Dryer Motor Possibly Short Circuiting
  • ron350
    • Feb 2014
    • 296
    Re: Dryer Motor Possibly Short Circuiting
    Since you will have to resolder that relay pin it wont hurt to add solder to the high stress parts.
    The power plug pins, transformer, both relays, those two large caps and BZ1.
    You will want to clean that burnt relay pin so that solder will stick properly. I just scrape a burnt pin with a knife till I see clean metal.
    • EasyGoing1
      Shock Therapist
      • Sep 2016
      • 977
      Thats exactly what I did. I also exposed some of the adjacent PCB trace and put a little flux around everything then took a small piece of solder wick and formed it around the pin and cut enough length to reach the exposed trace on the board and soldered it all together ... this problem should NEVER happen again with the way I re-enforced everything.
      sigpic
      • EasyGoing1
        Shock Therapist
        • Sep 2016
        • 977
        Originally posted by redwire
        Just to be clear, you have the same bad connection at a relay terminal on the PC board as the pics below? Bosch dishwasher that has bad connection just like your dryer pic.
        It's a common problem in appliances. Vibration or poor soldering fractures the joint, it arcs (tiny, inside the hole) and spews out solder vapor and gets worse.
        To fix it, if the relay is not damaged from the heating, just clean the joint and resolder it.
        The Whirlpool, Kenmore, or Kitchenaid dishwasher class action suit, you get $100, or 30% buying a new one. It was the same bad connection arcing.
        So I got the circuit board contacts cleaned up and re-soldered and re-enforced and I re-enforced all of the points on the PCB that handle 120 ... and I re-soldered the transformer contacts and all of the caps that were not surface mounted ... and I got the board re-installed and the dryer all put back together and it works like a champ!
        Thank you ... everyone who took the time to comment on this thread ... the information was invaluable in getting this thing working.
        sigpic
        • ajshoe
          ajshoe
          • Dec 2012
          • 477
          • usa
          you can test this motor very easily. believe u can put ac cord on pin 5 and pin 2 - then lift the roller assembly up - motor should run. or u can ohm these to points - aro 3-5 ohms.
          • DynaxSC
            Extreme High Current & Low Voltage Short Killer ??
            by DynaxSC
            Hi Folks
            I'm looking for a extreme high current short killer solution for a reasonable cost.
            I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
            After taking off the socket, the shorts dissappear again.
            The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
            10-15-2024, 10:13 AM
          • Stephen
            MacBook Pro 14" A2442 Short on PPBUS_AON but no short present when injecting voltage!
            by Stephen
            I check PPBUS_AON and there is a short present on the line, the computer shows a short when testing for short to ground, so when I inject voltage into the line, I get 0AMPS so no short is showing up. I have replaced a blown cap on this board that exploded and tested for the short and it is now removed. Any suggestions? I tested voltage at the line when the fuses are connected and I am getting 1.2 Volts at the line.
            02-06-2025, 12:03 PM
          • Victor Moreira Silva
            Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
            by Victor Moreira Silva
            I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
            Well, my decice specs are the following:
            Model: Acer Nitro 5 AN517-54-55T5
            CPU: Intel Core i5-11400H
            GPU: NVIDIA GeForce GTX 1650
            Motherboard: GH51G LA-L181P Rev:1c
            The symptom:
            When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
            05-26-2025, 10:49 AM
          • aaronkatrini
            Help me find the short circuit on this WORKING Nvidia GTX1650
            by aaronkatrini
            Recently picked up this GTX1650 at a local flea market for a low price and wanted to use it on my secondary PC. I first tested the card and saw the fan spin for a split second and then nothing. Immediately I thought of a short circuit. Disassembled and found a shorted SMD capacitor, injected voltage into it (1V/4A) and two Mosfets got hot immediately (QN3103 & QN3107). Desoldered these Mosfets and the card turned back to life.
            Bought replacements from Aliexpress and replaced them afterwards. Tried the card but still the saw the fan spin for a split second...
            04-18-2024, 03:15 PM
          • sbt123
            charnwood w821 mini wood lathe motor problem
            by sbt123
            hi there,im having a look at repairing a wood lathe for my dad,(charnwood w821)the problem is when turning up the variable speed control,the motor starts to stop and start by itself,if i continue to turn up the speed it will trip the mcb in the consumer unit,there is also a slight smell of burning from the speed controll box.,Another strange symptom is the lathe can be unplugged from the mains after switching it off and the motor will spin a couple of times by itself,so far ive put a new speed controll potentiometer on and new motor brushes,ive also tested the motor windings and everything looks...
            10-27-2024, 03:43 AM
