Hi, I have a Hitachi Refrigerator R-Z270AUN7KV. The fridge is on the bottom and the freezer is on the top. My problem is no matter what setting (1-9) the freezer is, the fridge is not getting cold but the freezer is always cold. I have tried all combination of settings for the fridge (Min, Mid, Max) but nothing. Fridge is always hot now. Before it would sometimes do this but now always fridge is hot. I believe the service center peeled some of the foil from the thermostat and that seemed to help a few years back. I replaced the thermostat recently and it worked off and on for a few weeks but now fridge is always hot and freezer cold for the past week.
Hitachi Refrigerator R-Z270AUN7KV not cold.
Re: Hitachi Refrigerator R-Z270AUN7KV not cold.
The lower section get the cold air form the freezer section, so look for opening in the bottom section of the fridge to see if there is any obstruction, also look for a fan that circulate the cold air from freezer to the lower fridge section.
Show us the pictures of the internal chambers of the fridge.
https://www.gfyappliancerepair.com/b...-freezer-cold/Last edited by budm; 10-29-2020, 02:57 PM.Never stop learning
http://www.badcaps.net/forum/showthread.php?t=24809 -
manual says ..Is the cold air vent blocked with food?Comment
One thing to check is if the defrost timer is working, What can happen if it does not cycle, ice can build up around the freezer and block the air flow to cool the fridge. I have a fridge with a similar defrost timer and if the motor in it stops running, the fridge will not get cold. The timer should be located on the rear lower right, you can cycle it manually using a large flat blade screwdriver. If the fridge is indeed frozen up, you may need to turn the defrost timer until it clicks and the heat element comes on and do this a couple times, You should then see or here water running into the pan under the fridge.
If this is the timer, you can turn the grey knob with a flat blade screwdriver clockwise. until it clicks, If the compressor is running at the time it will turn off.Last edited by R_J; 10-29-2020, 05:22 PM.Comment
There was a buildup of ice on the coils. Cooled it down, melted it with boiling water. Now with the fridge and freezer set to the lowest settings, it has been working fine.Comment
Thank you. Is the defrost timer located in the freezer or fridge compartment? I don't recall seeing anything that resembled that in the freezer compartment.Comment
The defrost timer is likely located on the lower part of the rear of the fridge, It will not be inside a compartment. Here is the location of mine, take a picture of the rear of your fridge if you can't locate it. When I checked the model of your fridge, the defrost timer for it is the one I posted in the picture, The original is likely black not white.Last edited by R_J; 11-11-2020, 09:37 AM.Comment
I don't know where they put it on this model, but if it is a frost free refrigerator, it is there somewhere.
Here is the manual, with the schematic, trace the wiring to find the defrost timer, maybe it IS inside behind a panel somewhere?
The pictures are too small to make out what's behind that black box where the cord entersAttached FilesLast edited by R_J; 11-15-2020, 12:27 PM.Comment
It might be with the temperature controller sensor behind the cover would be my guess
This timer might not have outside access to outside world would be my guess
But who knows where it could beLast edited by sam_sam_sam; 11-18-2020, 06:47 AM.Comment
I suspect this is a similar fridge, It looks like it is item #38 behind the panel in the fridge compartmentAttached FilesLast edited by R_J; 11-18-2020, 04:47 PM.Comment
Thanks mate, it is a very similar model. Is it the #31 part in the diagram the defrost timer, I had suspected that was it? It did it again this week it worked fine for like a month or so.Comment
NO that is the fan motor, The defront timer is #38Comment
Maybe it can be fixed? I don't have it to be able to tell. There is no adjustment, it is a timer, I suspect the small internal motor is not turning for some reason.
There should be a way to access the timer (post #6) so you can operate the switch manually by turning it with a flat screwdriver. maybe the access hole is under panel 42 or 36? If you can access it you can turn it to the defrost cycle, let it operate that way for about 10min, then advance it again to let the compressor operate.Last edited by R_J; 02-03-2021, 02:58 PM.Comment
The defrost timer only runs when the fridge/compressor is running. The defrost motor is connected across pins 1 & 3, check the resistance of the motor, if it is good then maybe you can get some type of cleaner to wash out the motor and the reduction gears inside it? If not just replace the timer, If you can find a used one it should be ok, you can order them off the internet, just be sure to get the right voltage (ac200~240)Last edited by R_J; 02-28-2021, 02:10 PM.Comment
by Th3_uN1Qu3I had this refrigerator at my old folks which I noticed I would put my beer or soda in and take it out warmer than I'd brought it from the store.
Now, I don't know much about refrigerators or HVAC but to me it seemed like we have a problem. I threw a thermometer in... 20 deg C in the fridge. WHAT THE...Freezer worked fine with temperatures way below zero, as it should, and it has only one compressor for both sides so it got me scratching my head for a while.
Only other things that seemed a bit odd was that the heatsink on the back was barely warm and the... -
by connorcc2005I have a 20 year old Kenmore side by side refrigerator that was acting up with the following issues:
- Evaporator coil in the freezer was frozen up.
- Unit was still holding temperature
- Evaporator fan would run 2 to 3 seconds on then shut off only to repeat.
1 Photo -
by CG2To be a bit more specific, I've got a 20-ish year old Liebherr that has just stopped working. This was quite a sophisticated beast for its time. It's a twin compressor model, and you set the desired temperatures of the fridge and freezer parts from a couple of little control panels above the door. It displays the actual temps on some eight segment displays there, flashing if it's working to get to where you want it. There's a control board with a microprocessor on it that read the temperature from a couple of sensors, switches the compressors on as necessary, and runs the display. There's also...
Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
The TV was stuck on the logo and I couldn't access the update menu.
I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
The image result was good, but the image is inverted.
The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in... -
by mikey5791Hi all forum members,
Few days ago, i might have forgotten to close my home fridge freezer door completely. The next day, the ice cubes and frozen meat almost melted halfway and the freezer doesn't feel cool. I shut it off, wipe dry and let it air dry for one whole day. The next day i switched on the fridge, the compressor run for a second and it shuts off(no vibration and no sound at all) only the internal freezer compartment fan is running but is not cooling even i switched on a full day.
After shut off, i dismantle the rear water pan holder and reached to the compressor wiring.... - Loading...
