that one out.
          I'll get the motor commutator cleaned up and get you a picture of the boards rear next.
          • CapLeaker
            Leaking Member
            • 8327
            I wonder if the motor is gunk ed up, kinda working harder until it warms up a bit. You should see that reflecting in the power consumption of the motor. To monitor the current consumption the easiest was is to pug that machine into some power monitoring device on the power mains plug / socket. If you got a insulation tester, it could tell you the condition of the winding inside. What about taking that belt off and try spinning that motor by hand? I should spin like very easy.
            • CptChronic
              • Jul 2022
              • 39
              • United Kingdom
              Ok so here are a few pictures https://imgur.com/a/9mlfzEb
              I have traced what the 2 resistors are attached to, they're attached to 3 pins but only 2 of them are connected. 1 goes to the motor the other into the yellow relay which then is connected to the front panel which houses the on/off switches, the counter and the control with on/off trigger and speed control. Not sure what part it is connected to though. I get no continuity when flipping the switches, increasing the speed etc.
              Here's a couple of pictures of the front panel https://imgur.com/a/7gxIe8B you can see the blue and brown wires entering it at the bottom
              • CptChronic
                • Jul 2022
                • 39
                • United Kingdom
                Can I test it with a multimeter? I don't have a power monitoring device or insulation tester unfortunately.
                I darent take the belt off for fear I won't get it back on, it does seem to turn quite easily though
                Edit: it does make sense though, this could be why the resistors are getting so hot right?
                • CapLeaker
                  Leaking Member
                  • 8327
                  Yes it does... also the amount of dirt that the motor sucked in. Just look at the motor itself... it sucked tons of dirt.
                  I wonder that when the motor is warmed up, if it keeps its speed and current consumption.
                  • CapLeaker
                    Leaking Member
                    • 8327
                    I think most DMM's have a 10A fuse. But since I don't know what DMM you have, I can't say. You have a current clamp? Other than that, a el cheapo power monitoring device will do just fine for this. I don't really think you will get around not taking that belt off the motor at some point. You can also try current consumption with load (belt on the motor) and without any load (belt off). Maybe something binding up whatever that belt drives.
                    • CptChronic
                      • Jul 2022
                      • 39
                      • United Kingdom
                      Possibly, I haven't let it get that far as those resistors were at 300C and rising which is already way over their max temperature, guessing it's a 3W resistor.
                      Yes my multimeter is 10A, I don't have a current clamp either, I didn't know those things existed so will pick one up soon anyway, they look like a great addition to the kit.
                      I've just ordered a power monitor, theyre on offer at the moment, £16 from Amazon...bargain! That'll be here tomorrow so I'll check the current once it arrives.
                      Thanks for the help so far, I really appreciate it
                      • CapLeaker
                        Leaking Member
                        • 8327
                        A lot of the "basic" test equipment is cheap to get and doesn't break the bank for the occasional electronics tinkerer.
                        • redwire
                          • 3912
                          OP can you give us a make/model of this carpet overlocker?
                          I would confirm the speed control potentiometer is ok and also its wiring to the board.
                          The hot running resistor pair gives power to the controller IC.
                          • CptChronic
                            • Jul 2022
                            • 39
                            • United Kingdom
                            I can't find a model number, there really doesn't seem to be much info for these on the Internet but it's this one here: http://www.carpetsewingmachines.com/...pping-machine/
                            It's make is Kompakt
                            I have stripped down and cleaned the potentiometer, it's alot smoother now.
                            As the resistors getting that hot normal?
                            Thanks for the help as well redwire, I really do appreciate it
                            • CptChronic
                              • Jul 2022
                              • 39
                              • United Kingdom
                              Ok so I've got one of these power testers you plug into the wall, the amp reading started off around 0.9A and slowly trickled down to 0.82A and stayed around there.
                              Would this still point to the motor dragging before warm up? I let it run for around 8 minutes, the speed increased and decreased marginally all this time but it was slowly gaining speed overall. https://imgur.com/a/FWJ5zKS
                              Really don't know what to do at this point
                              • redwire
                                • 3912
                                I'm not sure what resistance readings you now get from the speed control potentiometer. I wondered if its wiper was open-circuit and the speed control board floating with no speed command coming in? Do the switches work OK or is it stuck running?
                                The two 24k resistors R16, R17 will run quite hot, they each dissipate around 2.2W each which is a lot. But not 300°C, I'd guess around 100°C is a max.
                                As for what's wrong with this thing, it's either the speed pot or the IC or the calibration or (less likely) the electrolytic capacitors. You'd have to take voltage measurements while the board is powered up, which is no fun. The IC needs around 14VDC power.
                                It's hard with no wiring diagrams although the same speed controller scheme is used on many power tools. This overlocker one just has a soft-start (many seconds to ramp up motor speed) and variable speed. There is no load compensation or tachometer circuit.
                                I would pen-mark the trimpots VR2, VR3 location and give them a turn to see what they do. I can't follow their PC board traces running to which IC pins to figure them out. Note this board is hazardous live so use an insulated screwdriver...
                                At this point I'd likely put in a new IC and make sure the triac is OK.
                                You could short the speed pot forcing it to minimum speed (resistance) or maximum speed to see if the IC is responding at all.
                                • CapLeaker
                                  Leaking Member
                                  • 8327
                                  I’d point at either the pot or the motor. The motor should come apart. But before I’d take the motor apart I’d warm it up then start it. The warming up is to get the lubricant what ever is in there left a bit more runny first place. Keep in mind that all that dirt went through he motor, the windings, the bearings, the lube, etc.
                                  • redwire
                                    • 3912
                                    Why do you think it's the motor? There's such a reduction factor on the pulleys I don't think it drawing more current would cause the speed to creep up.
                                    An idea would be to substitute the motor with an incandescent light bulb as a load for the control board and see if it works as a dimmer.
                                    • CapLeaker
                                      Leaking Member
                                      • 8327
                                      That is a great idea to try! I have to admit, that I didn't think on subbing the motor with a light bulb.
                                      My motor theory went like this: as the motor warms up the dust infected old dry grease in the bearings gets a bit thinner and the motor is easier to turn. Cold motor works harder and higher current consumption. Warm motor turns easier and less current consumption. I am wondering once the motor is hot, is it being stable in the rpm department. As I understood it the motor is going faster slowly, but at some point it's got to stop speeding up. Plus my assumption that it doesn't slow down.
                                        • Jul 2011
                                        • 6065
                                        If this motor controller is like the ones I have work on before one pot control adjust the lowest speed possible then there is one that either adjusts frequency or torque if had three pot controls not including the one on the outside of the enclosure would control the fastest speed
                                        If it has three pot controls and one slow speed and one controls the fastest speed they are in proportion to each other in other words when you adjust one it affects the other adjustment
                                        If it the type that I have described above the way you would adjust it is as follows turn the outside pot control to minimum control position and then adjust the slowest speed pot control then turn the outside pot control to maximum position then turn the fastest speed pot for the maximum speed needed to do the job then go back to the slowest speed and see if it functions correctly or not
                                        • juergenb
                                          Nescafe Aeroccino, still fails with new Motor (red flashes only once)
                                          by juergenb
                                          i am asking for some Help.
                                          I have one of these Nescafe Aeroccino (Milk Frother) things with a bad motor.
                                          The Motor didn“t start anymore and internet is full of users just swapping the motor for a Mabuchi RF-500TB-12560.
                                          So i got a few of these from Banggood.
                                          I swapped the motor and now i have a new fault condition.
                                          In a working Frother you would press the start button, it will light red and work for a few minutes.
                                          If you press longer it will light blue and just mixup the milk.
                                          With the new Motor it just starts...
                                          03-23-2021, 11:24 AM
                                        • sbt123
                                          charnwood w821 mini wood lathe motor problem
                                          by sbt123
                                          hi there,im having a look at repairing a wood lathe for my dad,(charnwood w821)the problem is when turning up the variable speed control,the motor starts to stop and start by itself,if i continue to turn up the speed it will trip the mcb in the consumer unit,there is also a slight smell of burning from the speed controll box.,Another strange symptom is the lathe can be unplugged from the mains after switching it off and the motor will spin a couple of times by itself,so far ive put a new speed controll potentiometer on and new motor brushes,ive also tested the motor windings and everything looks...
                                          10-27-2024, 03:43 AM
                                        • mikey5791
                                          Help identify this motor
                                          by mikey5791
                                          Hi all forum members,
                                          Found this unknown motor discarded in a junk yard and took home for learning experience. By the look of it, I suspect it is taken out from a type of air blower probably running on ac power. I used digital multimeter on ohm/resistance scale and it doesn't read anything on those 2 black wires. So, this motor is not shorted and should be good to run.
                                          Correct me if i am wrong on the initial test.
                                          Can anyone kindly advice on how to test run this motor based on visible external two black wires. Fyi, i don't see any marking on the motor body nor smell anything...
                                          11-24-2023, 07:54 PM
                                        • Per Hansson
                                          Motor run capacitor physical size vs voltage rating & measurements?
                                          by Per Hansson
                                          (TL;DR skip the first paragraph)
                                          I encountered my first dead motor run capacitor at a customer this week.
                                          For some fields I guess it is a very common occurrence but the usual way for industrial machines here is to use 3-phase motors.
                                          (Unless a servo motor makes more sense that is).
                                          But for some reason this 3-phase machine uses a 1-phase motor for its liquid coolant pump.
                                          The pump would run but sometimes trip the 10A breaker.
                                          I monitored it starting and stopping for over an hour until it finally stopped in a specific spot between its windings:
                                          Then it could...
                                          09-20-2020, 06:32 AM
                                        • cjard
                                          A motor controller is a power supply, right?
                                          by cjard
                                          Hoping someone here will be able to provide a few pointers with this. I've got a motor controller board for a device that moves a caravan. A DC motor on each wheel is supplied with 12v DC or -12V DC depending on whether the remote control is pushed in "forward" or "backward" mode. The control is arranged by having 2 relays per motor that, at rest, are all connected to the negative.. If the motor is to go forwards, then relay 1 activates meaning the motor sees "positive negative" on its terminals 1 and 2. If the motor is to go backwards then relay 2 activates meaning...
                                          10-14-2020, 01:24 PM
